Bug in displaying structure contents with debugger? [message #62568] |
Wed, 11 May 2005 05:10  |
Originally posted by: sxxx.xxx.com
Running Eclipse platform 3.1M6 and Eclipse CDT 3.0.0M6 I can't examine the
contents of structures.
If I enable the structure in the Variable View, I can see the elements
which the structure contains. However, If I then enable an element of a
structure, in its name I get:
<!cdi.VariableManager.Unknown_variable_object!>
I can never actually see the value of the element.
Is this a bug or have I not set my environment up quite right?
Thanks in advance,
Stephan
Re: Bug in displaying structure contents with debugger? [message #63146 is a reply to message #62568] |
Wed, 11 May 2005 16:19  |
Looks to be a NLS support problem from CDT
A internationalized String is missing from their support
I would check the bugzilla and log if not already reported.
HTH
Darins
"Stephan Gueorguiev" <sxxx@xxx.com> wrote in message
news:a2de4fe0d0081b06576aa086ea4b4fd9$1@www.eclipse.org...
> Thanks in advance,
> Stephan
FUDForum. Page generated in 0.08039 seconds
