Home » Language IDEs » Java Development Tools (JDT) » Package Explorer Directory Structute
Package Explorer Directory Structute [message #62083] Thu, 19 June 2003 15:22 Go to next message
Originally posted by: vnssoftware.yahoo.com
How can the Package Explorer be made to show the Directory Structure as in
the File system instead of com.xxx. I am more comfortable with Resource
View- but then it doesn't show the Java Files. Only xml/properties files.
If you can show me a way so that Resource Prespective shows the Java
files, that's fine too.
Thanks...
Re: Package Explorer Directory Structute [message #62343 is a reply to message #62083] Thu, 19 June 2003 18:09 Go to previous messageGo to next message
Originally posted by: richkulp.NOSPAM.us.ibm.com
Try on the Package Explorer toolbar, bring down the menu (the downward
pointing arrow) and select Layout->Heirarchical. That will be closer to
what you want.
Or just use the Navigator view instead, this shows everything as files.
I don't know of "Resource view". I couldn't find that. If that is
actually the Navigator view, it may be that you have some filters turned
on in the Navigator view and are hiding the java files. Check the menu
on the toolbar of the Resource view, Filters...
Rich
Thanks. [message #63658 is a reply to message #62343] Fri, 20 June 2003 17:50 Go to previous message
> what you want.
> Rich
Thanks, Worked.
Previous Topic:-> PDE JUnit
Next Topic:How to createa a new CVS Project in Eclipse
Current Time: Mon Jul 21 21:50:34 EDT 2025
Powered by FUDForum. Page generated in 0.03529 seconds
