Re: [MWE] Is there a way to prevent to refresh the *entire* workspace after the run of a workflow? [message #621386] |
Thu, 24 September 2009 07:39 |
Sven Efftinge![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=sven.efftinge%40itemis.de) Messages: 1823 Registered: July 2009 |
Hi Michael,
as this is related to the MWE launcher I added the emft newsgroup.
the workspace refresh is hard coded so you cannot deactivate it in the
launch configuration. What you could do is to start the workflow using a
plain Java Application launch configuration.
All you need to do is start 'org.eclipse.emf.mwe.core.WorkflowRunner'
and pass the workflow file as the first parameter.
Note, that usually a refresh is only resources consuming if many files
are out of sync, i.e. have changed externally. You could try to minimize
this by avoid overwriting existing files if nothing has changed.
Sven
Michael Scharf schrieb:
> I have a huge workspace (>30.000 files).
> A refresh of the workspace can take up to 10 minutes
> (if the files are not in the disc cache because windows
> in not really good at that)! Even the second time it
> takes 15 seconds.
> Is there a way to only refresh the projects that
> have changed?
> I understand that it is difficult to figure out
> what has changed, but it would be great to
> specify in the workflow what to update.
> Michael
Need professional support for Eclipse Modeling?
Go visit: http://xtext.itemis.com
FUDForum. Page generated in 0.03031 seconds
