Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Final weird packaging problem hopefully
Final weird packaging problem hopefully [message #621128] Tue, 14 July 2009 07:03
Been a bit of a slog but on the last leg hopefully.
My plugin is packaged and exported.
If I use a clean Amalgam 1.0M7 build (Mac) and I install
MWE, M2T, and EMF/XSD followed by my plugin it works great.
(I downloaded a fresh amalgam and plugins)
but ....
If I use Galileo, it doesn't produce any file output no error
(modeling version)
If I ensure that the above has MWE, M2T, EMF/XSD installed first,
it still doesn't produce output (on Galileo). Everything else seems
to work including model creation etc.
But if I import my projects from Amalgam to Galileo I can run the
workflow from the workbench by using the run config.
If I export the plugin directly into the host repository it still fails
Am I doing something silly? Any suggestions?
regards
Steve
Previous Topic:EMF Compare fails
Next Topic:Final weird packaging problem hopefully
Current Time: Sat Jul 12 11:37:53 EDT 2025
Powered by FUDForum. Page generated in 0.03392 seconds
