cvs [server aborted]: cannot find .: No such file or directory [message #62264] |
Thu, 25 March 2004 09:52 |
Originally posted by: belgarath_NOSPAM.freemail.nl
----3D661A6453C297F8_message_boundary--
Content-type: text/plain; charset="us-ascii"
Hi all,
I've seen a number of questions about cvs and eclipse so I assume that this
is the appropriate news-group to post a question about it.
I've been trying to get my CVS server and eclipse to work together nicely
using SSH, but un-succesfull up to now.
This is the configuration:
The server that runs cvs is a Window2000 (SP4) server
Server: Concurrent Versions System (CVSNT) 2.0.34 (client/server)
The system that runs eclipse is also a Windows2000 (SP4) system.
Client: Concurrent Versions System (CVSNT) 2.0.34 (client/server)
I'm running eclipse 3.0.0 M7
When I define a CVS repository location in the "CVS Repositories" view,
there seems nothing wrong. The cvs-root looks like this
":extssh2:<user>@<host>:c:/cvsrepository"
When I try to open de HEAD branch the system seems to be connecting to the
server but nothing gets displayed. I have pur eclipse and the cvs plug-in's
into debug and then a bunch or errors is showing when I open the
HEAD-branch. I have attached the logfile (1.log)
In the log-file you can see that the Error-massage is "cvs [server
aborted]: cannot find .: No such file or directory"
The CVSNT option "Repository prefix" has been disabled on the cvs-server
and also the "Impersonation".
When I create a CVS repository location using pserver everything runs fine,
but this is not what we want since we are planning to use it over the web.
Anyone has expirenced the same problem? Any suggestions for changes, test,
things to try are very welcome.
Roel
Content-type: application/octet-string; name="1.log"
Content-Transfer-Encoding: Base64
Content-Disposition: attachment; FileName="1.log"
Content-Description: Attached file: 1.log
VXNpbmcgdGhlIGluc3RhbGxhdGlvbiBkaXJlY3RvcnkuDQpDb25maWd1cmF0 aW9uIGZpbGU6
