Home » Archived » BIRT » Problems with PDF
Problems with PDF [message #62611] Fri, 29 July 2005 07:06 Go to next message
Originally posted by: pb.entimo.com
Hallo,
I want to create a PDF-report in my application by BIRT engine 1.0.0.
The same HTML-report works fine.
The engine is successful initialized.
IRunAndRenderTask task = engine.createRunAndRenderTask( report );
HTMLRenderOption options = new HTMLRenderOption( );
String format = HTMLRenderOption.OUTPUT_FORMAT_PDF;
options.setOutputFormat( format );
String output = name.replaceFirst( ".rptdesign", "." + format );
options.setOutputFileName(output );
task.setRenderOption( options );
try
task.run( );
I get the error messages and warnings below during the command task.run( ).
Can anyone help me to avoid the messages:
- SCHWERWIEGEND: property - "text-transform" is not implemented yet.
- SCHWERWIEGEND: Error in letter-spacing property value 'normal':
- INFO: area contents overflows area in line SAS
Thx Peter
29.07.2005 12:57:01 org.eclipse.birt.core.util.BirtTimer logTimeTaken
INFO: Engine startup takes 15 Milliseconds.
29.07.2005 12:57:01 org.eclipse.birt.data.engine.impl.DataEngineImpl <init>
INFO: Data Engine starts up
29.07.2005 12:57:14
org.eclipse.birt.report.engine.content.impl.MasterPageConten t
initSimpleMasterPage
INFO: The property HeaderHeight is not set. Use Default 1 cm.
29.07.2005 12:57:14
INFO: The property FooterHeight is not set. Use default 1 cm.
line 1 column 1 - Warning: inserting missing 'title' element
29.07.2005 12:57:14 org.apache.avalon.framework.logger.Jdk14Logger info
INFO: Using org.apache.crimson.parser.XMLReaderImpl as SAX2 Parser
INFO: building formatting object tree
INFO: setting up fonts
29.07.2005 12:57:14 org.apache.avalon.framework.logger.Jdk14Logger error
org.apache.fop.fo.expr.PropertyException: No conversion defined
SCHWERWIEGEND: property - "word-spacing" is not implemented yet.
SCHWERWIEGEND: unknown length unit 'e15in'
INFO: [1]
SCHWERWIEGEND: At least one of minimum, optimum, or maximum IPD must be
specified on table.
29.07.2005 12:57:14 org.apache.avalon.framework.logger.Jdk14Logger warn
WARNUNG: Zero-width table column!
INFO: area contents overflows area in line ---
INFO: area contents overflows area in line SCSM
INFO: area contents overflows area in line Log
INFO: area contents overflows area in line Now
INFO: area contents overflows area in line Switched
INFO: area contents overflows area in line to
INFO: area contents overflows area in line This
INFO: area contents overflows area in line Destination
29.07.2005 12:57:15 org.eclipse.birt.data.engine.impl.DataEngineImpl
shutdown
INFO: Data engine shuts down
Re: Problems with PDF [message #62688 is a reply to message #62611] Fri, 29 July 2005 09:54 Go to previous messageGo to next message
Hallo,
I have forgotten to copy the following execption to the mail. Sorry!
This message only appears at first time of report creation.
29.07.2005 15:39:05 org.eclipse.birt.report.engine.emitter.fop.FOP
getDefaultConfigURL INFO: java.net.MalformedURLException: no protocol:
fop.xml java.net.MalformedURLException: no protocol: fop.xml
at java.net.URL.<init>(Unknown Source)
org.eclipse.birt.report.engine.emitter.fop.FOP.getDefaultCon figURL(FOP.ja
va:221) at
org.eclipse.birt.report.engine.emitter.fop.FOP.loadFOPConfig (FOP.java:104
) at
org.eclipse.birt.report.engine.emitter.fop.FOP.<init>(FOP.java:148)
org.eclipse.birt.report.engine.emitter.fop.FOPReportEmitter. endReport(FOP
ReportEmitter.java:278) at
org.eclipse.birt.report.engine.executor.ReportExecutor.execu te(ReportExec
utor.java:200) at
org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run (RunAndRender
Task.java:152) at
com.entimo.hyperion.ui.views.SASLogViewerPrintAction.runBIRT Print(SASLogV
iewerPrintAction.java:113) at
com.entimo.hyperion.ui.views.SASLogViewerPrintAction.run(SAS LogViewerPrin
tAction.java:38) at
org.eclipse.jface.action.Action.runWithEvent(Action.java:881 ) at
org.eclipse.ui.actions.RetargetAction.runWithEvent(RetargetA ction.java:21
2) at
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(Act
ionContributionItem.java:915) at
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributi
onItem.java:866) at
org.eclipse.jface.action.ActionContributionItem$8.handleEven t(ActionContr
ibutionItem.java:824) at
org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82) at
org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:796) at
org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2772)
org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2431)
org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1377)
org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1348) at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:25
4) at
org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:141)
com.entimo.hyperion.product.HyperionApp.run(HyperionApp.java :167)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivat
or.java:335) at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:2
73) at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:1
29) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at org.eclipse.core.launcher.Main.basicRun(Main.java:185)
at org.eclipse.core.launcher.Main.run(Main.java:704)
at org.eclipse.core.launcher.Main.main(Main.java:688)
Re: Problems with PDF [message #63236 is a reply to message #62688] Mon, 01 August 2005 07:22 Go to previous message
I also seem to have this exception the first time I try to run a report.
Is something not being initialised the first time round?
Nathan
Peter Bars wrote:
> Hallo,
> at
> va:221) at
> ) at
> at
> utor.java:200) at
> Task.java:152) at
> tAction.java:38) at
> 2) at
> onItem.java:866) at
> at
> at
> at
> 4) at
> at
> at
> or.java:335) at
> 73) at
Previous Topic:Problem in creating a basic chart
Next Topic:Problems creating a basic pie chart
Current Time: Wed Jul 16 02:00:32 EDT 2025
Powered by FUDForum. Page generated in 0.41129 seconds
