Home » Language IDEs » ServerTools (WTP) » Applet configuration
Applet configuration [message #62742] Fri, 07 January 2005 10:18 Go to next message
Originally posted by: EdwardAHaynes.yahoo.com
Is there a way to configure what html file is used by the appletviewer
that eclipse uses or a way to pass in additional jar files (that would be
included in the "archive" attribute from the applet tag)?
Re: Applet configuration [message #66188 is a reply to message #62742] Wed, 19 January 2005 06:16 Go to previous message
Originally posted by: jmordax.terra.es
This is not really a WTP issue. It is Eclipse Foundation one.
Eclipse doesn't use a HTML to execute applets. It has a specific Run
Profile for Applets. Go to: Run -> Run... and create a new Java Applet
profile. You will see sevral tabs where you can set most of the
attributes you can specify inthe HTML like width, height and params.
About JAR files, it will use those found in the Java Build Path of your
Java Project.
Hope this helps,
Chemi.
> be included in the "archive" attribute from the applet tag)?
Previous Topic:Debugging JSPs
Next Topic:wtp cvs (today) db server bug
Current Time: Mon Jul 21 22:01:57 EDT 2025
Powered by FUDForum. Page generated in 0.24395 seconds
