Xtext formatter [message #62232] |
Wed, 22 July 2009 04:24  |
I really like the formatting support in the new Xtext version. However,
creating a formatting configuration for a large grammer is often tedious.
As far as I understood the documentation, I have to configure the
formatter for each rule specific token, e.g.:
c.setNoSpace().around(f.getParamAccess().getColonKeyword_1() );
In our grammar we have 10 different rules in which we use a colon keyword
and therefore I have to configure each of them separately. In order to
avoid this, my idea was to define a terminal for the colon keyword and
then configure the formatter based on the terminal. This would enable the
reuse of formatting rules across different grammar rules:
c.setNoSpace().around(f.getDOTRule());
However, this did not work. Is there another way to configure the
formatter in a more general way?
This also applies to curly braces where would like to write something like:
c.setIndentation(
f.getLeftCurlyBracketRule(),
f.getRightCurlyBracketRule());
c.setLinewrap().after(
f.getLeftCurlyBracketRule());
Sebastian
Re: Xtext formatter [message #62355 is a reply to message #62232] |
Wed, 22 July 2009 05:22   |
Hi Sebastian,
good to hear!
> However,
> tedious. As far as I understood the documentation, I have to configure
> the formatter for each rule specific token, e.g.:
that is right.
> keyword and therefore I have to configure each of them separately. In
> order to avoid this, my idea was to define a terminal for the colon
> keyword and then configure the formatter based on the terminal. This
> would enable the reuse of formatting rules across different grammar rules:
Assigning formatting to rules currently only works with rules for hidden
tokens..
you can build your own:
<pseudocode>
for(AbstractElement e: grammarAccess.getGrammar().eAllElements())
if(e instanceof Keyword) {
Keyword k = (Keyword) e;
if(".".equals(k.getValue()))
cfg.setNoSpace().around(k);
</psudocode>
> c.setIndentation(
I guess you can think of a similar loop for finding all pairs of curly
brackets...
Generally speaking, I can say that we a re aware of this situation and
thinking about how to improve it. Another issue is, that methods-names
of the GrammarAccess tend to change when you modify your grammar.
One idea is to extend the GrammarAccess with methods that return all
keywords of a certain type, e.g.
ga.getAllColonKeywords()
Another is to introduce find-methods:
ga.findKeywords(".")
hth,
Moritz
Need professional support for Eclipse Modeling?
Go visit: http://xtext.itemis.com
Re: Xtext formatter [message #62731 is a reply to message #62355] |
Wed, 22 July 2009 10:40  |
Hi Moritz,
thanks for your help! It works as you said:
protected void configureFormatting(FormattingConfig c) {
MyGrammarAccess f = (MyGrammarAccess) getGrammarAccess();
// colons
Iterable<Keyword> keywords = GrammarUtil.containedKeywords(f.getGrammar());
for (Keyword currentKeyword : keywords) {
if (".".equals(currentKeyword.getValue())) {
c.setNoSpace().around(keyword);
// braces
Stack<Keyword> openBraceStack = new Stack<Keyword>();
if ("{".equals(currentKeyword.getValue())) {
openBraceStack.add(currentKeyword);
c.setLinewrap().after(currentKeyword);
}else if ("}".equals(currentKeyword.getValue())) {
c.setLinewrap().before(currentKeyword);
if (!openBraceStack.isEmpty()) {
c.setIndentation(openBraceStack.pop(), currentKeyword);
I think it would be really helpful if one could configure the formatting
at rule level, for example:
Statement:
Assignment | Return
c.setLinewrap().after(f.getStatementRule());
Sebastian
Moritz Eysholdt wrote:
> Hi Sebastian,
> good to hear!
>> However,
> that is right.
> tokens..
> <pseudocode>
> </psudocode>
>> c.setIndentation(
> brackets...
> hth,
> Moritz
FUDForum. Page generated in 0.03628 seconds
