Home » Archived » Visual Editor (VE) » VE do not work with Eclipse fpr OSX
VE do not work with Eclipse fpr OSX [message #5575] Wed, 26 November 2003 04:24 Go to next message
Originally posted by: d.sommer.crosssoft.de
Hello all,
I work with Eclipse 2.1.1 on OSX and want to install the VE Module. But
it dont work. Can anyone
help me?
best regards
Dirk
Re: VE do not work with Eclipse fpr OSX [message #7378 is a reply to message #5575] Mon, 01 December 2003 15:09 Go to previous messageGo to next message
Originally posted by: richkulp.NO.SPAM.us.ibm.com
We haven't tested it on OSX, but it should work. First you need to use
the correct pre-reqs. It requires Eclipse 2.1.2, not 2.1.1, and you will
need the GEF 2.1.2 and EMF 1.1.1. These are listed as pre-reqs on the
build download page.
Thanks, Rich Kulp
Re: VE do not work with Eclipse fpr OSX [message #7400 is a reply to message #7378] Mon, 01 December 2003 15:55 Go to previous messageGo to next message
Originally posted by: wade.eccentrichosting.net
Also note that VE does not work with the 3.0* you need eclipse 2.1.2
wade
Re: VE do not work with Eclipse fpr OSX [message #7409 is a reply to message #7400] Mon, 01 December 2003 16:05 Go to previous messageGo to next message
However, I was just pointed to a bugzilla bug that indicates we don't
support OSX. So your milage may vary.
Thanks, Rich Kulp
Re: VE do not work with Eclipse fpr OSX [message #77522 is a reply to message #7409] Mon, 17 January 2005 11:57 Go to previous messageGo to next message
Originally posted by: giribet.daniel.edu.upf
Are there any plans of adding support for MacOSX anytime?
I use Eclipse daily my MacOSX and whenever I have to use any other
platform I happily update from CVS and continue working. The one thing I
cannot work in this way is VE. Is it a problem with the underlying
frameworks (GEF)? If so, I will forward this to the appropriate group
(any improvements on this front would be inherited by the VE project). Is
it a problem of target marketshare or lack of resources (eg. testing
MacOSX box)?
I remember back in the 2.x days that I nearly got VE running (apart from
some mainly drawing glitches), that was an indication that there were not
fundamental technical obstacles in supporting OSX (I might be wrong
though).
Thx,
Daniel Giribet Farr
Re: VE do not work with Eclipse fpr OSX [message #77552 is a reply to message #77522] Mon, 17 January 2005 12:05 Go to previous message
Oops, just checked out 'https://bugs.eclipse.org/bugs/show_bug.cgi?id=
47716' and there seems to be a lot of progress since I last checked it
out. Great job.
I can't help noticing the slowness problem though (slow G4 user here
^_^).
thx.
Daniel Giribet <giribet.daniel@edu.upf> wrote in
news:Xns95E1B69C4C4Ddanielgiribetupfedu@206.191.52.34:
> I cannot work in this way is VE. Is it a problem with the underlying
> Is it a problem of target marketshare or lack of resources (eg.
> testing MacOSX box)?
> from some mainly drawing glitches), that was an indication that there
> were not fundamental technical obstacles in supporting OSX (I might be
> wrong though).
> Thx,
Daniel Giribet Farr
Re: VE do not work with Eclipse fpr OSX [message #571023 is a reply to message #5575] Mon, 01 December 2003 15:09 Go to previous message
Thanks, Rich Kulp
Re: VE do not work with Eclipse fpr OSX [message #571110 is a reply to message #7378] Mon, 01 December 2003 15:55 Go to previous message
wade
Re: VE do not work with Eclipse fpr OSX [message #571148 is a reply to message #7400] Mon, 01 December 2003 16:05 Go to previous message
Thanks, Rich Kulp
Re: VE do not work with Eclipse fpr OSX [message #604649 is a reply to message #7409] Mon, 17 January 2005 11:57 Go to previous message
MacOSX box)?
though).
Thx,
Daniel Giribet Farr
Re: VE do not work with Eclipse fpr OSX [message #604658 is a reply to message #77522] Mon, 17 January 2005 12:05 Go to previous message
out. Great job.
^_^).
thx.
> wrong though).
> Thx,
Daniel Giribet Farr
Previous Topic:Using VE - it freezes
Next Topic:SWT in VE: palette objs just little boxes
Current Time: Thu Jul 24 21:11:38 EDT 2025
Powered by FUDForum. Page generated in 0.04717 seconds
