[CVS] update workspace ? [message #62047] |
Wed, 04 June 2003 06:43  |
Originally posted by: yves.somewhere.com
I searched the cvs faq, but didn't find an answer.
Is there a possibility to update different projects in the workspace
with a "single click" ? Like the "solutions" in VAJ...
I tried it using ANT, but that doesn't work in a situation where a
project is stored in CVS under a subdirectory (e.g. project Yves is
stored in subdirectory USERS/Yves). In that case, the checkout command
creates the USERS directory, and I don't want that.
If someone can tell me how to use ANT for this, I'd be happy.
The ideal situation is that I specify the update in a "solution file" :
- project name (local)
- directory in CVS where the project can be found
- the tag to use for the update
Maybe there is some plugin that does the above ?
Thanks !
Yves
Re: [CVS] update workspace ? [message #65160 is a reply to message #62242] |
Fri, 06 June 2003 04:10  |
Well, it does update a complete set of projects.
But it always destroys the local copy and retrieves
the complete project from the repository. I prefer
the way eclipse does (replace {version}) : only the
needed files are downloaded and replaced.
Andrew McCullough wrote:
> Check out: http://www.ejbprovider.de/homepage/index.html
> I think it does what you want.
> -Andrew
> "Yves" <yves@somewhere.com> wrote in message
> news:bbkig9$ksm$1@rogue.oti.com...
>>Hi,
> <SNIP>
>>Yves
FUDForum. Page generated in 0.27610 seconds
