Home » Archived » Visual Editor (VE) » VE and SWT
VE and SWT [message #62037] Mon, 27 September 2004 20:40 Go to next message
Originally posted by: cchan.spikesource.com
Unable to create SWT Shell using Visual Editor.
I tried to create a SWT Shell from the palette and from the new Visual
Class dialog, niether of them allows me to create a shell so I can add
other contents like buttons, etc.
- Creating from palette allows be to select SWT Container Shell, drag a
rectangle into canvas, but nothing shows up.
- Creating from the initial dialog, SWT Application, generates some
code, but fails to load the control palette (its empty) and gives an
error that a Null pointer was discovered. Then it is stuck because
cannot layout any controls since there is nothing in the palette.
Does anyone know why? I'm using Eclipse 3.0.1 with VE 1.0.
Thanks in advanced.
- Chris
Re: VE and SWT [message #62062 is a reply to message #62037] Mon, 27 September 2004 21:46 Go to previous messageGo to next message
The error I get is
"Error trying to set new file into editor"
Reason:
> Thanks in advanced.
> - Chris
Re: VE and SWT [message #62368 is a reply to message #62062] Tue, 28 September 2004 12:36 Go to previous message
> The error I get is
> Reason:
> java.lang.NullPointerException
>> a rectangle into canvas, but nothing shows up.
>> Thanks in advanced.
>> - Chris
Please attach the .log file (in the .metadata directory of your workspace)
Re: VE and SWT [message #599822 is a reply to message #62037] Mon, 27 September 2004 21:46 Go to previous message
The error I get is
Reason:
> Thanks in advanced.
> - Chris
Re: VE and SWT [message #599910 is a reply to message #62062] Tue, 28 September 2004 12:36 Go to previous message
> The error I get is
> Reason:
>> Thanks in advanced.
>> - Chris
Previous Topic:Code Generation
Next Topic:Error when opening a class with the visual publisher
Current Time: Sun Jul 27 06:22:42 EDT 2025
Powered by FUDForum. Page generated in 0.23474 seconds
