Home » Archived » M2M (model-to-model transformation) » [ATL] Error injecting KM3 with Ant
[ATL] Error injecting KM3 with Ant [message #62196] Sat, 22 September 2007 06:14 Go to next message
Hello again.
To automate the build process of my project I created an Ant script to
inject a KM3 meta-model into the corrensponding EMF (Ecore) meta-model, and
ran it from Eclipse.
I'm using the following Ant target, almost cut-n-pasted from the wiki:
<!-- MODEL INJECTION -->
<target name="inject">
<am3.loadModel name="${model}" path="${model}.km3"
metamodel="KM3" modelHandler="EMF">
<injector name="ebnf">
<param name="name" value="KM3" />
</injector>
</am3.loadModel>
<am3.saveModel model="${model}" path="${model}.ecore" />
</target>
${model} is a Ant property set to the model name without extension (the .km3
file is correctly found).
When running the Ant task I get the following:
inject:
[am3.loadModel] GRAVE: no type named 'Metamodel' in metamodel 'ModelName'
[am3.loadModel] java.lang.NullPointerException
[am3.loadModel] at
org.eclipse.m2m.atl.drivers.emf4atl.ASMEMFModel.newModelElem ent(ASMEMFModel.java:185)
[am3.loadModel] at
org.eclipse.m2m.atl.engine.vm.nativelib.ASMModel.newModelEle ment(ASMModel.java:76)
[am3.loadModel] at
org.eclipse.m2m.atl.engine.vm.nativelib.ASMModel.newModelEle ment(ASMModel.java:62)
[am3.loadModel] at
org.atl.engine.injectors.ebnf.ASMModelHandler.createElement( ASMModelHandler.java:89)
[am3.loadModel] at
org.atl.engine.injectors.ebnf.EBNFInjector2.create(EBNFInjec tor2.java:301)
[am3.loadModel] at
org.atl.engine.injectors.ebnf.KM3_ANTLR3Parser.metamodel(KM3 _ANTLR3Parser.java:318)
[am3.loadModel] at
org.atl.engine.injectors.ebnf.KM3_ANTLR3Parser.main(KM3_ANTL R3Parser.java:117)
[am3.loadModel] at sun.reflect.NativeMethodAccessorImpl.invoke0(Native
Method)
[am3.loadModel] at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown
Source)
[am3.loadModel] at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown
Source)
[am3.loadModel] at java.lang.reflect.Method.invoke(Unknown Source)
[am3.loadModel] at
org.eclipse.gmt.tcs.wrappers.antlr3.ParserWrapper.parse(Pars erWrapper.java:69)
[am3.loadModel] at
org.atl.engine.injectors.ebnf.EBNFInjector2.performImportati on(EBNFInjector2.java:253)
[am3.loadModel] at
org.atl.engine.injectors.ebnf.EBNFInjector2.performImportati on(EBNFInjector2.java:213)
[am3.loadModel] at
org.atl.engine.injectors.ebnf.EBNFInjector2.performImportati on(EBNFInjector2.java:162)
[am3.loadModel] at
org.atl.engine.injectors.ebnf.EBNFInjector2.inject(EBNFInjec tor2.java:92)
[am3.loadModel] at
org.eclipse.gmt.am3.tools.ant.toolkit.AM3AntToolKit.ebnfInje ction(AM3AntToolKit.java:256)
[am3.loadModel] at
org.eclipse.gmt.am3.tools.ant.toolkit.AM3AntToolKit.ebnfInje ction(AM3AntToolKit.java:273)
[am3.loadModel] at
org.eclipse.gmt.am3.tools.ant.toolkit.AM3AntToolKit.inject(A M3AntToolKit.java:281)
[am3.loadModel] at
org.eclipse.gmt.am3.tools.ant.tasks.LoadModelTask.execute(Lo adModelTask.java:62)
[am3.loadModel] at
org.apache.tools.ant.UnknownElement.execute(UnknownElement.j ava:275)
[am3.loadModel] at org.apache.tools.ant.Task.perform(Task.java:364)
[am3.loadModel] at org.apache.tools.ant.Target.execute(Target.java:341)
[am3.loadModel] at
org.apache.tools.ant.Target.performTasks(Target.java:369)
[am3.loadModel] at
