Home » Archived » M2M (model-to-model transformation) » Adding operation to ATL VM
Adding operation to ATL VM [message #62514] Wed, 26 September 2007 04:23 Go to next message
Originally posted by: eric.maes.thalesgroup.com
Are there some limitations adding operations to the ATL VM ?
What are the consequences of addind a huge amount of operations ?
I'd like to add about thousand simple operations to the ATL VM. Does
anyone has tried such an experience and can tell me about his feeling on
ATL's possibilities and behavior ?
Re: [ATL] Adding operation to ATL VM [message #62594 is a reply to message #62514] Wed, 26 September 2007 05:37 Go to previous messageGo to next message
Hmm, perhaps this kind of information is better posted on the
development mailing list: m2m-dev@eclipse.org
I'll add it in CC...
> Regards
I assume you mean adding VM instructions? I found that the biggest
performance factor in the standard ATL VM is the creation of stackframes
with every method invocation. Interpreting instructions only plays a
small part.
Of course, there are currently only 22 instructions, which are
interpreted through a big if-then statement inside a while loop in the
ASMOperation class. I'm afraid that this solution does not scale up to
1000 instructions.
You may try to refactor the current approach to a more object-oriented
approach with an interpreter pattern. You can extend the ASMInstruction
and ASMInstructionWithOperand classes with new subclasses for each
instruction (in their own "instr" package, probably).
The behaviour for each instruction can be implemented in the instruction
class itself and ASMOperation only needs to call instr.exec(frame).
Instruction parsing is then done only once when the asm file is loaded.
ASMInstruction objects are created by the ASMEmitter class. Probably a
good idea to add an ASMInstructionFactory class that creates the correct
object for each mnemonic.
This may be a lot of work, but you probably need to do this if you don't
want the runtime transformation performance to become worse.
Dennis
Re: [ATL] Adding operation to ATL VM [message #62618 is a reply to message #62594] Wed, 26 September 2007 05:47 Go to previous messageGo to next message
Originally posted by: mikael.barbero.gmail.com
From my point of view, i understood that Eric wanted to add native
operations (i.e. direct call to java method).
I don't see any point against this idea. You'll probably better have to
create your own model handler with your own methods rather than changing
one of the already existing ones (but you can inherit from it).
As those method are statically registered, it should not have a big
impact on the VM performance (maybe on the class loading time).
Mikael
>> on ATL's possibilities and behavior ?
>> Thanks,
>> Regards
> small part.
> 1000 instructions.
> Dennis
Mikaël Barbero - PhD Candidate
ATLAS Group (INRIA & LINA) - University of Nantes
2, rue de la Houssinière
44322 Nantes Cedex 3 - France
tel. +33 2 51 12 58 08 /\ cell.+33 6 07 63 19 00
email: Mikael.Barbero@{gmail.com, univ-nantes.fr}
http://www.sciences.univ-nantes.fr/lina/atl/
Re: [ATL] Adding operation to ATL VM [message #62642 is a reply to message #62618] Wed, 26 September 2007 06:23 Go to previous messageGo to next message
Ah, ok. Then it depends on whether you can add to your meta-model.
Native operations on EClasses are already supported: operations are
declared in Ecore models and implemented in the generated code.
Performance impact: EMF operations are invoked through Java reflection.
If you cannot extend your meta-model's EClasses, using your own model
handler is indeed the best solution. The ASMModelElement subclass for
each model handler (e.g. ASMEMFModelElement for EMF model handler) will
handle all method invocations. You can add code to your own
ASMModelElement subclass to handle special operations, without affecting
the ATL VM code.
Dennis
> Mikael
>>> Thanks,
>>> Regards
>> stackframes with every method invocation. Interpreting instructions
>> only plays a small part.
>> 1000 instructions.
>> ASMInstruction and ASMInstructionWithOperand classes with new
>> subclasses for each instruction (in their own "instr" package, probably).
>> instruction class itself and ASMOperation only needs to call
>> instr.exec(frame). Instruction parsing is then done only once when the
>> asm file is loaded. ASMInstruction objects are created by the
>> ASMEmitter class. Probably a good idea to add an ASMInstructionFactory
>> class that creates the correct object for each mnemonic.
>> don't want the runtime transformation performance to become worse.
>> Regards,
>> Dennis
Re: [ATL] Adding operation to ATL VM [message #62666 is a reply to message #62642] Wed, 26 September 2007 07:07 Go to previous message
Yes, I am speaking about adding native operations.
Thanks for your answers.
Previous Topic:Re: Help with .ecore files, please
Next Topic:[ATL]UML Models and Java Models
Current Time: Sun Aug 31 15:04:51 EDT 2025
Powered by FUDForum. Page generated in 0.04443 seconds
