Home » Archived » XML Schema Definition (XSD) » Extension element
Extension element [message #62633] Thu, 28 July 2005 08:49 Go to next message
I have A.XSD which has element called employee I am not able to resolve
comeplete element defination of employee as subelement uses extension base.
Please help me to resolve extension base elements
My Requirement is to build schema tree. I am sending you sample schema and
code which I have used (modified for demo purpose).
with the current code I am getting this as output
/envelope
/envelope/firstname
/envelope/lastname
/envelope/address
/envelope/city
/envelope/country
But I should get something like this
/envelope
/envelope/address
/envelope/city
/envelope/country
Here is the code I have used
* Created on Mar 9, 2005
* TODO To change the template for this generated file go to
* Window - Preferences - Java - Code Style - Code Templates
package com.gxs.ai.ngwb.xsdparser;
import java.io.File;
import java.io.FileNotFoundException;
import java.io.IOException;
import java.util.ArrayList;
import java.util.Iterator;
import javax.swing.tree.TreeNode;
import org.eclipse.emf.common.util.URI;
import org.eclipse.emf.ecore.resource.Resource;
import org.eclipse.emf.ecore.resource.ResourceSet;
import org.eclipse.emf.ecore.resource.impl.ResourceSetImpl;
import org.eclipse.xsd.XSDAttributeDeclaration;
import org.eclipse.xsd.XSDAttributeGroupContent;
import org.eclipse.xsd.XSDAttributeGroupDefinition;
import org.eclipse.xsd.XSDAttributeUse;
import org.eclipse.xsd.XSDAttributeUseCategory;
import org.eclipse.xsd.XSDComplexTypeDefinition;
import org.eclipse.xsd.XSDDiagnostic;
import org.eclipse.xsd.XSDElementDeclaration;
import org.eclipse.xsd.XSDModelGroup;
import org.eclipse.xsd.XSDModelGroupDefinition;
import org.eclipse.xsd.XSDParticle;
import org.eclipse.xsd.XSDParticleContent;
import org.eclipse.xsd.XSDPlugin;
import org.eclipse.xsd.XSDSchema;
import org.eclipse.xsd.XSDSchemaContent;
import org.eclipse.xsd.XSDSimpleTypeDefinition;
import org.eclipse.xsd.XSDTypeDefinition;
import org.eclipse.xsd.impl.XSDComplexTypeDefinitionImpl;
import org.eclipse.xsd.impl.XSDElementDeclarationImpl;
import org.eclipse.xsd.util.XSDResourceFactoryImpl;
import org.eclipse.xsd.util.XSDResourceImpl;
* @author tatinip
* TODO To change the template for this generated type comment go to
public class XSDParserNEW {
private String m_XSDFileName;
private ArrayList m_error_List ;
private ArrayList m_warning_List ;
private int m_minOccurrence = 1;
private int m_maxOccurrence = 1;
private String m_rootElementName;
private boolean m_isRoot = false;
private boolean flag = false;
private boolean m_ignoreCpexTypeDefnName = false;
private String m_modelName;
private String m_modelDirection;
protected TreeNode m_VirtualRoot;
private String m_ModelType="";
public XSDParserNEW(){
public boolean parseXSD(String xsdFileName , String rootElementName)
throws FileNotFoundException , IOException , Exception
m_rootElementName = rootElementName;
m_XSDFileName = xsdFileName;
Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap( ).put( "xsd",
new XSDResourceFactoryImpl());
try
boolean status = validateAndProcess(xsdFileName);
return status;
}catch(IOException ioe)
throw ioe;
}catch(Exception e)
{ throw e;
private boolean validateAndProcess(String xsdFile) throws Exception
* This let's us test whether the string exists as a file.
* It not, we try as a URI.
m_error_List = new ArrayList();
m_warning_List = new ArrayList();
URI uri;
if (xsdFile==null ){
//DMParseError parserError = new DMParseError(4,"","Schema file not
specified",0,0);
//m_error_List.add(parserError);
m_warning_List.add("Schema file not specified in Model file " +
m_modelName);
//this.rootNode = null;
return true;
File file = new File(xsdFile);
if (!file.exists()){
//DMParseError parserError = new DMParseError(4,"","File Not
Found",0,0);
m_warning_List.add("Schema file not Found " + xsdFile);
return true;
if (file.isFile())
uri = URI.createFileURI(file.getCanonicalFile().toString());
else
uri = URI.createURI(xsdFile);
// Create a resource set, create a schema resource, and load the main
schema file into it.
ResourceSet resourceSet = new ResourceSetImpl();
resourceSet.getLoadOptions().put(XSDResourceImpl.XSD_TRACK_L OCATION,
Boolean.TRUE);
XSDResourceImpl xsdMainResource =
(XSDResourceImpl)resourceSet.createResource(uri);
xsdMainResource.setURI(uri);
xsdMainResource.load(resourceSet.getLoadOptions());
// Get the first resource, i.e., the main resource and those that have
been included or imported.
