Q: Can JDT API be used headless? [message #5600] |
Fri, 25 April 2003 13:37  |
I'm using the JDT API heavily in my metrics plugin, but now
would like to calculate the metrics as part of an automated
nightly build - from ant. Can the JDT API be used this way?
How does one find/access the workspace programmatically
in this scenario, if at all possible?
Frank Sauer
Re: Q: Can JDT API be used headless? [message #54408 is a reply to message #5629] |
Wed, 11 June 2003 07:13  |
Originally posted by: dbexternal.comcast.net
Jed:
Any chance you would be will to provide a snippet of code detailing how
you accomplished running the JDT core headless?
Thanks, Dennis
Jed Anderson wrote:
> Frank,
> I have written a tool that uses the JDT core headless, so I know that is
> possible.
> If you use just org.eclipse.jdt.core and org.eclipse.core.resources, you
> can run headless and still access the workspace through normal means
> (i.e. ResourcesPlugin.getWorkspace()).
> jkca
> > Regards,
> > Frank Sauer
FUDForum. Page generated in 0.05386 seconds