org.apache.tools.ant.Project.executeSortedTargets(Project.ja va:1216)
[am3.loadModel] at
org.apache.tools.ant.Project.executeTarget(Project.java:1185 )
[am3.loadModel] at
org.apache.tools.ant.helper.DefaultExecutor.executeTargets(D efaultExecutor.java:40)
[am3.loadModel] at
org.eclipse.ant.internal.core.ant.EclipseDefaultExecutor.exe cuteTargets(EclipseDefaultExecutor.java:32)
[am3.loadModel] at
org.apache.tools.ant.Project.executeTargets(Project.java:106 8)
[am3.loadModel] at
org.eclipse.ant.internal.core.ant.InternalAntRunner.run(Inte rnalAntRunner.java:706)
[am3.loadModel] at
org.eclipse.ant.internal.core.ant.InternalAntRunner.run(Inte rnalAntRunner.java:457)
Method)
Source)
Source)
[am3.loadModel] at org.eclipse.ant.core.AntRunner.run(AntRunner.java:356)
[am3.loadModel] at
org.eclipse.ant.internal.ui.launchConfigurations.AntLaunchDe legate$1.run(AntLaunchDelegate.java:230)
[am3.loadModel] at java.lang.Thread.run(Unknown Source)
[am3.saveModel] INFO: Saving model WebML
BUILD SUCCESSFUL
Total time: 163 milliseconds
Although it says "build successful", the resulting Ecore file is empty and
therefore not valid.
What does "no type named 'Metamodel' in metamodel 'ModelName'" mean? I'm
sure the KM3 file is syntax-correct and I can inject it successfully using
the context-menu command provided by the ATL Eclipse plugin.
Thank you in advance.
Lorenzo
Re: [ATL] Error injecting KM3 with Ant [message #62220 is a reply to message #62196] Sat, 22 September 2007 11:03 Go to previous messageGo to next message
Did you load the KM3 metamodel in Ecore format (e.g., KM3.ecore, or
better, nsURI="http://www.eclipse.org/gmt/2005/KM3") before loading the
KM3 model?
Frédéric Jouault
Lorenzo Dalla Vecchia wrote:
> Hello again.
> and ran it from Eclipse.
> </injector>
> </am3.loadModel>
> </target>
> .km3 file is correctly found).
> inject:
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> Method)
> Source)
> [am3.loadModel] at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> Method)
> Source)
> [am3.loadModel] at
> [am3.loadModel] at
> BUILD SUCCESSFUL
> and therefore not valid.
> using the context-menu command provided by the ATL Eclipse plugin.
> Lorenzo
Re: [ATL] Error injecting KM3 with Ant [message #62245 is a reply to message #62220] Sat, 22 September 2007 18:48 Go to previous messageGo to next message
You were right, I totally forgot to load the KM3 metamodel itself.
However there is still a problem with the following new code:
<am3.loadModel modelHandler="EMF" name="KM3"
nsUri="http://www.eclipse.org/gmt/2005/KM3"
metamodel="MOF" />
<am3.loadModel modelHandler="EMF" name="${model}"
path="${model}.km3" metamodel="KM3">
</injector>
</am3.loadModel>
</target>
Unlike Ecore files produced by the Eclipse plugin, the resulting Ecore file
does not use the namespace http://www.eclipse.org/emf/2002/Ecore and
elements like eClass, eAttribute but the KM3 namespace
(http://www.eclipse.org/gmt/2005/KM3) and different elements like Metamodel
and Contents, thus making it incompatible with other EMF tools.
I'm sure that there is a simple way of fixing this problem, maybe adding
another injector parameter... Sorry, I'm a bit newbie with these tools.
Regards.
Lorenzo
"Frédéric Jouault" <frederic.jouault@univ-nantes.fr> ha scritto nel
messaggio news:fd3ari$g9f$1@build.eclipse.org...
> Hello,
> KM3 model?
