Home » Archived » Test and Performance Tools Platform (TPTP) » Help!What is the work around for open file in AGR?
Help!What is the work around for open file in AGR? [message #62535] Thu, 30 March 2006 03:42 Go to next message
I'm an automation tester working in IBM China Lab.
I want to use AGR to test our eclipse plug-in automaticly.
But I have encounter such problem.
I click the menu File-Open File
And an open file dialog pops up.
AGR does not support this dialog.
And what is the work around?
A sample will give me great help.
Best Regards
Simoom Chen
Re: Help!What is the work around for open file in AGR? [message #63196 is a reply to message #62535] Sat, 01 April 2006 01:14 Go to previous message
Yes, AGR doesn't support native dialogs.
As a workaround, you can have the file imported into your workspace before
opening it. The following section of the userguide describes how you can
import a resource into your workspace using a relative path:
http://www.eclipse.org/tptp/test/documents/userguides/Intro- Auto-GUI-4-2-0.html#2.2.5
"simoom" <hugulas@gmail.com> wrote in message
news:e0g5es$org$1@utils.eclipse.org...
> Best Regards
> Simoom Chen
Previous Topic:Hyades and Weblogic 6.1
Next Topic:Profiling Data File
Current Time: Mon Jul 21 21:33:08 EDT 2025
Powered by FUDForum. Page generated in 0.25830 seconds