DQogICAgZmlsZTpjOi9lY2xpcHNlLy5jb25maWcvY29uZmlnLmluaQ0KRnJh bWV3b3JrIGxv
Y2F0ZWQ6DQogICAgZmlsZTpjOi9lY2xpcHNlL3BsdWdpbnMvb3JnLmVjbGlw c2Uub3NnaV8z
LjAuMC8NCkZyYW1ld29yayBjbGFzc3BhdGg6DQogICAgZmlsZTpjOi9lY2xp cHNlL3BsdWdp
bnMvb3JnLmVjbGlwc2Uub3NnaV8zLjAuMC9jb3JlLmphcg0KICAgIGZpbGU6 YzovZWNsaXBz
ZS9wbHVnaW5zL29yZy5lY2xpcHNlLm9zZ2lfMy4wLjAvY29uc29sZS5qYXIN CiAgICBmaWxl
OmM6L2VjbGlwc2UvcGx1Z2lucy9vcmcuZWNsaXBzZS5vc2dpXzMuMC4wL29z Z2kuamFyDQog
ICAgZmlsZTpjOi9lY2xpcHNlL3BsdWdpbnMvb3JnLmVjbGlwc2Uub3NnaV8z LjAuMC9yZXNv
bHZlci5qYXINCiAgICBmaWxlOmM6L2VjbGlwc2UvcGx1Z2lucy9vcmcuZWNs aXBzZS5vc2dp
XzMuMC4wL2RlZmF1bHRBZGFwdG9yLmphcg0KICAgIGZpbGU6YzovZWNsaXBz ZS9wbHVnaW5z
L29yZy5lY2xpcHNlLm9zZ2lfMy4wLjAvZWNsaXBzZUFkYXB0b3IuamFyDQpT cGxhc2ggcGF0
aDoNCiAgICBjOlxlY2xpcHNlXHBsdWdpbnNcb3JnLmVjbGlwc2UucGxhdGZv cm1fMy4wLjBc
c3BsYXNoLmJtcA0KRGVidWctT3B0aW9uczoNCiAgICBmaWxlOkM6L2VjbGlw c2UvLm9wdGlv
bnMNClRpbWUgbG9hZEJ1bmRsZXMgaW4gdGhlIGZyYW1ld29yazogMjk3DQpW YWxpZC1yZXNw
b25zZXMgb2sgZXJyb3IgTSBFIENoZWNrZWQtaW4gVmFsaWQtcmVxdWVzdHMg VGVtcGxhdGUg
U2V0LXN0aWNreSBNVCBDbA0KZWFyLXN0YXRpYy1kaXJlY3RvcnkgTW9kdWxl LWV4cGFuc2lv
biBTZXQtc3RhdGljLWRpcmVjdG9yeSBDbGVhci1zdGlja3kgTmV3LWVudHIN CnkgTWVyZ2Vk
IFJlbW92ZWQgVXBkYXRlZCBSZW1vdmUtZW50cnkgVXBkYXRlLWV4aXN0aW5n IENvcHktZmls
ZSBDcmVhdGVkIE5vdGlmaWVkDQogTW9kLXRpbWUNCnZhbGlkLXJlcXVlc3Rz DQpWYWxpZC1y
ZXF1ZXN0cyBSb290IFZhbGlkLXJlc3BvbnNlcyB2YWxpZC1yZXF1ZXN0cyBE aXJlY3Rvcnkg
TWF4LWRvdGRvdCBTdGF0aWMtZA0KaXJlY3RvcnkgU3RpY2t5IEVudHJ5IEVu dHJ5RXh0cmEg
S29wdCBDaGVja2luLXRpbWUgTW9kaWZpZWQgSXMtbW9kaWZpZWQgVXNlVW5j aGENCm5nZWQg
VW5jaGFuZ2VkIE5vdGlmeSBOb3RpZnlVc2VyIFF1ZXN0aW9uYWJsZSBDYXNl IFV0ZjggQXJn
dW1lbnQgQXJndW1lbnR4IEdsb2JhDQpsX29wdGlvbiBHemlwLXN0cmVhbSB3 cmFwcGVyLXNl
bmRtZS1yY3NPcHRpb25zIFNldCBleHBhbmQtbW9kdWxlcyBjaSBjbyBjaG93 biBzZQ0KdG93
bmVyIHNldHBlcm0gY2hhY2wgc2V0YWNsIGxpc3RwZXJtIGxzYWNsIHNldHBh c3MgcGFzc3dk
IHVwZGF0ZSBkaWZmIGxvZyBybG9nIGENCmRkIHJlbW92ZSB1cGRhdGUtcGF0 Y2hlcyBzdGF0
dXMgbHMgcmRpZmYgdGFnIHJ0YWcgaW1wb3J0IGFkbWluIGV4cG9ydCBoaXN0 b3J5IHJlDQps
