Home » Archived » Test and Performance Tools Platform (TPTP) » Runtime options for AGR
Runtime options for AGR [message #62721] Thu, 30 March 2006 11:47 Go to next message
Originally posted by: vladimir.au.ru
I get OutOfMemory during execution of my scenario. I have several messages
in execution log. Firt of them is:
CAPTURED SYSTEM ERROR STREAM (MAXIMUM OF 10240 CHARACTERS):
Unhandled event loop exception
Reason:
java.lang.OutOfMemoryError
The next is:
Fatal runtime error happened during workbench emergency close.
org.eclipse.swt.SWTException: Failed to execute runnable
(java.lang.NullPointerException)
at org.eclipse.swt.SWT.error(SWT.java:2942)
at org.eclipse.swt.SWT.error(SWT.java:2865)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:126)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3102)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2761)
org.eclipse.jface.operation.ModalContext$ModalContextThread. block(ModalContext.java:153)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:303)
org.eclipse.jface.dialogs.ProgressMonitorDialog.run(Progress MonitorDialog.java:447)
org.eclipse.ui.internal.progress.ProgressMonitorJobsDialog.r un(ProgressMonitorJobsDialog.java:261)
org.eclipse.ui.internal.ide.IDEWorkbenchAdvisor.disconnectFr omWorkspace(IDEWorkbenchAdvisor.java:298)
org.eclipse.ui.internal.ide.IDEWorkbenchAdvisor.postShutdown (IDEWorkbenchAdvisor.java:200)
at org.eclipse.ui.internal.Workbench.shutdown(Workbench.java:19 97)
at org.eclipse.ui.internal.Workbench.busyClose(Workbench.java:5 96)
at org.eclipse.ui.internal.Workbench.access$8(Workbench.java:52 2)
at org.eclipse.ui.internal.Workbench$13.run(Workbench.java:713)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
at org.eclipse.ui.internal.Workbench.close(Workbench.java:711)
org.eclipse.ui.internal.WorkbenchConfigurer.emergencyClose(W orkbenchConfigurer.java:165)
org.eclipse.ui.internal.ide.IDEExceptionHandler.closeWorkben ch(IDEExceptionHandler.java:121)
org.eclipse.ui.internal.ide.IDEExceptionHandler.handleExcept ion(IDEExceptionHandler.java:100)
org.eclipse.ui.internal.ide.IDEWorkbenchAdvisor.eventLoopExc eption(IDEWorkbenchAdvisor.java:210)
org.eclipse.ui.internal.ExceptionHandler.handleException(Exc eptionHandler.java:62)
org.eclipse.ui.internal.progress.ErrorNotificationManager$1. run(ErrorNotificationManager.java:82)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
Caused by: java.lang.NullPointerException
org.eclipse.tptp.test.auto.gui.internal.recorder.Macro$1.run (Macro.java:261)
... 40 more
Reason:
Failed to execute runnable (java.lang.NullPointerException)
So, looks like eclipse is out of memory, thats why too many exceptions
occured. How I can set runtime options for script execution? Is it
possible?
Vladimir.
Re: Runtime options for AGR [message #63336 is a reply to message #62721] Sat, 01 April 2006 11:50 Go to previous message
Do you mean runtime options for the workbench that gets launched? If so,
then you have to wait until
https://bugs.eclipse.org/bugs/show_bug.cgi?id=109880 is implemented.
"Vladimir" <vladimir@au.ru> wrote in message
news:51609f10f2f50342ce5df72ac2f6563c$1@www.eclipse.org...
> Reason:
> The next is:
> at
> at
xt.java:153)
> at
va:447)
> at
> at
> at
isor.java:200)
> at
er.java:165)
> at
andler.java:121)
> at
Handler.java:100)
> at
> at
va:62)
> at
> at
> at
> at
java:226)
> at
> at
> at
> at
> ... 40 more
> Reason:
> possible?
> Vladimir.
Previous Topic:checkbox in Preferences dialog not worked with AGR
Next Topic:I have found the execution log problem for AGR!
Current Time: Sat Jul 26 14:02:27 EDT 2025
Powered by FUDForum. Page generated in 0.03591 seconds
