Home » Language IDEs » Java Development Tools (JDT) » AST.parseCompilationUnit -> Unhandled exception caught in event loop
AST.parseCompilationUnit -> Unhandled exception caught in event loop [message #5616] Fri, 25 April 2003 15:10 Go to next message
I have the following class:
public class Action implements IObjectActionDelegate {
private ISelection selection;
private ICompilationUnit getCompilationUnit() {
return (ICompilationUnit) ((IStructuredSelection)
this.selection)
.getFirstElement();
public void run(IAction action) {
ICompilationUnit unit = this.getCompilationUnit();
try {
System.out.println(unit.getSource());
} catch (JavaModelException e) {
// TODO Auto-generated catch block
e.printStackTrace();
if (unit != null) {
System.out.println("Trying to parse: " + unit);
AST.parseCompilationUnit(unit, false);
System.out.println("Parsing done.");
//MyVisitor visitor = new MyVisitor();
//root.accept(visitor);
public void selectionChanged(IAction action, ISelection
selection) {
this.selection = selection;
public void setActivePart(IAction action, IWorkbenchPart
targetPart) {
// TODO Auto-generated method stub
It uses this extension point:
<extension
point="org.eclipse.ui.popupMenus">
<objectContribution
objectClass="org.eclipse.jdt.core.ICompilationUnit"
id="de.netbeyond.eclipse.ICompilationUnit">
<action
label="myproj"
tooltip="myproj Tool-Tip"
class="de.netbeyond.eclipse.myproj.Action"
enablesFor="1"
id="de.netbeyond.eclipse.myproj.Action">
</action>
</objectContribution>
</extension>
If I trigger the run() method in the Run-time Workbench I will get
everytime this error:
Trying to parse: HelloWorld.java [in [default] [in src [in test1]]]
class HelloWorld
static void main(String[])
Unhandled exception caught in event loop.
Reason:
java.lang.IllegalArgumentException
The statement
prints the source code of my test class HelloWorld.java, so I think
the given Java element exists and its source string can be obtained.
Any ideas why the exceptions is be thrown?
Thanks for the help,
Martin
Re: AST.parseCompilationUnit -> Unhandled exception caught in event loop [message #5635 is a reply to message #5616] Fri, 25 April 2003 15:31 Go to previous messageGo to next message
Originally posted by: adam.kiezun.gmx.net.remove
why don't you simply debug it?
a.
eclipse.org
Re: AST.parseCompilationUnit -> Unhandled exception caught in event loop [message #5645 is a reply to message #5635] Fri, 25 April 2003 16:38 Go to previous messageGo to next message
I traced it until the first line
buildBodyDeclarations(typeDeclaration, typeDecl);
of method
buildBodyDeclarations(org.eclipse.jdt.internal.compiler.ast. TypeDeclaration
typeDeclaration, TypeDeclaration typeDecl)
in class
ASTConverter.
I don't understand what happens here but in this method
typeDecl.bodyDeclarations().add(convert(nextMethodDeclaratio n));
will be called (nextDeclarationType = 1) and then the exception will be
thrown.
If I use my plug-in with another .java it works...
Regards, Martin
Re: AST.parseCompilationUnit -> Unhandled exception caught in event loop [message #5649 is a reply to message #5645] Fri, 25 April 2003 16:39 Go to previous messageGo to next message
Sorry:
MemberTypeDeclaration[] members = typeDeclaration.memberTypes;
Re: AST.parseCompilationUnit -> Unhandled exception caught in event loop [message #6345 is a reply to message #5616] Fri, 25 April 2003 16:53 Go to previous messageGo to next message
The error was induced by this line
assert(true);
in my HelloWorld class.
assert is a key word, not a method. It has to be
assert true;
But I'm wondering because I was able to compile and run the program
without any problems.
Regards, Martin
Re: AST.parseCompilationUnit -> Unhandled exception caught in event loop [message #6555 is a reply to message #6345] Sun, 27 April 2003 01:41 Go to previous message
Originally posted by: bob.objfac.com
Seems odd that this is a problem. Is it not true in Java that true == (true)
== ((true))...?
Bob
"Martin Burger" <m@rtin-burger.de> wrote in message
news:b8c75f$nd7$1@rogue.oti.com...
> assert(true);
> assert true;
> Regards, Martin
Previous Topic:[NEWBIE] How to determine the line-number of a code-fragment?
Next Topic:Looking for a good j2ee plugin - NOT LOMBOZ!!!
Current Time: Wed Jul 02 09:16:43 EDT 2025
Powered by FUDForum. Page generated in 0.29598 seconds
