Home » Eclipse Projects » Equinox » Tapestry + Hivemind + OSGI
Tapestry + Hivemind + OSGI [message #62623] Sat, 25 February 2006 14:11 Go to next message
Originally posted by: iravana.gmail.com
I have read mentions of this configuration. Has anyone successfully done
this. If so, could you share some pointers/info with the rest of the group?
thanks
Re: Tapestry + Hivemind + OSGI [message #63267 is a reply to message #62623] Tue, 07 March 2006 13:59 Go to previous messageGo to next message
I have not done the integration, but over at ops4j we have done the same
thing for Wicket with OSGi
(http://wiki.ops4j.org/dokuwiki/doku.php?id=pax:wicket) which is quite
similar. Beside that, some of this work has been done by inserting the DPML
Metro object model (similar in functionality to OSGi) into Tapestry (
https://scm.ops4j.org/repos/ops4j/projects/legacy/components /http/examples/hangman/).
The docs are not generated right now, but I think it should not be too hard
to at least get the BundleContext into the framework.
Let me know if you are interested, and I can do a bit of digging.
/peter
> group?
> thanks
Re: Tapestry + Hivemind + OSGI [message #63475 is a reply to message #63267] Mon, 13 March 2006 12:17 Go to previous message
Thank you Peter. I will take a look at the links you provided.
Peter Neubauer wrote:
> /peter
>> group?
>> thanks
Previous Topic:org.eclipse.update.configurator fails with auto-installing
Next Topic:org.eclipse.equinox.servlet.bridge.launcher config.ini in HEAD references a new project I can't find
Current Time: Tue Nov 11 19:42:34 EST 2025
Powered by FUDForum. Page generated in 0.03867 seconds
