Re: GridViewer - Getting notifed when a record gets invisible through vertical scrolling [message #62906 is a reply to message #62904] |
Thu, 05 March 2009 05:41  |
thx a lot!
peter
Tom Schindl schrieb:
> Hi Peter,
> Yes there is. I'm using it to keep my image handle count down to a
> minimum (I have viewer who show thounds of images). You need to use my
> header_footer branch and there you'll find a class named
> GridVisibleRangeSupport? It will inform you whenever the visible range
> of cell has been changed.
> I'm going to present those feature at EclipseCon in a short talk about
> Nebula-Grid [1].
> Tom
> [1]http://www.eclipsecon.org/2009/sessions?id=571
> Peter Pfeifer schrieb:
>> Hello there.
>> I'd like to get notified from the gridviewer when a record dissapears?
>> E.g my gridviewer displays 10 lines whereas the gridviewer input
>> consists of 20 lines. So when the user does a vertical scroll, each
>> time a record disappears from the visible range i'd like to get notifed.
>> is there a way to achieve this?
>> regards,
>> peter
Re: GridViewer - Getting notifed when a record gets invisible through vertical scrolling [message #593855 is a reply to message #62902] |
Wed, 04 March 2009 10:09  |
Hi Peter,
Nebula-Grid [1].
Tom
> Hello there.
> consists of 20 lines. So when the user does a vertical scroll, each time
> regards,
> peter
Re: GridViewer - Getting notifed when a record gets invisible through vertical scrolling [message #593866 is a reply to message #62904] |
thx a lot!
peter
> Hi Peter,
> Nebula-Grid [1].
> Tom
>> Hello there.
>> regards,
>> peter
FUDForum. Page generated in 0.04272 seconds
