Home » Archived » Visual Editor (VE) » Error when opening a class with the visual publisher
Error when opening a class with the visual publisher [message #62225] Tue, 28 September 2004 05:52 Go to next message
Originally posted by: rbs.e-basico.net
When I open of visual form a class that extens of JPanel, it generates the
exception following
!SESSION sep 28, 2004 11:45:15.578
eclipse.buildId=I200406251208
java.fullversion=J2RE 1.4.2 IBM Windows 32 build cn1420-20040626 (JIT
enabled: jitc)
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=es_ES
!ENTRY org.eclipse.ve.java.core 4 0 sep 28, 2004 11:45:15.578
!MESSAGE Exception thrown.
!STACK 0
java.lang.ClassCastException: org.eclipse.emf.java.util.JavaResourceImpl
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.createJavaInstances(JavaS
rceTranslator.java:705)
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.buildCompositionModel(Jav
ourceTranslator.java:774)
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.decodeDocument(JavaSource
anslator.java:881)
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.loadModel(JavaSourceTrans
tor.java:656)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$Setup.run(JavaVisua
ditorPart.java:1444)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:66)
Windows 2000
ServiPack 4
Eclipse 3,0
Everything updated
Re: Error when opening a class with the visual publisher [message #62273 is a reply to message #62225] Tue, 28 September 2004 08:40 Go to previous messageGo to next message
Originally posted by: myersj.nospam.gmail.com
> exception following
> enabled: jitc)
> !STACK 0
> at
To quote Joe:
Can you pleased unload the EMF examples which conflict with the VE.
There is a bugzilla 71473 to fix this.
- Jeff
Re: Error when opening a class with the visual publisher [message #62415 is a reply to message #62273] Tue, 28 September 2004 12:37 Go to previous message
Jeff Myers wrote:
> > exception following
> > enabled: jitc)
> > !STACK 0
> > at
> To quote Joe:
> - Jeff
OK - Everything works of form correcta. Thanks
- Rafa
Re: Error when opening a class with the visual publisher [message #599877 is a reply to message #62225] Tue, 28 September 2004 08:40 Go to previous message
> exception following
> enabled: jitc)
> !STACK 0
> at
To quote Joe:
- Jeff
Re: Error when opening a class with the visual publisher [message #599926 is a reply to message #62273] Tue, 28 September 2004 12:37 Go to previous message
Jeff Myers wrote:
> > exception following
> > enabled: jitc)
> > !STACK 0
> > at
> To quote Joe:
> - Jeff
- Rafa
Previous Topic:VE and SWT
Next Topic:Visualizing code in the Design view doesn't work
Current Time: Sat Jul 12 20:05:48 EDT 2025
Powered by FUDForum. Page generated in 0.04936 seconds
