Home » Archived » BIRT » Massive queries
Massive queries [message #62066] |
Wed, 27 July 2005 10:11  |
Originally posted by: benn.tilby.tangozebra.com
Has anyone else had problems when using BIRT with massive queries spanning
many tables? I have a query that works fine up until the point where a SUM
is required on a column. But this sum computes if I take other conditions
out of the query like reference to a couple of tables. I am wondering if all
this might 'overload' BIRT. I am sure it is not the logic of my query which
is crashing BIRT, as these extra tables should not prevent the extraction of
records when combined with using the sum. And BIRT does not generate an sql
error it just goes into thinking mode and then crashes Eclipse.
The specifics wont be of any use here, but to show the query size (if that
is of any indication to the problem cause), it is:
SELECT
s.name as s_name,
r.id as referrer_id,
r.display_name as r_name,
c.id as creative_id,
c.name as c_name,
ar.booked AS r_booked,
advert_sites.booked AS s_booked,
sacs.event_supertype AS event_supertype,
sacs.event_subtype AS event_subtype,
mpe.mb_rate,
mpe.basis
FROM
adverts a,
referrers r,
creatives c,
sites s,
advert_referrer_creatives arc,
advert_referrers ar,
stats_advert_criteria_sets sacs,
stats_advert_tallies sat,
media_plan_entry mpe
LEFT JOIN advert_sites ON (a.id = advert_sites.advert_id AND s.id =
advert_sites.site_id)
WHERE sacs.id = sat.criteria_set_id
AND a.job_number = ?
AND s.id = ?
AND a.active <> 'discarded'
AND arc.advert_id = a.id
AND arc.creative_id = c.id
AND arc.referrer_id = r.id
AND arc.suppressed = 'false'
AND ar.referrer_id = r.id
AND ar.advert_id = a.id
AND r.site_id = s.id
AND mpe.site_id = s.id
AND mpe.advert_id = a.id
AND r.internal = 'no'
AND c.advert_id = a.id
AND sacs.advert_id = a.id
AND sacs.creative_id = c.id
AND sacs.event_supertype in ('c', 'v', 'g')
GROUP BY
s.id, referrer_id, creative_id, event_supertype, event_subtype
Re: Massive queries [message #62137 is a reply to message #62066] |
Wed, 27 July 2005 13:44   |
What type of error do you see when your query "breaks" BIRT? Did JVM run out
of memory? Have you tried starting Eclipse with increased JVM heap size?
It's certainly possible for a large query to break Birt with the 1.0
release, since Birt does all calculations in memory, which means the entire
query's result set must fit in memory. This will likely change in a future
release - the Birt team is working on adding support for larger queries by
using disk file-based processing.
regards,
Gary Xue
Birt Committer
"Benn Tilby" <benn.tilby@tangozebra.com> wrote in message
news:dc84lu$39e$1@news.eclipse.org...
all
which
of
sql
> SELECT
> s.name as s_name,
> c.name as c_name,
> mpe.mb_rate,
> mpe.basis
> FROM
> adverts a,
> referrers r,
> creatives c,
> sites s,
> AND s.id = ?
> GROUP BY
Re: Massive queries [message #62231 is a reply to message #62137] |
Thu, 28 July 2005 06:23  |
Thanks for this... I have now been able to try this option - increasing the
stack size - but still crashes. So I guess I am awaiting support for larger
queries - which will be good because then we can consider moving all our
reporting to BIRT.
BT.
"Gary Xue" <gxue@actuate.com> wrote in message
news:dc8h3v$jk7$1@news.eclipse.org...
> out
> entire
> regards,
> Gary Xue
> Birt Committer
>> spanning
>> SUM
> all
> which
> of
> sql
>> that
>> SELECT
>> s.name as s_name,
>> c.name as c_name,
>> mpe.mb_rate,
>> mpe.basis
>> FROM
>> adverts a,
>> referrers r,
>> creatives c,
>> sites s,
>> AND s.id = ?
>> GROUP BY
Current Time: Fri Jul 25 23:29:40 EDT 2025
Powered by FUDForum. Page generated in 0.06967 seconds
