Adding JScrollPanes around JLists [message #5540] |
Tue, 25 November 2003 19:30  |
Is it possible, using VE, to place a JList inside a ScollPane? I'm sure
one could hack the SDK to expose this, but I'm hesitant to get myself
enmeshed in yet more code. But I'd hope to finish setting this up as
visually as possible.
Re: Adding JScrollPanes around JLists [message #5569 is a reply to message #5551] |
Tue, 25 November 2003 22:00  |
Originally posted by: jdm0532.nospam.cs.rit.edu
The problems you're having with manipulating the combined object are
most likely occurring because you have the JList selected rather than
the JScrollPane. It's impossible to select the JScrollPane on the
canvas surface. You'll have to select the scroll pane on the Java Beans
Viewer, then perform the resize/align actions without losing the focus
on it on the canvas.
- Jeff Myers
Danyel Fisher wrote:
> Got it, thanks for the help.
> It's worth noting that the combined object seems harder to manipulate
> than the individual objects--it doesn't offer resize corners, and can't
> be aligned.
> Danyel
> Jeff Myers wrote:
>> Yes, you should be able to do this, but there's not a combined palette
>> item like JTable on JScrollPane. Simply drop the JScrollPane first
>> (from the Swing Containers drawer) then the JList on top of that. It
>> might be easier to get the child relationship right if you drop the
>> JList onto the JScrollPane on the Java Beans Viewer.
>> - Jeff Myers
>>> sure one could hack the SDK to expose this, but I'm hesitant to get
>>> myself enmeshed in yet more code. But I'd hope to finish setting this
>>> up as visually as possible.
Re: Adding JScrollPanes around JLists [message #569255 is a reply to message #5540] |
Tue, 25 November 2003 19:40  |
- Jeff Myers
Re: Adding JScrollPanes around JLists [message #569291 is a reply to message #5546] |
Tue, 25 November 2003 21:18  |
be aligned.
Danyel
> - Jeff Myers
Re: Adding JScrollPanes around JLists [message #569415 is a reply to message #5551] |
- Jeff Myers
> be aligned.
> Danyel
>> - Jeff Myers
FUDForum. Page generated in 0.07460 seconds
