Home » Language IDEs » C / C++ IDE (CDT) » is there a page somewhere that discribes
is there a page somewhere that discribes [message #61959] Wed, 12 February 2003 03:21 Go to next message
Originally posted by: jpetzold.earthlink.net
how to setup a compiler under windows? I have MinGW installed in C:\MinGW
thanks
Re: is there a page somewhere that discribes [message #62078 is a reply to message #61959] Wed, 12 February 2003 17:00 Go to previous messageGo to next message
The CDT User's Guide indicates to add a build path to your project.
i.e.
make -f makefile
User's Guide
http://dev.eclipse.org/viewcvs/index.cgi/%7Echeckout%7E/cdt- home/user/faq.ht
ml?cvsroot=Tools_Project
For compiler specific set up see the documentation provided by CygWin and
MinGW.
-Judy
"Jeremy Petzold" <jpetzold@earthlink.net> wrote in message
news:3E4A0401.6060604@earthlink.net...
| thanks
Re: is there a page somewhere that discribes [message #62102 is a reply to message #62078] Thu, 13 February 2003 05:18 Go to previous messageGo to next message
I have downloaded mingw what should I else have to compile
my hello.cpp???
Re: is there a page somewhere that discribes [message #62275 is a reply to message #62102] Fri, 14 February 2003 15:49 Go to previous messageGo to next message
> my hello.cpp???
This issue has been answered here some time ago.
Again:
1. Add the MinGW binary path to your PATH environment variable.
How this is done depends on your Windows (98/ME <-> 2k/XP)
2. Make sure, there is an make.exe in that binary path. If not
and you just find an win32-make.exe copy it to make.exe in
the same path.
3. Write an Makefile and save it in your projects top-directory.
4. Compile your project.
Henning
Re: is there a page somewhere that discribes [message #62489 is a reply to message #62275] Tue, 18 February 2003 03:54 Go to previous message
i just did all this.
but still get:
Build Error
(Exec error:Launching failed)
Henning Riedel wrote:
>> my hello.cpp???
> Again:
> the same path.
> Henning
Previous Topic:CDT & M5 ... or any other Eclipse 2.1.0 builds
Next Topic:where can I get the source code and Jar files for eclipse-- UI, SWT,...?
Current Time: Mon Jul 14 19:42:39 EDT 2025
Powered by FUDForum. Page generated in 0.04135 seconds
