Teneo resources and the EMF Validation framework do not properly work together [message #616010] |
Thu, 27 March 2008 10:57 |
Hi!
I'm trying to use the EMF Validation framework (not to be confused with the
EValidator API) together with an EMF editor based on JPOXResource. The
editor works fine, I can run the validation and I even get results in the
form of a popup window. Problem marker generation (with
EclipseResourcesUtil used by ValidateAction) however, is broken because
calls to IFile EditUIMarkerHelper::getFile(Object datum) return null for
JPOXResource objects. The getFile method propagates to
MarkerHelper::getFile(URI uri)) which checks if the URI is a platform URI
and returns null if it is not.
Are there any workarounds known for this problem?
Florian
Florian Hackenberger
FUDForum. Page generated in 0.02574 seconds
