Home » Eclipse Projects » Plugin Development Environment (PDE) » Invalid manifest files
Invalid manifest files [message #61939] |
Fri, 15 May 2009 11:14  |
I wrote a wizard which creates new projects in an workspace. These
projects do have a plugin nature (despite other custom natures) and
therefore i need to add plug-in dependencies. For this part, i use
WorkspaceBundlePluginModel from PDE (i know, it's not part of the API,
but i haven't found a better solution).
Anyways, i've noticed that adding additional bundle dependencies, might
lead to an invalid manifest file, since the existing dependencies are
all written to a single line which might exceed the 72 bytes limit. I
dug a bit deeper in the PDE code and i found out that the class
"org.eclipse.osgi.util.ManifestElement.parseBundleManifest() ", which is
used by BundleModel.load() simple eliminates line breaks when parsing
the manifest file, and put all the comma separated values in one line
(with the result described above). I don't think, that this is desired
behaviour. What about you?!
Regards, Ralf
Re: Invalid manifest files [message #61963 is a reply to message #61939] |
Fri, 15 May 2009 11:42   |
Why don't you just rewrite the Manifest file directly (using the
standard Java API classes)? PDE's manifest builder should then take care
of adding in the correct plugin dependencies to the project.
There's been another thread on this on this newsgroup some months ago
and I'm quite successfully using the standard Manifest API classes myself.
Steffen
Ralf Grossklaus wrote:
> Hello,
> Regards, Ralf
Dr. rer. nat. Steffen Zschaler
Senior Research Associate
Lancaster University
Lancaster, United Kingdom
Email szschaler@acm.org
Phone +44 (01524) 510354
WWW http://www.steffen-zschaler.de/
Consider submitting to GPCE, the 8th International Conference
on Generative Programming and Component Engineering
http://www.gpce.org/
Re: Invalid manifest files [message #62149 is a reply to message #61963] |
Mon, 18 May 2009 03:03  |
Hello Steffen,
thanks for the quick reply.
Yes, i could rewrite the manifest file. But the problem with
ManifestElement.parseBundleManifest() remains. It's not only my wizard
that has troubles with invalie manifest files. The standard plug-in
project wizard has the same problem. You can easily test it yourself:
1) Create a new plug-in project 'test' in your workspace (use default
location)
2) add a number of plug-in dependencies to the manifest.
3) delete the project from you workspace, but don't delete the files on
the disk.
4) Create the same project 'test' again (use the same location as before).
The plug-in wizard parses the manifest file, which is already there,
making it invalid (since all plug-in dependencies are now on a single line).
Yes i know, this is not sensible use case. But still, i think a wizard
should not create invalid files silently. It should at least issue some
sort of warning about the existing project. What do you think?
Regards, Ralf!
> Cheers,
> Steffen
>> Hello,
>> Regards, Ralf
Re: Invalid manifest files [message #597537 is a reply to message #61939] |
Steffen
> Hello,
> Regards, Ralf
Re: Invalid manifest files [message #597607 is a reply to message #61963] |
Hello Steffen,
location)
the disk.
Regards, Ralf!
> Cheers,
> Steffen
>> Hello,
>> Regards, Ralf
Current Time: Sat Jul 26 14:40:31 EDT 2025
Powered by FUDForum. Page generated in 0.34988 seconds
