Home » Eclipse Projects » Plugin Development Environment (PDE) » Bundle-ClassPath not processed in 3.5RC1
Bundle-ClassPath not processed in 3.5RC1 [message #62269] Wed, 20 May 2009 07:39 Go to next message
Before I file this as a bug, just a quick cross-reference.
I've added a jar to the plug-in project, and then declared that jar in
the 'Classpath' area under the 'Runtime' tab of the Manifest editor.
Yet, the 'Exported Packages' area remains disabled. I cannot 'Add,
Remove, ...'. The buttons are disabled. I've tried different jars from
different sources to check if the problem is associated with the package
itself, but the problems remains.
Any feedback on this?
Best,
Dann
Re: Bundle-ClassPath not processed in 3.5RC1 [message #62293 is a reply to message #62269] Wed, 20 May 2009 08:08 Go to previous messageGo to next message
.... I forgot to add this:
Manually adding the corresponding 'Export-Package' header to the
Manifest, with the expected packages yields the error message that this
package does not exist in this plug-in.
Re: Bundle-ClassPath not processed in 3.5RC1 [message #62317 is a reply to message #62293] Wed, 20 May 2009 08:17 Go to previous messageGo to next message
Repeated the steps with 3.5M7 and there it still works.
If someone from the PDE team gives me a nudge, I'll enter this as a bug.
Dann
Re: Bundle-ClassPath not processed in 3.5RC1 [message #62464 is a reply to message #62317] Thu, 21 May 2009 09:28 Go to previous message
I have found the way to reproduce this, and contrary to my previous
statement, those exact steps also cause the same problem in 3.5M7; I'll
file a bug on this one.
> Best regards,
> Dann
>> this package does not exist in this plug-in.
Re: Bundle-ClassPath not processed in 3.5RC1 [message #597660 is a reply to message #62269] Wed, 20 May 2009 08:08 Go to previous message
Re: Bundle-ClassPath not processed in 3.5RC1 [message #597667 is a reply to message #62293] Wed, 20 May 2009 08:17 Go to previous message
Dann
Re: Bundle-ClassPath not processed in 3.5RC1 [message #597711 is a reply to message #62317] Thu, 21 May 2009 09:28 Go to previous message
> Best regards,
> Dann
Previous Topic:More control over Eclipse builders
Next Topic:Update Manager port?
Current Time: Sat Jul 12 10:40:53 EDT 2025
Powered by FUDForum. Page generated in 0.03870 seconds
