Re: Validation: generating error messages [message #625449 is a reply to message #625310] |
Wed, 22 September 2010 08:32 |
Sebastian Zarnekow Messages: 3118 Registered: July 2009 |
Hi Bodo,
EMF generates a bunch of integer constants in the package that identify
features of your metamodel.
Consider the following example:
entity FOO {
where foo is the value of the name property of your entity. If a
validation marks the name as invalid (because it's all uppercase) you
want to identify the invalid attribute together with the invalid object.
So you'd call error("Invalid name", checkedEntity,
MyDslPackage.ENTITY__NAME). The editor will underline only FOO. If you
skip the feature and pass null, the complete entity will be underlined.
Hope that clarifies things.
Sebastian
Need professional support for Eclipse Modeling?
Go visit: http://xtext.itemis.com
Am 22.09.10 10:13, schrieb Bodo:
> In the validation path, one can issue error messages via the method call
> 'error'. The form I use is:
> protected void error(String string, EObject source, Integer feature)
> Now, I wonder, what one can path trough this message by the 3rd
> parameter 'feature'? In the example, a value form xxxPackage is chosen
> corresponding somehow to the grammar rule.
> But what does this parameter do?
FUDForum. Page generated in 0.02329 seconds
