Gallery with widgets instead of images [message #61895] |
Tue, 20 January 2009 09:13  |
Originally posted by: mk.nospam.org
is it possible to have a Gallery widget display other widgets instead of
images only?
The use-case for this would be some kind of monitoring dashboard that
displays e.g. the performance of several production lines each
visualized by a custom widget with some current numbers, state and
buttons for access to further detailed information.
Thanks in advance for your feedback.
Martin Klinke
Re: Gallery with widgets instead of images [message #62399 is a reply to message #61942] |
Thu, 29 January 2009 12:54  |
Hi Martin, Baptiste
This is not supported out of the box, but you can try the following :
- You can create your own ItemRenderer : You can draw whatever you want
instead of an Image and a label. The groupRenderer also be updated to
forward mouse clicks to the item renderer. You can also try to create a
widget and move it to the right possition.
OR add a paint listener to the Gallery : take a look at
CustomDrawSnippet (org.eclipse.nebula.snippets)
- You can use a GridLayout to display widgets like the Gallery widget
does for images. This was what I tried first before creating a custom
widget. Even if using GridLayout and Label to display images is far too
slow, it can be useable for your usecase.
Nicolas
baptiste a écrit :
> I don't thing it is possible for the moment, although such a
> functionality would be awesome. It would allow the gallery widget to be
> used in many more situations.
> Baptiste
Re: Gallery with widgets instead of images [message #593464 is a reply to message #61942] |
Hi Martin, Baptiste
Nicolas
baptiste a écrit :
> Baptiste
FUDForum. Page generated in 0.03573 seconds
