Home » Archived » Test and Performance Tools Platform (TPTP) » checkbox in Preferences dialog not worked with AGR
checkbox in Preferences dialog not worked with AGR [message #62675] Thu, 30 March 2006 09:08 Go to next message
Originally posted by: vladimir.au.ru
I've found another problems with GUI recorder. I try to create the
following script:
- open preferences window (window->preferences)
- open java->compiler tab
- uncheck "Use default compliance settings"
I've recorded this scenario successfully and try to play it using "Quick
Run" button, but it failed with next exception:
There was an error while running the macro associated with the test case:
ModifyDefaultOptions. org.eclipse.core.runtime.CoreException: Line 13:
Cannot locate shell control:
org.eclipse.swt.widgets.Button#{{org.eclipse.jdt.internal.ui .preferences.OptionsConfigurationBlock$ControlData@1f6dbf5}}-{{1.0}}
Do you have any thoughts about it?
Vladimir.
Re: checkbox in Preferences dialog not worked with AGR [message #63313 is a reply to message #62675] Sat, 01 April 2006 11:44 Go to previous message
I didn't have problems recording and playing back your scenario. Looking at
your button's id, it looks like you have registered buttons with a bad
property:
org.eclipse.jdt.internal.ui.preferences.OptionsConfiguration Block$ControlDat
a@1f6dbf5
This is an object. The last part of it is the memory location of the
object, which will be different in each quick run session.
"Vladimir" <vladimir@au.ru> wrote in message
news:171a39087a4742a5dbd051b6e8a436db$1@www.eclipse.org...
> following script:
> Vladimir.
Previous Topic:AGR incorrectly records non-UI (programmatic) action and playback fails
Next Topic:Runtime options for AGR
Current Time: Tue Jul 15 15:31:23 EDT 2025
Powered by FUDForum. Page generated in 0.03772 seconds
