Home » Eclipse Projects » Nebula » Issue with Grid widget
Issue with Grid widget [message #62914] Tue, 10 March 2009 11:07 Go to next message
I'm facing an issue with the Grid widget that I can't reproduce.
Sometimes when collapsing all nodes in the tree, the Grid throws an
invalid argument exception while painting. The line of exception is 2519
(the source code is a bit old). Here is a snippet of the code:
// parameter preparation
if (startIndex == -1)
if(!inverse)
// search frist visible item
do startIndex++; while (startIndex < items.size() &&
!((GridItem)items.get(startIndex)).isVisible());
if (startIndex == items.size()) return null;
else
// search last visible item
startIndex = items.size();
do startIndex--; while (startIndex >= 0 &&
if (startIndex == -1) return null;
// fail fast
if (startIndex < 0 || startIndex >= items.size()
|| ((GridItem)items.get(startIndex)).isVisible() == false)
SWT.error(SWT.ERROR_INVALID_ARGUMENT);
If I'm not wrong, the only case that throws the invalid argument
exception is if the item at startIndex is not visible (if startIndex is
out of range it should return null from the previous statements).
So my question is, how it is possible to have the startIndex item not
visible but passing the previous checks and loops ?
I tried several combinations of expanded/collapsed states but I can't
get this error. Do you have any hint on how I could reproduce such error ?
Marco.
Re: Issue with Grid widget [message #62915 is a reply to message #62914] Tue, 10 March 2009 11:45 Go to previous messageGo to next message
Hi Marco,
Could you please give the current header_footer branch a try and once
you manage to get a stacktrace file a bugzilla with as much information
(ideally with a snippet)
Tom
Marco Maccaferri schrieb:
> if(!inverse)
> else
> // fail fast
> Marco.
Re: Issue with Grid widget [message #62916 is a reply to message #62915] Tue, 10 March 2009 13:26 Go to previous message
Unfortunately I can't use the latest code because I'm still running with
an Eclipse 3.2 SDK.
The problem is that I can't build a snippet, because I don't have any
clue about how to reproduce the error. It happens on a client
installation but I can't run a debugger on it.
This is a partial stack trace however it doesn't say much:
java.lang.IllegalArgumentException: Argument not valid
at org.eclipse.swt.SWT.error(SWT.java:3358)
at org.eclipse.swt.SWT.error(SWT.java:3297)
at org.eclipse.swt.SWT.error(SWT.java:3268)
at org.eclipse.nebula.widgets.grid.Grid.getRowRange(Grid.java:2 519)
at org.eclipse.nebula.widgets.grid.Grid.onPaint(Grid.java:4920)
at org.eclipse.nebula.widgets.grid.Grid.access$2(Grid.java:4890 )
org.eclipse.nebula.widgets.grid.Grid$4.paintControl(Grid.jav a:6013)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:83)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:928)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:952)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:937)
at org.eclipse.swt.widgets.Composite.WM_PAINT(Composite.java:12 85)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3299 )
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4025 )
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native
Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:19 23)
org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2966)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:820 )
at org.eclipse.jface.window.Window.open(Window.java:796)
Marco.
Re: Issue with Grid widget [message #593927 is a reply to message #62914] Tue, 10 March 2009 11:45 Go to previous message
Hi Marco,
Tom
> if(!inverse)
> else
> // fail fast
> Marco.
Re: Issue with Grid widget [message #593934 is a reply to message #62915] Tue, 10 March 2009 13:26 Go to previous message
an Eclipse 3.2 SDK.
Method)
Marco.
Previous Topic:Issue with Grid widget
Next Topic:collapsible buttons layout issue
Current Time: Tue Jul 22 02:38:49 EDT 2025
Powered by FUDForum. Page generated in 0.11461 seconds
