Home » Language IDEs » AspectJ » cross-project aspects?
cross-project aspects? [message #62304] Tue, 28 February 2006 02:30 Go to next message
Originally posted by: yoduderoo.netscape.net
Should it be possible to define an Aspect in one project which weaves
into code from another?
For example, I create an AspectJ project A. I convert an existing Java
project, B, by right-clicking the Java project and performing relevant
action. I create an aspect, TestAspect, in project A which defines a
pointcut on a Java source in B. It compiles, but there are no markers.
If I move the source from B into aspect project A, the markers appear.
Can I have a separate project with my aspects which weave into other
projects?
Versions:
AJDT 1.2.1, Build 20051220151004, AspectJ version: 1.5.0
IBM RSA 6.0 (Eclipse 3.0)
JRE 1.4.2
Thanks, y
Re: cross-project aspects? [message #62328 is a reply to message #62304] Tue, 28 February 2006 05:26 Go to previous messageGo to next message
Yes, it's possible.
If you make project B an AspectJ project (you don't have to have any
aspects in it!), you can add project A to the "aspect path" of
project B (under the project's properties pages). The weaving will then
take place in project A. Alternatively, if you want to keep project B as a
Java project, you could do the weaving in project A, by setting the
"in path" to be the output folder of project B.
Hope that helps,
Matt.
On Tue, 28 Feb 2006 08:30:52 +0100, Yodude wrote:
> projects?
> Versions:
> JRE 1.4.2
> Thanks, y
Re: cross-project aspects? [message #62761 is a reply to message #62328] Wed, 15 March 2006 10:21 Go to previous messageGo to next message
"Matt Chapman" <mpchapman@gmail.com> wrote in message
news:pan.2006.02.28.10.26.57.753030@gmail.com...
How do I add project A to the "aspect path" of project B? I see that I
can add JARs, External JARs, Variables and Class Folders, but I don't see a
way to add projects.
- Oliver
Re: cross-project aspects? [message #62782 is a reply to message #62761] Wed, 15 March 2006 10:41 Go to previous messageGo to next message
Use the Class Folder option and add the output folder (usually the "bin"
directory) of the other project.
Maybe we should add an explicit control to add projects - it would make it
a bit clearer.
Matt.
Re: cross-project aspects? [message #592376 is a reply to message #62304] Tue, 28 February 2006 05:26 Go to previous messageGo to next message
Yes, it's possible.
Hope that helps,
Matt.
> projects?
> Versions:
> JRE 1.4.2
> Thanks, y
Re: cross-project aspects? [message #592554 is a reply to message #62328] Wed, 15 March 2006 10:21 Go to previous messageGo to next message
- Oliver
Re: cross-project aspects? [message #592563 is a reply to message #62761] Wed, 15 March 2006 10:41 Go to previous messageGo to next message
a bit clearer.
Matt.
Re: cross-project aspects? [message #1738890 is a reply to message #62761] Mon, 25 July 2016 13:36 Go to previous messageGo to next message
I have spent all day trying ways to keep my aspects in one project, but used in another without success. Including the solution given here.
I want the aspects in one project to be used in a dynamic web project.
I am using Eclipse J2ee Neon and the latest AJDT tools (45) on OSX Yosemite.
I can use the aspect and I can use the dynamic web project. Each works separately but the aspect is not entered when I try to use them together.
I attach zip files of both projects
Re: cross-project aspects? [message #1739474 is a reply to message #1738890] Tue, 02 August 2016 05:02 Go to previous message
Update: With a vanilla standalone project I can put aspects in one project and access them from another
It seems impossible to do this if, as in my case, the project using the aspect is a RESTful webservice.
I find this hard to understand since once on a server the webservoce is just another application
I can use an aspect that resides inside the webservice but not outside.
Previous Topic:Plug-in org.eclipse.jdt.ui was unable to load class org.eclipse.jdt.internal.ui.javaeditor.Compilati
Next Topic:news.eclipse.org is shutting down.
Current Time: Sun Jul 27 11:04:35 EDT 2025
Powered by FUDForum. Page generated in 0.25347 seconds
