no output from workflow called by java - action - debug action calls? [message #621120] |
Sun, 12 July 2009 19:21 |
Bill Hinge Messages: 156 Registered: July 2009 |
I'm on the last leg - packaging my plugin
I have a plugin which is trying to run a mwe workflow
(the workflow runs in project explorer right click as expected)
When I export my plugin and load it, then run my action, the action
is called as evidenced by org.eclipse.jface.dialogs placed in my code.
I have checked that the workflow urls I am using point to resources
actually exist but I don't seem to be getting any output. Normally it
takes about 11 to 23 secs to run the workflow but through java it just
skips through
I'm selecting a gmf output file as my model file.
This is how I am calling my action (no exceptions thrown)
ngossModel is my GMF model file
Is there any better way of getting debug info from something called
from an action. The only way I can check things is via placing jface
dialogs in my code. Not sure how to use debugger on an action if
possible? (no debug or console)
regards
Steve
public void run(IAction action) {
try {
EObject source = getInput();
if (source == null) {
String title = Messages.RunTransformationAction_title;
String message = Messages.RunTransformationAction_message;
MessageDialog.openInformation(getShell(), title, NLS.bind(message,
file.getFullPath()));
} else {
URL url2 = new
URL(" platform:/plugin/org.tmf.businessService.ui/templates/busine ssServiceDemoWorkflow.mwe ");
org.eclipse.jface.dialogs.MessageDialog.openInformation(getS hell(),
"Debug", "Running workflow := " + url2.toString() );
URL url = FileLocator.toFileURL(url2);
URL url3 = new URL("platform:/plugin/org.tmf.businessService.ui");
URL url4 = FileLocator.toFileURL(url3);
"Step2", "url := " + url4.toString() );
Map<String, String> properties = new HashMap<String, String>();
Map<String, String> slotcontents = new HashMap<String, String>();
properties.put("ngossModel",
URI.createPlatformResourceURI(file.getFullPath().toString(),
true).toString());
properties.put("src-gen", Platform.getLocation().toOSString() +
file.getParent().getFullPath());
properties.put("project_home", url4.toString());
new WorkflowRunner().run(url.getPath(), new NullProgressMonitor(),
properties, slotcontents);
file.getParent().refreshLocal(IResource.DEPTH_ONE, new
org.eclipse.core.runtime.NullProgressMonitor());
"Done", "Transform run on := " + file.getName()
+ " output produced in location : " +
Platform.getLocation().toOSString() + file.getParent().getFullPath() );
} catch (Exception ex) {
handleError(ex);
Here is my workflow - it works if run on the workbench using 'run as'
I'm not seeing any console output
<?xml version="1.0" encoding="utf-8" ?>
<workflow>
<property name="workspace_loc" value="./" />
<property name="project_home" value="../org.tmf.businessService.ui" />
<property name="ngossModel" value="templates/default16.ngoss" />
<property name="src-gen" value="../org.tmf.businessService.ui/src-gen"/>
<property name="out" value="out" />
<bean class="org.eclipse.emf.mwe.utils.StandaloneSetup">
<platformUri value="../" />
<RegisterEcoreFile value="${project_home}/model/contract.ecore"/>
<RegisterEcoreFile value="${project_home}/model/sla.ecore"/>
<RegisterEcoreFile value="${project_home}/model/informationModel.ecore"/>
<RegisterEcoreFile value="${project_home}/model/ngoss.ecore"/>
<RegisterEcoreFile value="${project_home}/model/tam.ecore"/>
<RegisterEcoreFile value="${project_home}/model/sbvr.ecore"/>
<registerGeneratedEPackage value="org.eclipse.uml2.uml.UMLPackage"/>
value="org.eclipse.gmf.runtime.notation.NotationPackage"/>
</bean>
<component class="org.eclipse.emf.mwe.utils.DirectoryCleaner"
directory="${project_home}/src-gen"/>
<component class="org.eclipse.emf.mwe.utils.Reader">
<firstElementOnly value="true" />
<modelSlot value="ngossModel"/>
<uri value="${ngossModel}"/>
</component>
<component class="org.eclipse.xpand2.Generator" id="ngossGenerate">
<metaModel id="mm"
class="org.eclipse.xtend.typesystem.emf.EmfRegistryMetaModel "/>
<fileEncoding value="UTF-8"/>
<expand value="Demos::Main FOR ngossModel" />
<outlet path="${src-gen}">
<!-- postprocessor output configuration -->
</outlet>
</component>
</workflow>
FUDForum. Page generated in 0.02917 seconds
