AGR from JUnits [message #62769] |
Thu, 30 March 2006 13:10  |
Originally posted by: dschaefer.qnx.com
I have a collection of JUnit plug-in tests already, and I generate a
nice report as part of my nightly builds scripts that gets posted as a
web page. (This is for the CDT by the way).
What I'd like to do now is add GUI tests to this framework. I'm excited
to see AGR and its ability to capture and execute GUI tests. However,
I'd like to slide them nicely into my JUnit framework.
Has anyone done anything like this? If not, anyone interested in
something like this. I would mind spending some dev cycles making this
easier to do.
Doug
Re: AGR from JUnits [message #65795 is a reply to message #65668] |
Tue, 11 April 2006 15:23  |
Thanks, Ali, sounds like the answer to my question is "no". Maybe I can
dig around the AGR code and talk to Scott and Joe to see if I can code
up a solution.
Doug (although at times I look like dough :) Schaefer
Eclipse CDT Project Lead.
Ali Mehregani wrote:
> Hi Dough,
> You can run AGR tests programmatically using the automatable test framework.
> I know there is a way for users to launch tests via a Java class. There is
> some EclipseCon material on how users can write an automatable service:
> http://www.eclipse.org/tptp/test/documents/tutorials/eclipse Con2006/Achieving_Continuous_Integration_with_the_Eclipse_Te st_and_Performance_Tools_Platform_files/v3_document.htm
> The only catch is that the results will be captured in an execution history
> file. You'll need to use an existing automatable service to interpret the
> results and cause JUnit failures/passes.
> The primary developer of the automatable service framework is Scott
> Schneider (scott.schneider@us.ibm.com). Joseph P Toomey
> (jptoomey@us.ibm.com) is also fairly familiar with the framework. You can
> either try to contact them personally or send out an email to the test
> mailing list:
> http://www.eclipse.org/tptp/home/project_info/general/mailne ws.html
> "Doug Schaefer" <dschaefer@qnx.com> wrote in message
> news:e1b81t$cks$1@utils.eclipse.org...
>>I guess my point is that, no, I am not willing to give up my current
>>infrastructure. I am happy with the reports that it generates and I
>>don't have the time to make fundamental changes with how my nightly
>>builds are done.
>> From what I understand, TPTP oversolves my problem and forces me to use
>>a complicated service and reporting mechanism. All I want to do is add
>>JUnits to my current infrastructure that tests the GUI. In particular,
>>I'd like to call an AGR test programatically and have failures exposed
>>as JUnit failures.
>>Doug.
>>>I should mention that the automatable service framework is described
> under
>>>the following topic in help contents:
>>>Testing automatically and manually > Testing JUnit plug-in > Launching
> tests
>>>from scripts and applications
>>>news:e0h6ul$emv$1@utils.eclipse.org...
>>>>easier to do.
>>>>Doug
FUDForum. Page generated in 0.15852 seconds
