Home » Modeling » M2T (model-to-text transformation) » [M2T] How to achieve a general goal
[M2T] How to achieve a general goal [message #62289] |
Fri, 05 June 2009 05:52  |
Hi everyone,
I have read as much as I could and now, I had several generic doubts.
I have a .ecore model. This .ecore model is a metamodel of GUI's and, as
instances of it, I create models (like instances of the .ecore model)
using EMF as usual.
My goal is to transform that models, instances of the .ecore model,
representing differents GUIs, to Java interfaces (using SWING, AWT,
SWT...) AUTOMATICALLY.
I think M2T handles this kind of purposes.
I think in two ways:
1.- Directly create a "JET transformation" from my models to my desired
..java clases and make it run.
2.- If it exists, use a pre-defined "JET transformation" that takes as
input models which are instances of a certain Java metamodel (obviuously
represented as .ecore or equivalent, also if it is exists too) and
automatically generates de desired Java code. In that case, I would not
have to use JET technology but only a QVT model transformation from GUI
models to JAVA models.
I hope you could point my job in the right direction.
Thank you!
Re: [M2T] How to achieve a general goal [message #62313 is a reply to message #62289] |
Fri, 05 June 2009 13:56   |
Hi Miguel,
I'ld recommend to use code generation.
Model transformation to the target platform model can become very
complicated. It's not that model transformation is inherently
complicated, but a Java meta model is very complicated, at least if it
not only covers the coarse grained concepts but also includes statements
and expressions.
IMHO generating code using a template language is easier, more readable
and maintainable, because we know and thing in the concrete syntax of
Java, not in its abstract syntax (aka meta model).
Sven
Miguel Angel Garcia de Dios schrieb:
> Hi everyone,
> using EMF as usual.
> desired .java clases and make it run.
> as input models which are instances of a certain Java metamodel
> (obviuously represented as .ecore or equivalent, also if it is exists
> too) and automatically generates de desired Java code. In that case, I
> would not have to use JET technology but only a QVT model transformation
> from GUI models to JAVA models.
> Thank you!
Re: [M2T] How to achieve a general goal [message #62337 is a reply to message #62313] |
Sat, 06 June 2009 11:20   |
Sven Efftinge pisze:
> Hi Miguel,
> and expressions.
> Cheers,
> Sven
IMHO it is not that much complicated to use M2M, but one need some
helper functions, and I am not aware of any Ecore Java model with java
code generation (so I did one myself).
I am using Modisco J2SE metamodel
(http://www.eclipse.org/gmt/modisco/technologies/J2SE5/) that represent
resolved java syntax (it can read Java code, and I can generate almost
exactly the same code, but all the types corresponding to names are
known). I did write Xpand templates from this model to Java.
Pros:
- You use type safe transformations
- Some transformations are actually easier in M2M way, as you collect
some informations in many places and put them to output model
- You can alter the output model in any way afterwards.
Cons:
- it is really low level model
- it is a bit complicated (UML is many times more complicated!)
- using M2T is more productive in typical cases
Nevertheless probably M2T would better in that use case.
Eventually I would propose to check the work around
http://www.eclipse.org/pmf/ You may find it interesting.
Ps. If you want to use both M2M and M2T you may eventually implement
same queries in both technologies. AFAIK JET, Acceleo and QVT, ATL have
no integration. On other hand there is Xpand with Xtend, so you can use
one query language to do M2M and use it in your M2T templates. IMO it is
more productive in most cases, but you pay a price - Jet is faster than
Xpand and ATL is faster than Xtend.
That is my personal opinion I am not connected to any of those
technologies ;).
Krzysztof Kowalczyk
Re: [M2T] How to achieve a general goal [message #62361 is a reply to message #62337] |
Mon, 08 June 2009 13:03  |
Ok, I think that the best option in my opinion is using JET but, Do
anybody know about a tutorial about the general steps for creating those
tamplates from EMF models? I mean, a tutorial for the language to be
used, or and simple example that, from a EMF model generates a simple
Java Code using the information about that model?
I am looking for a tutorial of this type but I am not being able to
understand the general steps and structure.
Than you for your answers.
>> Hi Miguel,
>> statements and expressions.
>> readable and maintainable, because we know and thing in the concrete
>> syntax of Java, not in its abstract syntax (aka meta model).
>> Cheers,
>> Sven
> Pros:
> Cons:
> technologies ;).
> Krzysztof Kowalczyk
Current Time: Tue Jul 22 12:08:26 EDT 2025
Powered by FUDForum. Page generated in 0.27304 seconds
