Home » Modeling » TMF (Xtext) » [Xtext] Ecore Metamodel Question
[Xtext] Ecore Metamodel Question [message #62540] Wed, 22 July 2009 09:02 Go to next message
Originally posted by: oba.informatik.uni-kiel.de
Hi all,
both of the following grammars yield to the same Ecore Metamodel:
GRAMMAR 1
Model :
(elements+=DataType)+
DataType:
'datatype' name=ID ';'?
GRAMMAR 2
Model :
(elements+=DataType)*
DataType:
But I would expect that in the first one, the lower bound of the
reference "elements" would be set to 1. This is not the case, can some
one tell me, what I am overseeing/misunderstanding?
Thanks a lot!
mN
Re: [Xtext] Ecore Metamodel Question [message #62565 is a reply to message #62540] Wed, 22 July 2009 09:11 Go to previous messageGo to next message
Hello mN,
what's wrong?
You expect in grammar 1 at least one Datatype?
Why you dont use a definition like (see below):
Model:
head = DataType (tails += DataType)*;
DataType:
'datatype' name = ID ';';
Ciao, Micha
--- Original-Nachricht ---
Absender: myName
Datum: 22.07.2009 15:02
> Hi all,
> GRAMMAR 1
> Model :
> DataType:
> GRAMMAR 2
> Model :
> DataType:
> Thanks a lot!
> mN
Re: [Xtext] Ecore Metamodel Question [message #62660 is a reply to message #62565] Wed, 22 July 2009 09:20 Go to previous messageGo to next message
Michael Burkhardt wrote:
> Hello mN,
hi, thanks for your reply, Micha
> what's wrong?
> Model:
Well, this is what the first rule ( Model: (elements+=DataType)+; )
does, isn't it? Except naming the first element separately.
I do not need this rule at least not in this form but I want to
understand why the generator does not set the lower bound of the
reference "elements" in the generated Ecore model to 1 when my rule says
that it should contain at least one "datatype".
mN
Re: [Xtext] Ecore Metamodel Question [message #62683 is a reply to message #62540] Wed, 22 July 2009 09:22 Go to previous messageGo to next message
Hi mN,
its intentional. We didn't want to introduce to many constraints in the
metamodel. However, there is an open issue and you may want to comment
it: https://bugs.eclipse.org/bugs/show_bug.cgi?id=266830
If you want strict constraints in your metamodel, you can use a post
processing step. Have a look at the docs to learn about it.
Sebastian
Need professional support for Eclipse Modeling?
Go visit: http://xtext.itemis.com
Am 22.07.2009 15:02 Uhr, schrieb myName:
> Hi all,
> GRAMMAR 1
> Model :
> DataType:
> GRAMMAR 2
> Model :
> DataType:
> Thanks a lot!
> mN
Re: [Xtext] Ecore Metamodel Question [message #62707 is a reply to message #62683] Wed, 22 July 2009 09:27 Go to previous message
Sebastian Zarnekow wrote:
> Hi mN,
> Sebastian
oh, I see. Thanks Sebastian.
Previous Topic:[Xtext] MWE problem: Allowing backtracing in AntlrDelegating fragment yields to error
Next Topic:Xtext formatter
Current Time: Thu May 08 15:26:02 EDT 2025
Powered by FUDForum. Page generated in 0.08409 seconds
