Home » Eclipse Projects » Nebula » GridTableViewer and sorting
GridTableViewer and sorting [message #62890] Tue, 24 February 2009 05:32 Go to next message
Hi all
How do I sort a Grid when using a GridTableViewer? I tried it using a
ColumnViewerSorter, but that doesn't seem to work. Furthermore, Grid
doesn't seem to have API like setSortColumn() or setSortDirection().
Any help is highly appreciated.
Christian
Re: GridTableViewer and sorting [message #62892 is a reply to message #62890] Tue, 24 February 2009 06:34 Go to previous messageGo to next message
Christian Hauser wrote:
> Hi all
ColumnViewerSorter is a ViewerComparator. However, I can only set a
ViewerComparator to the GridTableViewer, not to its columns. How is this
supposed to be used?
I'm still confused and would be very happy for any hint.
Christian
Re: GridTableViewer and sorting [message #62894 is a reply to message #62892] Tue, 24 February 2009 06:47 Go to previous message
Hi all,
I managed to get my Grid to sort the columns. I had a problem in my code.
This is the way I'm doing the sorting now:
For each column I add a new ColumnViewerSorter:
new ColumnViewerSorter(myGridTableViewer, myGridViewerColumn) {
protected int doCompare (Viewer viewer, Object e1, Object e2) {
// compare the two items e1 and e2
And this is the implementation of ColumnViewerSorter:
public abstract class ColumnViewerSorter extends ViewerComparator {
public static final int ASC= 1;
public static final int NONE= 0;
public static final int DESC= -1;
private int direction= 0;
private final GridViewerColumn column;
private final ColumnViewer viewer;
public ColumnViewerSorter (ColumnViewer viewer, GridViewerColumn
column) {
this.viewer= viewer;
this.column= column;
this.column.getColumn().addSelectionListener(new
SelectionAdapter() {
public void widgetSelected (SelectionEvent e) {
if (ColumnViewerSorter.this.viewer.getComparator() !=
null) {
== ColumnViewerSorter.this) {
int tdirection= ColumnViewerSorter.this.direction;
if (tdirection == ASC) {
setSorter(ColumnViewerSorter.this, DESC);
} else if (tdirection == DESC) {
setSorter(ColumnViewerSorter.this, NONE);
} else {
setSorter(ColumnViewerSorter.this, ASC);
} else {
protected void setSorter (ColumnViewerSorter sorter, int direction) {
if (direction == NONE) {
column.getColumn().setSort(SWT.NONE);
viewer.setComparator(null);
} else {
sorter.direction= direction;
if (direction == ASC) {
column.getColumn().setSort(SWT.DOWN);
} else {
column.getColumn().setSort(SWT.UP);
if (viewer.getComparator() == sorter) {
viewer.refresh();
} else {
viewer.setComparator(sorter);
public int compare (Viewer viewer, Object e1, Object e2) {
return direction * doCompare(viewer, e1, e2);
protected abstract int doCompare (Viewer viewer, Object e1, Object e2);
Re: GridTableViewer and sorting [message #593805 is a reply to message #62890] Tue, 24 February 2009 06:34 Go to previous message
> Hi all
Christian
Re: GridTableViewer and sorting [message #593817 is a reply to message #62892] Tue, 24 February 2009 06:47 Go to previous message
Hi all,
column) {
null) {
} else {
} else {
} else {
} else {
viewer.refresh();
} else {
Previous Topic:Can we use JFace DataBinding with Grid?
Next Topic:CDateTime issues since 26 January?
Current Time: Mon Jul 21 21:21:29 EDT 2025
Powered by FUDForum. Page generated in 1.04237 seconds
