Grid and StyledCellLabelProvider [message #62677] |
Tue, 17 February 2009 03:10  |
Hi all,
I've been using a normal JFace TableViewer for an editable table.
However, I had to switch to GridTableViewer, because the customer needs
wrapping of the text within cells.
The problem I'm facing now is that my StyledCellLabelProvider that
highlights text is not working with Grid. Am I missing something or is
this rather new feature (Eclipse 3.4) not yet supported on Grid?
Thanks in advance for any help,
Christian
Re: Grid and StyledCellLabelProvider [message #62752 is a reply to message #62704] |
Tue, 17 February 2009 08:31   |
Hi Tom
I'm using a StyledCellLabelProvider, which is not a
IStyledLabelProvider, but thank you anyway. I think I can handle it now,
well, I'll have a look at it and try to adapt it somehow.
Thank you for your help and time!
Christian
Tom Schindl wrote:
> No. We don't support this but it should quite easy for you to implement
> a CellRenderer which uses a StyledString and renderer it.
> Attached to this mail you'll find a completely untested (I only wrote
> the code renderer) class but you should get the idea. Always remember
> when using the Grid you are in the position of drawing everything
> yourself and you are not restricted to the bounds of the native widget.
> Tom
> Christian Hauser schrieb:
>> Hi all,
>> Christian
Re: Grid and StyledCellLabelProvider [message #593652 is a reply to message #62704] |
Hi Tom
Christian
Tom Schindl wrote:
> Tom
>> Hi all,
>> Christian
FUDForum. Page generated in 0.05737 seconds
