Home » Eclipse Projects » Eclipse Platform » Tile Editors in editorarea programmatically
Tile Editors in editorarea programmatically [message #62480] Wed, 04 June 2003 11:42 Go to next message
I know we can tile the editor working area manually by using drag and
drop.But is it possible to set the tile as the default layout of the editor
area programmatically, so that whenever two editors are opened in the
editor area,we will be able to see the two editors in tiled layout.
MorPheus
Re: Tile Editors in editorarea programmatically [message #62538 is a reply to message #62480] Wed, 04 June 2003 11:49 Go to previous messageGo to next message
Originally posted by: simon.ibm.oti.lab
no
Simon :-)
"MorPheus" <rgurupackiam@selectica.com> wrote in message
news:bbl417$6nr$1@rogue.oti.com...
editor
> MorPheus
Re: Tile Editors in editorarea programmatically [message #62562 is a reply to message #62538] Wed, 04 June 2003 12:04 Go to previous messageGo to next message
Hi Simon,
Hi Simon,
I think today is my unlucky day. I got two negative responses from you. I
wonder why the eclipse doesn't provide API for programmatically setting the
layout of the editor that would change the default stacked layout to tiled
layout because I feel this as restriction imposed on the developers. I also
feel the functionality is really needed because we cannot force the end user
or assume the end user will be knowing how to set the editor layout
manually. They should be able to get the desired layout by click of a
button. Need your comments and suggestions
MorPheus
"Simon Arsenault" <simon@ibm.oti.lab> wrote in message
news:bbl4dh$74j$1@rogue.oti.com...
> no
> Simon :-)
> > Hi,
and
> editor
> > MorPheus
Re: Tile Editors in editorarea programmatically [message #62701 is a reply to message #62562] Wed, 04 June 2003 13:53 Go to previous message
"MorPheus" <rgurupackiam@selectica.com> wrote: "I wonder why the eclipse
doesn't provide API for"
The same reason(s) you give a client of your application when the client ask
"how come you did not include feature ABC?". There are many things included
in eclipse, and many more missing too. Its a question of time, priority,
complexity, value, etc.
You can open an enhancement bug report against Platform - UI for it to be
considered. Or maybe your company is willing to commit a number of
developers to add this feature in and have it included in Eclipse. If so,
please post a message in the platform-ui-dev mailing list.
Simon :-)
news:bbl5ad$84b$1@rogue.oti.com...
> Hi Simon,
> Hi Simon,
the
also
user
> MorPheus
> > no
> > Simon :-)
> > > Hi,
> and
> > editor
> > > MorPheus
Previous Topic:Branding Eclipse
Next Topic:What is the proper way to build the Eclipse jars?
Current Time: Fri Jul 25 23:24:38 EDT 2025
Powered by FUDForum. Page generated in 0.03215 seconds