Object resource = resourceSet.getResources().get(0);
if (resource instanceof XSDResourceImpl)
XSDResourceImpl xsdResource = (XSDResourceImpl)resource;
XSDSchema xsdSchema = xsdResource.getSchema();
xsdSchema.validate();
* Schema file is valid if Diagnostics is empty
if (!xsdSchema.getDiagnostics().isEmpty())
for (Iterator i = xsdSchema.getDiagnostics().iterator();
i.hasNext(); )
XSDDiagnostic xsdDiagnostic = (XSDDiagnostic)i.next();
String localizedSeverity =
XSDPlugin.INSTANCE.getString("_UI_XSDDiagnosticSeverity_" +
xsdDiagnostic.getSeverity());
//Handle Error
// DMParseError parserError = new
DMParseError(4,"" ,xsdDiagnostic.getMessage(),xsdDiagnostic.getLine(),xsdDiagn ostic.getColumn());
xsdResource.unload();
return false;
// If the user not selected root element
set first element as root element
if (m_rootElementName == null ||
m_rootElementName.equalsIgnoreCase("")){
Iterator i = xsdSchema.getContents().iterator();
while(i.hasNext()){
XSDSchemaContent e = (XSDSchemaContent)i.next(); // probable root element
if (e instanceof XSDElementDeclaration){
m_rootElementName = e.getElement().getAttribute("name");
break;
processRoot(xsdSchema);
return true;
return false;
private void processRoot(XSDSchema schema)
//process each element directly under the 'schema' element
for(Iterator i = schema.getElementDeclarations().iterator(); i.hasNext(); )
XSDElementDeclaration e = (XSDElementDeclaration)i.next(); // probable
root element
m_isRoot = true;
if (m_rootElementName != null && !m_rootElementName.equalsIgnoreCase("")){
if (m_rootElementName.equalsIgnoreCase(e.getName())){
dumpContentItem(e, 0,"");
}else{
flag = false;
* Method dumpContentItem.
* @param item
* @param level
* This is a recursive method called for handling (currently)
XSDElementDeclaration,
* XSDComplexTypeDefinition, XSDSimpleTypeDefinition,
XSDAttributeDeclaration,
* XSDModelGroupDefinition, XSDAttributeGroupDefinition
private void dumpContentItem(XSDSchemaContent item, int level, String
xPath)
try{
if(item instanceof XSDElementDeclaration)
XSDElementDeclarationImpl elem = (XSDElementDeclarationImpl)item;
int min = m_minOccurrence;
int max = m_maxOccurrence;
if(elem.getName() != null)
xPath = xPath+"/"+elem.getName();
printTree(xPath);
m_isRoot = false; // Need to do this after writing the root header,
//because the processing of child elements starts here
// Get the type definition of the Element
XSDTypeDefinition elemTypeDef= elem.getTypeDefinition();
if(elemTypeDef==null && elem.getResolvedElementDeclaration().getValue() ==
null)
// For a reference
dumpContentItem(elem.getResolvedElementDeclaration(), level, xPath);
}else if((elemTypeDef instanceof XSDSimpleTypeDefinition) &&
((XSDSimpleTypeDefinition)elem.getTypeDefinition()).getConte nts().isEmpty())
// Element doesn't have any children i.e simpleContent but might have
restrictions etc
else // The 'type' attribute is another element in the same XSD file
/* name of the Complex type must be ignored when an element refers to
* it with the 'type' attribute
if(elemTypeDef instanceof XSDComplexTypeDefinition)
if(((XSDComplexTypeDefinition)elemTypeDef).getName()!=null )
m_ignoreCpexTypeDefnName = true;
dumpContentItem(elemTypeDef, level, xPath);
else if (item instanceof XSDComplexTypeDefinition)
XSDComplexTypeDefinitionImpl cplex = (XSDComplexTypeDefinitionImpl)item;
if(!m_ignoreCpexTypeDefnName && cplex.getName()!=null)
xPath = xPath+"/"+cplex.getName();
// Process the attributes
for(Iterator i = cplex.getAttributeContents().iterator(); i.hasNext(); )
XSDAttributeGroupContent att_grp = (XSDAttributeGroupContent) i.next();
// For attribute group
if(att_grp instanceof XSDAttributeGroupDefinition)
dumpContentItem(((XSDAttributeGroupDefinition)att_grp), level, xPath);
/*for(Iterator j =
((XSDAttributeGroupDefinition)att_grp).getAttributeUses().it erator();
j.hasNext(); )
j.next(); // need to take care
//dumpContentItem(((XSDAttributeUse)j.next()).getAttributeDe claration(),level);
