Home » Language IDEs » AspectJ » Multi-dirrectory output
Multi-dirrectory output [message #62424] Fri, 03 March 2006 08:22 Go to next message
Originally posted by: a.shneyderman.gmail.com
In my project I have two source folders main/java & test/java. When I
write an abstract object that only needs a pointcut in its concrete
implementation, I would write it inlined in my test. This means that the
test directory does have an aspect but I do not want to package it. While
main/java source' output is the one I want to take and package.
AJDT (and I suppose it is an ajc fault) has a problem with outputing
compiled code to 2 separate output directories, therefore does output
classes into the default directory, which cause me a lot of pain.
Is there a work around this limitation or maybe a solution that I
overlooked?
alex.
Re: Multi-dirrectory output [message #62448 is a reply to message #62424] Fri, 03 March 2006 13:21 Go to previous message
> overlooked?
Yes, the limitation is covered by bug 101983.
Could you move your test folder out into a separate project?
Matt.
Re: Multi-dirrectory output [message #592424 is a reply to message #62424] Fri, 03 March 2006 13:21 Go to previous message
> overlooked?
Matt.
Previous Topic:Multi-dirrectory output
Next Topic:J2ME
Current Time: Fri Jul 18 07:27:07 EDT 2025
Powered by FUDForum. Page generated in 0.27891 seconds
