Home » Eclipse Projects » Plugin Development Environment (PDE) » ERROR: ‘Not implmented in this version’ With xml Transform.
ERROR: ‘Not implmented in this version’ With xml Transform. [message #62578] Fri, 22 May 2009 01:42
Recently i upgraded java version from 1.5 to 1.6.
I Use eclispe 3.4.
I use Xml transformer to read the contents of the file.
Now when i run my rcp – product it give error when
Source source = new DOMSource(MyDocument);
StreamResult result = new StreamResult(newStringWriter());
Transformer xformer = TransformerFactory.newInstance().newTransformer();
xformer.transform(source, result);
String xmlString = result.getWriter().toString();
Its gives me
javax.xml.transform.TransformerException: org.w3c.dom.DOMException: Not
implmented in this version at
com.sun.org.apache.xalan.internal.xsltc.trax.TransformerImpl .transform(TransformerImpl.java:717)
com.sun.org.apache.xalan.internal.xsltc.trax.TransformerImpl .transform(TransformerImpl.java:313)
Please help..
I use javax.xml_1.3.4.v200806030440.jar of eclipse.
Is there way where i can i ask to run with this rather than jre.
Govind R
Previous Topic:PDE Build, SVN and jar qualifiers
Next Topic:ERROR: ‘Not implmented in this version’ With xml Transform.
Current Time: Mon May 12 09:54:51 EDT 2025
Powered by FUDForum. Page generated in 0.18119 seconds