> Frédéric Jouault
>> Hello again.
>> </injector>
>> </am3.loadModel>
>> </target>
>> inject:
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> Method)
>> Source)
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> Method)
>> Source)
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> BUILD SUCCESSFUL
>> Lorenzo
Re: [ATL] Error injecting KM3 with Ant [message #62268 is a reply to message #62245] Sun, 23 September 2007 12:17 Go to previous messageGo to next message
Originally posted by: mikael.barbero.gmail.com
Hi Lorenzo,
After the injection of your .km3 file, you get a KM3 model (M1 level),
conforming to the KM3 metamodel (M2 level), itself conforming to Ecore
(M3 level). If you want to get a metamodel from the KM3 model, you have
to "promote" this model. You can do this with the transformation KM32Ecore.
Mikael
> metamodel="MOF" />
> </injector>
> </am3.loadModel>
> </target>
> file does not use the namespace http://www.eclipse.org/emf/2002/Ecore
> and elements like eClass, eAttribute but the KM3 namespace
> Metamodel and Contents, thus making it incompatible with other EMF tools.
> Regards.
> Lorenzo
>> Hello,
>> the KM3 model?
>> Regards,
>> Frédéric Jouault
>>> Hello again.
>>> to inject a KM3 meta-model into the corrensponding EMF (Ecore)
>>> meta-model, and ran it from Eclipse.
>>> </injector>
>>> </am3.loadModel>
>>> </target>
>>> (the .km3 file is correctly found).
>>> inject:
>>> 'ModelName'
>>> [am3.loadModel] at
>>> [am3.loadModel] at
>>> [am3.loadModel] at
>>> [am3.loadModel] at
>>> [am3.loadModel] at
>>> [am3.loadModel] at
>>> [am3.loadModel] at
>>> [am3.loadModel] at
>>> sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>>> [am3.loadModel] at
>>> sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
>>> [am3.loadModel] at
>>> [am3.loadModel] at
>>> [am3.loadModel] at
>>> [am3.loadModel] at
>>> [am3.loadModel] at
>>> [am3.loadModel] at
>>> [am3.loadModel] at
>>> [am3.loadModel] at
>>> [am3.loadModel] at
>>> [am3.loadModel] at
>>> [am3.loadModel] at
>>> [am3.loadModel] at
>>> [am3.loadModel] at
>>> [am3.loadModel] at
>>> [am3.loadModel] at
>>> [am3.loadModel] at
>>> [am3.loadModel] at
>>> [am3.loadModel] at
>>> [am3.loadModel] at
>>> [am3.loadModel] at
>>> [am3.loadModel] at
>>> [am3.loadModel] at
>>> [am3.loadModel] at
>>> [am3.loadModel] at
>>> BUILD SUCCESSFUL
>>> empty and therefore not valid.
>>> I'm sure the KM3 file is syntax-correct and I can inject it
>>> successfully using the context-menu command provided by the ATL
>>> Eclipse plugin.
>>> Lorenzo
Mikaël Barbero - PhD Candidate
ATLAS Group (INRIA & LINA) - University of Nantes
2, rue de la Houssinière
44322 Nantes Cedex 3 - France
tel. +33 2 51 12 58 08 /\ cell.+33 6 07 63 19 00
email: Mikael.Barbero@{gmail.com, univ-nantes.fr}
http://www.sciences.univ-nantes.fr/lina/atl/
Re: [ATL] Error injecting KM3 with Ant [message #62315 is a reply to message #62268] Mon, 24 September 2007 15:54 Go to previous message
> conforming to the KM3 metamodel (M2 level), itself conforming to Ecore (M3
> level). If you want to get a metamodel from the KM3 model, you have to
It worked adding an am3.atl task for the trasformation.
Thanks a lot!
Lorenzo
Previous Topic:[M2M] [Fwd: Re: resolving volatile references]
Next Topic:Re: 'EStructuralFeature' is not a valid classifier
Current Time: Tue Jul 15 05:45:03 EDT 2025
Powered by FUDForum. Page generated in 0.03768 seconds
