Home » Language IDEs » ServerTools (WTP) » WSDL model APIs
WSDL model APIs [message #62530] Thu, 06 January 2005 17:35 Go to next message
Originally posted by: not_real.not_real.com
I was wondering if the WSDL model API and implementation (found in
org.eclipse.wst.wsdl) will continue to be offered as public API for use
by third party extensions. I'm trying to decide whether or not I should
depend on it for WSDL manipulation. Can anyone shed light on this?
Thanks.
Re: WSDL model APIs [message #62600 is a reply to message #62530] Fri, 07 January 2005 00:21 Go to previous messageGo to next message
For those reading this, org.eclipse.wst.wsdl contains an EMF WSDL 1.1
model.
The API for the WTP project should not be considered final at this point
as it may change over the next couple milestones. The WTP project does aim
to provide reusable components to the Eclipse commmunity so you will be
able to depend on the WSDL model API once it is finalized. Can you post a
summary of how you would like to use the model in order to help the
developers decide what should be exposed in the API?
Alternatively, if you're looking for a lightweight WSDL model you may want
to take a look at WSDL4J. See
http://www-124.ibm.com/developerworks/projects/wsdl4j/. There are plugins
in the WTP project which rely on this model for
performance/simplicity/requirements reasons.
Lawrence
Re: WSDL model APIs [message #63070 is a reply to message #62600] Fri, 07 January 2005 12:25 Go to previous messageGo to next message
Thank you for your reply. I would like to use the WSDL model in order
to examine and possibly manipulate WSDLs. The features I am interested
in in particular are:
1. Resolution of references, including cross document references (ie.
operation.getInput() returns message instance and not a QName).
2. Extensibility -- I would like to extend the model with a few WSDL
extensions.
3. Fine grained events when WSDLs change(might be able to live without
these).
The WebTools WSDL model seem to take care of all of the above except for
possibly #2; I need to dig deeper to figure out if/how this can be done.
Do you have a rough idea of when the WSDL model API will be finalized?
Do you anticipate that it will change much?
Thanks!
> model.
> Lawrence
Re: WSDL model APIs [message #63106 is a reply to message #63070] Fri, 07 January 2005 12:47 Go to previous messageGo to next message
> extensions.
> these).
The WSDL model supports all three features that you list above. You'll
notice that we provide SOAP and HTTP extensibility models that should
demonstrate #2. You may be interested in knowing that for #1 we also
provide cross document references to XML Schema objects (to the eclipse
XSD model).
I don't anticipate too much change. Having folks use our model would help
us understand what we need to expose as API (currently much of the code is
marked 'internal' ... and we assume you won't need to touch that... but
we're probably wrong in some cases). So I'd ecourage you to start using
it. I'm guessing we'll be ready to finalize the API some time in March
(depending on how much feed back we've received).
Thanks for your interest. Please continue to post questions, comments and
(of course) bug reports.
Re: WSDL model APIs [message #63265 is a reply to message #63106] Fri, 07 January 2005 15:33 Go to previous message
Yes, the XML schema references are very cool, and something that I am
very interested in using. Thanks for your response!
>> interested in in particular are:
>> extensions.
>> these).
>> for possibly #2; I need to dig deeper to figure out if/how this can be
>> done.
> XSD model).
> help us understand what we need to expose as API (currently much of the
> code is marked 'internal' ... and we assume you won't need to touch
> that... but we're probably wrong in some cases). So I'd ecourage you
> to start using it. I'm guessing we'll be ready to finalize the API some
> time in March (depending on how much feed back we've received).
> and (of course) bug reports.
Previous Topic:XML Templates global or DTD specific?
Next Topic:Bugzilla voting
Current Time: Sun Aug 31 18:40:40 EDT 2025
Powered by FUDForum. Page generated in 0.03113 seconds