ZWFzZSB3YXRjaC1vbiB3YXRjaC1vZmYgd2F0Y2gtYWRkIHdhdGNoLXJlbW92 ZSB3YXRjaGVy
cyBlZGl0b3JzIGluaXQgYW5ub3RhdGUgcg0KYW5ub3RhdGUgbm9vcCB2ZXJz aW9uIFJvb3Rs
ZXNzLXN0cmVhbS1tb2RpZmljYXRpb24gS2VyYmVyb3MtZW5jcnlwdCBHc3Nh cGktZW5jcnkN
CnB0IFByb3RvY29sLWVuY3J5cHQgR3NzYXBpLWF1dGhlbnRpY2F0ZSBQcm90 b2NvbC1hdXRo
ZW50aWNhdGUgcmVhZC1jdnNyYyByZWFkLWN2DQpzcmMyIHJlYWQtY3ZzaWdu b3JlIHJlYWQt
Y3Zzd3JhcHBlcnMgRXJyb3ItSWYtUmVhZGVyIEF1dGhlbnRpY2F0aW9uLVJl cXVlc3RlZA0K
IENvbXByZXNzaW9uLVJlcXVlc3RlZCAgVmFsaWQtUmNzT3B0aW9ucw0Kb2sN ClJvb3QgYzov
cmVwb3NpdG9yaWVzDQpDTUQ+IGN2cyB2ZXJzaW9uDQp2ZXJzaW9uDQpFIGN2 cyBbc2VydmVy
IGFib3J0ZWRdOiBjOi9yZXBvc2l0b3JpZXM6IG5vIHN1Y2ggcmVwb3NpdG9y eQ0KZXJyb3IN
ClJFU1VMVD4gU3RhdHVzIEVSUk9Sb3JnLmVjbGlwc2UudGVhbS5jdnMuY29y ZSBjb2RlPS0x
MCBUaGUgc2VydmVyIHJlcG9ydGVkIGFuIGVyDQpyb3Igd2hpbGUgcGVyZm9y bWluZyB0aGUg
ImN2cyB2ZXJzaW9uIiBjb21tYW5kLiBudWxsIGNoaWxkcmVuPVtTdGF0dXMg RVJST1Jvcmcu
ZQ0KY2xpcHNlLnRlYW0uY3ZzLmNvcmUgY29kZT0tMTQgY3ZzIFtzZXJ2ZXIg YWJvcnRlZF06
IGM6L3JlcG9zaXRvcmllczogbm8gc3VjaCByZXANCm9zaXRvcnkgbnVsbF0N CkNNRD4gY3Zz
IC1uIHVwZGF0ZSAtZCAiIg0KR2xvYmFsX29wdGlvbiAtbg0KQXJndW1lbnQg LWQNCkRpcmVj
dG9yeSAuDQpjOi9yZXBvc2l0b3JpZXMvDQpBcmd1bWVudCAuDQpEaXJlY3Rv cnkgLg0KYzov
cmVwb3NpdG9yaWVzLw0KdXBkYXRlDQoNClJFU1VMVD4gU3RhdHVzIEVSUk9S b3JnLmVjbGlw
c2UudGVhbS5jdnMuY29yZSBjb2RlPS0xMCBUaGUgc2VydmVyIHJlcG9ydGVk IGFuIGVyDQpy
b3Igd2hpbGUgcGVyZm9ybWluZyB0aGUgImN2cyB1cGRhdGUiIGNvbW1hbmQu IG51bGwgY2hp
bGRyZW49W1N0YXR1cyBFUlJPUm9yZy5lYw0KbGlwc2UudGVhbS5jdnMuY29y ZSBjb2RlPS0x
MCBUaGUgc2VydmVyIGRpZCBub3QgcHJvdmlkZSBhbnkgYWRkaXRpb25hbCBp bmZvcm1hdGkN
Cm9uLiBudWxsXQ0KIVNFU1NJT04gbXJ0IDI1LCAyMDA0IDE1OjM3OjI3Ljkz NyAtLS0tLS0t
LS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0NCg0KamF2 YS52ZXJzaW9u
PTEuNC4yXzAzDQpqYXZhLnZlbmRvcj1TdW4gTWljcm9zeXN0ZW1zIEluYy4N CkJvb3RMb2Fk
ZXIgY29uc3RhbnRzOiBPUz13aW4zMiwgQVJDSD14ODYsIFdTPXdpbjMyLCBO TD1ubF9OTA0K
IUVOVFJZIG9yZy5lY2xpcHNlLnRlYW0uY3ZzLnVpIDQgMCBtcnQgMjUsIDIw MDQgMTU6Mzc6