}else if(att_grp instanceof XSDAttributeUse)
setAttributeOccurrences(((XSDAttributeUse)att_grp).getUse()) ;
dumpContentItem(((XSDAttributeUse)att_grp).getAttributeDecla ration(),level,
xPath);
else
System.out.println("2. UNHANDLED");
// Process the element content if it is not equal to null
if(cplex.getContent() != null)
if(cplex.getContent() instanceof XSDParticle)
dumpParticle((XSDParticle)cplex.getContent(), level, xPath);
else if(cplex.getContent() instanceof XSDSimpleTypeDefinition)
dumpContentItem((XSDSimpleTypeDefinition)cplex.getContent(), level, xPath);
else
System.out.println("1. UNHANDLED"+ cplex.getContent().toString());
else if (item instanceof XSDSimpleTypeDefinition)
XSDSimpleTypeDefinition simple = (XSDSimpleTypeDefinition)item;
xPath = xPath+"/"+simple.getName();
if(simple.getContents() != null )
if(!simple.getContents().isEmpty())
for(Iterator i = simple.getContents().iterator(); i.hasNext(); )
XSDSimpleTypeDefinition child_simple = (XSDSimpleTypeDefinition)i.next();
dumpContentItem(child_simple, level+1, xPath);
else
System.out.println("4. UNHANDLED");
else
System.out.println("3. UNHANDLED");
else if (item instanceof XSDAttributeDeclaration)
XSDAttributeDeclaration attrib = (XSDAttributeDeclaration)item;
xPath = xPath+"/"+attrib.getName();
} else if(item instanceof XSDModelGroupDefinition)
// For sequence, all, choice
XSDModelGroupDefinition mgdef = (XSDModelGroupDefinition)item;
if(mgdef.getModelGroup() != null)
for(Iterator i = mgdef.getModelGroup().getContents().iterator();
i.hasNext(); )
XSDParticle pcle = (XSDParticle)i.next();
dumpParticle(pcle, level+1, xPath);
} else
// for "<xs:group ref=
dumpContentItem((mgdef.getResolvedModelGroupDefinition()), level, xPath);
} else if(item instanceof XSDAttributeGroupDefinition)
XSDAttributeGroupDefinition att_grp = (XSDAttributeGroupDefinition)item;
if(!att_grp.getAttributeUses().isEmpty())
for(Iterator i = att_grp.getAttributeUses().iterator(); i.hasNext(); )
XSDAttributeUse att_use = (XSDAttributeUse)i.next();
setAttributeOccurrences(att_use.getUse());
dumpContentItem((att_use).getAttributeDeclaration(),level, xPath);
}else // For an attributeGroup reference
//dumpContentItem(att_grp.getResolvedAttributeGroupDefinitio n(), level,
xPath);
else
// example : XSDAnnotation, XSDNotationDeclaration, XSDImport, XSDInclude,
if(item != null)
System.out.println("Unhandled Schema Content : "+ item.toString());
}catch(Exception e)
e.printStackTrace();
// Set the class level helper variables to default values
m_isRoot = false;
private void setAttributeOccurrences(XSDAttributeUseCategory e)
if(e == XSDAttributeUseCategory.OPTIONAL_LITERAL)
m_minOccurrence = 0;
} else
if(e == XSDAttributeUseCategory.REQUIRED_LITERAL)
} else
if(e == XSDAttributeUseCategory.PROHIBITED_LITERAL)
m_maxOccurrence = 0;
else // default
* Method dumpParticle.
* @param p
* @param level
private void dumpParticle(XSDParticle p, int level,String xPath)
m_minOccurrence = p.getMinOccurs();
if (p.getMaxOccurs() == XSDParticle.UNBOUNDED ) {
m_maxOccurrence = Integer.MAX_VALUE;
}else {
m_maxOccurrence = p.getMaxOccurs();
XSDParticleContent partContent= p.getContent();
if(partContent instanceof XSDElementDeclaration)
dumpContentItem((XSDElementDeclaration)partContent, level, xPath);
else if(partContent instanceof XSDModelGroupDefinition)
dumpContentItem((XSDModelGroupDefinition)partContent, level, xPath);
else if(partContent instanceof XSDModelGroup)
XSDModelGroup temp = (XSDModelGroup)partContent;
for(Iterator i = temp.getContents().iterator(); i.hasNext(); )
dumpParticle((XSDParticle)i.next(), level+1, xPath);
else
System.out.println("unhandled particle "+ p.toString());
//XSDTerm
//XSDWildcard
private void printTree(String xPath){
System.out.println(xPath);
public static void main(String arg[]){
try {
new XSDParserNEW().parseXSD("A.xsd","employee");
} catch (FileNotFoundException e) {
// TODO Auto-generated catch block
} catch (IOException e) {
} catch (Exception e) {
here is XSD file.
