Home » Eclipse Projects » Eclipse Platform » [CVS] update workspace ?
[CVS] update workspace ? [message #62047] Wed, 04 June 2003 06:43 Go to next message
Originally posted by: yves.somewhere.com
I searched the cvs faq, but didn't find an answer.
Is there a possibility to update different projects in the workspace
with a "single click" ? Like the "solutions" in VAJ...
I tried it using ANT, but that doesn't work in a situation where a
project is stored in CVS under a subdirectory (e.g. project Yves is
stored in subdirectory USERS/Yves). In that case, the checkout command
creates the USERS directory, and I don't want that.
If someone can tell me how to use ANT for this, I'd be happy.
The ideal situation is that I specify the update in a "solution file" :
- project name (local)
- directory in CVS where the project can be found
- the tag to use for the update
Maybe there is some plugin that does the above ?
Thanks !
Yves
Re: [CVS] update workspace ? [message #62242 is a reply to message #62047] Wed, 04 June 2003 09:15 Go to previous messageGo to next message
Originally posted by: mccull1.does.not.like.spam.us.ibm.com
Check out: http://www.ejbprovider.de/homepage/index.html
I think it does what you want.
-Andrew
"Yves" <yves@somewhere.com> wrote in message
news:bbkig9$ksm$1@rogue.oti.com...
<SNIP>
> Yves
Re: [CVS] update workspace ? [message #65160 is a reply to message #62242] Fri, 06 June 2003 04:10 Go to previous message
Well, it does update a complete set of projects.
But it always destroys the local copy and retrieves
the complete project from the repository. I prefer
the way eclipse does (replace {version}) : only the
needed files are downloaded and replaced.
> -Andrew
>>Hi,
> <SNIP>
>>Yves
Previous Topic:Plugins - How can I access files during development and deploy
Next Topic:swt for pocket pc: where to find
Current Time: Thu Jul 17 20:50:15 EDT 2025
Powered by FUDForum. Page generated in 0.07637 seconds