MjcuOTY4DQohTUVTU0FHRSBJbnRlcm5hbCBlcnJvcg0KIVNUQUNLIDENCm9y Zy5lY2xpcHNl
LnRlYW0uaW50ZXJuYWwuY2N2cy5jb3JlLmNvbm5lY3Rpb24uQ1ZTU2VydmVy RXhjZXB0aW9u
OiBUaGUgc2VydmVyIHJlDQpwb3J0ZWQgYW4gZXJyb3Igd2hpbGUgcGVyZm9y bWluZyB0aGUg
ImN2cyB1cGRhdGUiIGNvbW1hbmQuDQogICAgICAgIGF0IG9yZy5lY2xpcHNl LnRlYW0uaW50
ZXJuYWwuY2N2cy5jb3JlLnJlc291cmNlcy5SZW1vdGVGb2xkZXJNZW1iZXJG ZXRjaA0KZXIu
cGVyZm9ybUVycm9yQ2hlY2soUmVtb3RlRm9sZGVyTWVtYmVyRmV0Y2hlci5q YXZhOjE2NikN
CiAgICAgICAgYXQgb3JnLmVjbGlwc2UudGVhbS5pbnRlcm5hbC5jY3ZzLmNv cmUucmVzb3Vy
Y2VzLlJlbW90ZUZvbGRlck1lbWJlckZldGNoDQplci5mZXRjaE1lbWJlcnMo UmVtb3RlRm9s
ZGVyTWVtYmVyRmV0Y2hlci5qYXZhOjg4KQ0KICAgICAgICBhdCBvcmcuZWNs aXBzZS50ZWFt
LmludGVybmFsLmNjdnMuY29yZS5yZXNvdXJjZXMuUmVtb3RlRm9sZGVyTWVt YmVyRmV0Y2gN
CmVyLmZldGNoTWVtYmVycyhSZW1vdGVGb2xkZXJNZW1iZXJGZXRjaGVyLmph dmE6NzMpDQog
ICAgICAgIGF0IG9yZy5lY2xpcHNlLnRlYW0uaW50ZXJuYWwuY2N2cy51aS5v cGVyYXRpb25z
LkZldGNoTWVtYmVyc09wZXJhdGlvbi5leA0KZWN1dGUoRmV0Y2hNZW1iZXJz T3BlcmF0aW9u
LmphdmE6MTExKQ0KICAgICAgICBhdCBvcmcuZWNsaXBzZS50ZWFtLmludGVy bmFsLmNjdnMu
dWkub3BlcmF0aW9ucy5DVlNPcGVyYXRpb24ucnVuKENWU09wZXINCmF0aW9u LmphdmE6MTIw
KQ0KICAgICAgICBhdCBvcmcuZWNsaXBzZS50ZWFtLmludGVybmFsLmNjdnMu dWkubW9kZWwu
Q1ZTVGFnRWxlbWVudC5mZXRjaERlZmVycmVkQ2gNCmlsZHJlbihDVlNUYWdF bGVtZW50Lmph
dmE6MTEyKQ0KICAgICAgICBhdCBvcmcuZWNsaXBzZS51aS5wcm9ncmVzcy5E ZWZlcnJlZFRy
ZWVDb250ZW50TWFuYWdlciQyLnJ1bihEZWZlcnJlZFRyZWUNCkNvbnRlbnRN YW5hZ2VyLmph
dmE6MTg4KQ0KICAgICAgICBhdCBvcmcuZWNsaXBzZS5jb3JlLmludGVybmFs LmpvYnMuV29y
a2VyLnJ1bihXb3JrZXIuamF2YTo2MikNCiFFTlRSWSBvcmcuZWNsaXBzZS50 ZWFtLmN2cy5j
b3JlIDQgLTEwIG1ydCAyNSwgMjAwNCAxNTozNzoyOC4xNQ0KIU1FU1NBR0Ug VGhlIHNlcnZl
ciByZXBvcnRlZCBhbiBlcnJvciB3aGlsZSBwZXJmb3JtaW5nIHRoZSAiY3Zz IHVwZGF0ZSIg
Y29tbWFuZC4NCg0KIVNVQkVOVFJZIDEgb3JnLmVjbGlwc2UudGVhbS5jdnMu Y29yZSA0IC0x
MCBtcnQgMjUsIDIwMDQgMTU6Mzc6MjguMzENCiFNRVNTQUdFIFRoZSBzZXJ2 ZXIgZGlkIG5v
dCBwcm92aWRlIGFueSBhZGRpdGlvbmFsIGluZm9ybWF0aW9uLg0KDQo=
----3D661A6453C297F8_message_boundary----
FUDForum. Page generated in 0.06769 seconds