A.XSD
<xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema">
<xs:element name="employee" type="fullpersoninfo"/>
<xs:complexType name="personinfo">
<xs:sequence>
<xs:element name="firstname" type="xs:string"/>
<xs:element name="lastname" type="xs:string"/>
</xs:sequence>
</xs:complexType>
<xs:complexType name="fullpersoninfo">
<xs:complexContent>
<xs:extension base="personinfo">
<xs:sequence>
<xs:element name="address" type="xs:string"/>
<xs:element name="city" type="xs:string"/>
<xs:element name="country" type="xs:string"/>
</xs:sequence>
</xs:extension>
</xs:complexContent>
</xs:complexType>
</xs:schema>
Thanks in Advance.
Param
Re: Extension element [message #62657 is a reply to message #62633] Thu, 28 July 2005 11:37 Go to previous message
Param,
Using XSDComplexTypeDefinition.getContentType in place of getContent and
getAttributeUses in place of getAttributeContents will give the computed
relations that take inheritance into account, instead of the syntactic
relations that give you only what's locally/physically defined in the type.
> resolve comeplete element defination of employee as subelement uses
> extension base.
> and code which I have used (modified for demo purpose).
> /envelope
> /envelope/firstname
> /envelope/lastname
> /envelope/address
> /envelope/city
> /envelope/country
> /envelope
> /envelope/address
> /envelope/city
> /envelope/country
> * @author tatinip
> rootElementName) throws FileNotFoundException , IOException , Exception
> try
> return status;
> throw ioe;
> }catch(Exception e)
> { throw e;
> URI uri;
> specified",0,0);
> m_modelName);
> return true;
> Not Found",0,0);
> return true;
> if (file.isFile())
> else
> main schema file into it.
> Boolean.TRUE);
> have been included or imported.
> i.hasNext(); )
> + xsdDiagnostic.getSeverity());
> //Handle Error
> return false;
> element set first element as root element
> while(i.hasNext()){
> element
> break;
> return true;
> return false;
> i.hasNext(); )
> m_isRoot = true;
> }else{
> flag = false;
> * @param item
> * @param level
> xPath)
> try{
> printTree(xPath);
> elem.getResolvedElementDeclaration().getValue() == null)
> // For a reference
> restrictions etc
> /*for(Iterator j =
> j.hasNext(); )
> xPath);
> else
> xPath);
> else
> else
> else
> i.hasNext(); )
> } else
> level, xPath);
> else
> XSDInclude,
> if(item != null)
> }catch(Exception e)
> m_isRoot = false;
> } else
> } else
> else // default
> * @param p
> * @param level
> }else {
> else
> //XSDTerm
> //XSDWildcard
> try {
> here is XSD file.
> A.XSD
> <xs:sequence>
> </xs:sequence>
> </xs:complexType>
> <xs:complexContent>
> <xs:sequence>
> </xs:sequence>
> </xs:extension>
> </xs:complexType>
> </xs:schema>
> Thanks in Advance.
> Param
Re: Extension element [message #596144 is a reply to message #62633] Thu, 28 July 2005 11:37 Go to previous message
Param,
> extension base.
> /envelope
> /envelope/firstname
> /envelope/lastname
> /envelope/address
> /envelope/city
> /envelope/country
> /envelope
> /envelope/address
> /envelope/city
> /envelope/country
> * @author tatinip
> try
> return status;
> throw ioe;
> }catch(Exception e)
> { throw e;
> URI uri;
> specified",0,0);
> m_modelName);
> return true;
> Not Found",0,0);
> return true;
> if (file.isFile())
> else
> Boolean.TRUE);
> i.hasNext(); )
> //Handle Error
> return false;
> while(i.hasNext()){
> element
> break;
> return true;
> return false;
> i.hasNext(); )
> m_isRoot = true;
> }else{
> flag = false;
> * @param item
> * @param level
> xPath)
> try{
> printTree(xPath);
> // For a reference
> restrictions etc
> /*for(Iterator j =
> j.hasNext(); )
> xPath);
> else
> xPath);
> else
> else
> else
> i.hasNext(); )
> } else
> level, xPath);
> else
> XSDInclude,
> if(item != null)
> }catch(Exception e)
> m_isRoot = false;
> } else
> } else
> else // default
> * @param p
> * @param level
> }else {
> else
> //XSDTerm
> //XSDWildcard
> try {
> here is XSD file.
> A.XSD
> <xs:sequence>
> </xs:sequence>
> </xs:complexType>
> <xs:complexContent>
> <xs:sequence>
> </xs:sequence>
> </xs:extension>
> </xs:complexType>
> </xs:schema>
> Thanks in Advance.
> Param
Previous Topic:Extension element
Next Topic:Validating XML doc against its Schema
Current Time: Mon Jul 21 21:49:51 EDT 2025
Powered by FUDForum. Page generated in 0.14330 seconds
