Home » Modeling » TMF (Xtext) » Workspace aware epackage registry available for download?
Workspace aware epackage registry available for download? [message #62930] Thu, 23 July 2009 10:46 Go to next message
I'm working on multiple grammars which reference each other. I want to
setup a single workspace to edit the grammars. I then use a runtime
workspace to create xtend and xpand files (required to register the meta
models).
In the primary eclipse workspace I get errors in the grammars which
contain model imports. Those models are unregistered as they are created
right in this workspace. Therefore I need something like the workspace
aware registry, describe here:
http://apps.itemis.de/roller/itemislabkiel/entry/workspace_a ware_epackage_regist
Is this registry available for download somewhere?
I've played around with the different naming scheme for grammar imports
(like "classpath:/", "platform:/resource"). I ended up using the namespace
URI scheme.
Christoph
Re: Workspace aware epackage registry available for download? [message #62941 is a reply to message #62930] Thu, 23 July 2009 12:51 Go to previous messageGo to next message
Hi Christoph,
I'm afraid there is no such thing as a Workspace Aware Registry, but
maybe I'm wrong.
Why can't you use platform:/resource uris instead of nsUris? They should
work fine in your scenario of different languages that refer other
abstract syntaxes (meta models).
However, you should not try to use only one workflow to generate all
languages but use different workflows and use the StandaloneSetup in the
workflow to register the generated, referenced packages.
Hope that helps,
Sebastian
Need professional support for Eclipse Modeling?
Go visit: http://xtext.itemis.com
Am 23.07.2009 16:46 Uhr, schrieb Christoph Kulla:
> models).
> namespace URI scheme.
> Regards
> Christoph
Re: Workspace aware epackage registry available for download? [message #62964 is a reply to message #62941] Fri, 24 July 2009 05:12 Go to previous messageGo to next message
Hi Sebastian,
I've also tried the "platform:/resource" URIs. The problems start when you
are working in a runtime eclipse or export the plugins to another eclipse.
My setup is like:
Primary Eclipse:
Grammar A
Grammar B with cross references to A (A is referenced by
platform:/resource/.../A.ecore URI)
Start Eclipse runtime from primary eclipse
Create a new project. Create a xtend file. Import B and try to reference
cross references to A in the xtend file. This results in error markers.
This can be avoidd using nsURIs, but then you get the error markers in the
primary eclipse installation :(. What I trying to achieve is an error free
setup in both eclipse installations.
Christoph
Re: Workspace aware epackage registry available for download? [message #62980 is a reply to message #62964] Fri, 24 July 2009 08:15 Go to previous messageGo to next message
Hi Christoph,
this is a bug in Xpand. Generally speaking, EMF will transparently
convert platform:/resource to platform:/plugin uris in a runtime
workspace. To get this behaviour, you have to initialize the uri mapping
properly for the resource set, that you are working with. Xpand internal
analyzer did not do this, but it was a one liner to fix it.
It will make it into CVS after a code review.
Thanks for your detailled steps to reproduce this bug.
Sebastian
Am 24.07.2009 11:12 Uhr, schrieb Christoph Kulla:
> Hi Sebastian,
> you are working in a runtime eclipse or export the plugins to another
> eclipse.
> My setup is like:
> Primary Eclipse:
> Grammar A Grammar B with cross references to A (A is referenced by
> the primary eclipse installation :(. What I trying to achieve is an
> error free setup in both eclipse installations.
> Regards
> Christoph
Re: Workspace aware epackage registry available for download? [message #62986 is a reply to message #62980] Fri, 24 July 2009 09:31 Go to previous messageGo to next message
sounds great! Does this also apply for xtend?
Christoph
Re: Workspace aware epackage registry available for download? [message #62989 is a reply to message #62986] Fri, 24 July 2009 09:33 Go to previous message
Hi Christoph,
actually I tested it with Xtend, but I will double check with Xpand and
check files.
Sebastian
Am 24.07.2009 15:31 Uhr, schrieb Christoph Kulla:
> Regards
> Christoph
Previous Topic:XtextResource to XMI
Next Topic:[XText] unknown behavior
Current Time: Wed Jul 30 17:07:16 EDT 2025
Powered by FUDForum. Page generated in 0.05294 seconds
