Home » Modeling » GMF (Graphical Modeling Framework) » Associate an object to a connection as it's attribute
Associate an object to a connection as it's attribute [message #62472] Sat, 14 October 2006 13:07 Go to next message
Originally posted by: greenl.mot.com
I want to map a link between an object to a Connection so that once the link
is created, the object is associated to the Connection as a EReference. I
set up the "Target Feature" as the proper EReference of the link class.
However I found I actuall was not able to creat the link between the object
and the Connection at run time, even the mouse hover on the connection and
the target object, the forbidden icon still visible.
Anybody has any idea?
Green
Re: Associate an object to a connection as it's attribute [message #63838 is a reply to message #62472] Tue, 17 October 2006 07:08 Go to previous message
Perhaps, EReference.eType is not compatible with the target under the mouse?
Artem
"Green Law" <greenl@mot.com> wrote in message
news:egr5ke$g1g$1@utils.eclipse.org...
> link is created, the object is associated to the Connection as a
> EReference. I set up the "Target Feature" as the proper EReference of the
> link class. However I found I actuall was not able to creat the link
> between the object and the Connection at run time, even the mouse hover on
> the connection and the target object, the forbidden icon still visible.
> Green
Previous Topic:Label not associated with subject node
Next Topic:Transparent SVG file as a figure
Current Time: Sat Jul 12 21:52:19 EDT 2025
Powered by FUDForum. Page generated in 0.19927 seconds
