Home » Modeling » TMF (Xtext) » [Xtext] MWE problem: Allowing backtracing in AntlrDelegating fragment yields to error
[Xtext] MWE problem: Allowing backtracing in AntlrDelegating fragment yields to error [message #62473] Wed, 22 July 2009 08:39 Go to next message
Originally posted by: oba.informatik.uni-kiel.de
thanks for your replies in advance. Here is my problem:
I have set the backtrace option of my AntLRDelegating fragment in the
GenerateMyDSL file of my grammar "MyDSL" according to the instructions,
given here:
http://wiki.eclipse.org/Xtext/FAQ#Why_do_I_get_warnings_like _.22warning.28200.29:_InternalFoo.g:42:3:_Decision_can_match _....22_when_running_the_generator.C2.A0.3F
When I now try and run the workflow, this is what it says to me:
ERROR eclipse.emf.mwe.core.WorkflowRunner - [ERROR]: No getter or adder
method for property 'options' in clazz
'org.eclipse.xtext.generator.AntlrDelegatingFragment' found. Forgot to
customize?(Element: bean options in
/home/oba/Desktop/workspaces/KIELER_KIT_Galileo/org.xtext.ex ample.textualsc/src/org/xtext/example/GenerateTSCL.mwe:33;
Reported by: -UNKNOWN-)
Aprreciate any help!
mN
Re: [Xtext] MWE problem: Allowing backtracing in AntlrDelegating fragment yields to error [message #62589 is a reply to message #62473] Wed, 22 July 2009 09:16 Go to previous messageGo to next message
Hi Ilyas,
the FAQ contains a bug. You have to use the XtextAntlrGeneratorFragment
directly if you want to use backtracking. Please change the classname in
your workflow to
de.itemis.xtext.antlr.XtextAntlrGeneratorFragment.
Also note that you'll have to enable backtracking for the
XtextAntlrUIGeneratorFragment too.
I'll update the FAQ.
Sebastian
Need professional support for Eclipse Modeling?
Go visit: http://xtext.itemis.com
Am 22.07.2009 14:39 Uhr, schrieb myName:
> given here:
> Thanks
> mN
Re: [Xtext] MWE problem: Allowing backtracing in AntlrDelegating fragment yields to error [message #62613 is a reply to message #62589] Wed, 22 July 2009 09:18 Go to previous message
Sorry I've been confused, you are not Ilyas, but mN ?
Am 22.07.2009 15:16 Uhr, schrieb Sebastian Zarnekow:
> Hi Ilyas,
> your workflow to
> Sebastian
Previous Topic:Reading Xtext model file in Java Apps
Next Topic:[Xtext] Ecore Metamodel Question
Current Time: Sun Jul 27 07:06:08 EDT 2025
Powered by FUDForum. Page generated in 0.03184 seconds
