Home » Language IDEs » ServerTools (WTP) » Preview HTML Editor
Preview HTML Editor [message #61884] |
Wed, 05 January 2005 22:26  |
Originally posted by: mdiggory.apache.org
I notice there a nice example of a multipage source/preview editor in
the HTML portion of the project. Is there a simple way I can use this
editor for HTML instead of of the current single page editor, or are
there plans to make this example preview editor the default for the HTML
editor plugin?
-Mark
Re: Preview HTML Editor [message #63076 is a reply to message #61928] |
Fri, 07 January 2005 12:31   |
Your correct, after more consideration I feel the ultimate awkwardness
here is that there is an HTMLEditor and a BrowserEditor, so, say I'm
authoring and HTML doc and I want to View it in the BrowserEditor, the I
have to close it in the HTML editor and Open it in the BrowserEditor.
What would be much more powerful would be to have a BrowserView with the
same capabilities of BrowserEditor (I mean really, what good is a
BrowserEditor, it supplys no "Editing" functionality and on top of this,
I can navigate away for the page I'm "Editing"). So, in that light, even
a Multipage source/preview html editor is wonky.
What I would recommend as a solution to this design issue would be to
move away from supplying a BrowserEditor and instead provide a
BrowserView linked to the source editor in the same way as the
Properties or Outline View. This browserView could then be used in
concert with the editor in the same way that the OutlineView or
PropertiesView is used. When you open an HTML page in the HTML Editor,
the editor supplies content info to the BrowserView for rendering that page.
-Mark
>> HTML editor plugin?
> You can use the PDE to create an Ant build.xml from its plugin.xml and
> then run Ant to build a .zip to package it so you can run it as part of
> your environment. Once it's running you're free to change the file
> associations as you'd like.
> There are no plans to make this the default since it's 1) really just an
> example showing that it's as easy to embed as the default text editor 2)
> missing the status bar you see in the HTML Source Page editor and 3)
> we'd like to see real editors created and used instead.
> - Nitin
Re: Preview HTML Editor [message #63193 is a reply to message #63164] |
Fri, 07 January 2005 14:52   |
David Williams wrote:
> On Fri, 07 Jan 2005 12:31:54 -0500, Mark Diggory <mdiggory@apache.org>
> This is a good idea (volunteering? :)
Sure, I'd be glad to donate back in. I need this view for my current
project, but would like to see it in the right place. I'm new to the
Eclipse cvs/newsgroups (joined last fall) but have spent considerable
time over the last few years helping out as a commiter at Apache.
> I'd also like communities opinon on another "twist" to this idea. It
> seems that a
> view of the "static" HTML is pretty limitied ... only good for those
> cases where the
> HTML is in fact static ... for cases where you need to "run" the page to
> get accurate view,
> perhaps the browser view should in fact be our web browser? (That you
> currently get in
> editor site when you "run on server"). ... I'm just curious as to
> relative weight of need
> for static vs. need for dynamic views. [not that I'm voluntering :) ]
Have you seen the JTidy example? Here a split pane is used to show
before and after results of running JTidy in SWT Browser Widgets
http://www.devx.com/opensource/Article/22118/0/page/1
Point being that in one case the HTML is actually getting loaded from a
dynamic source (JTidy)
Not fully grokking the Architecture of a Web application project, I'm
only guessing. But, I would think that if your working with any editor
(Html, JSP, css, javascript) etc. Its still the "Nature" of the project
your in that would determine how url's or the html content itself was
fed to the browser view.
I also think, in reviewing the WebBrowser code, that WebBrowser itself
is very similar to a "Viewer" wrapping a Browser control and should
probably be sporting the JFace Viewer Interface.
Reviewing the Models behind ContentOutlineView and PropertiesPageView.
logically, we end up with a View shell that listens for editor
selectionChange events and acquires the WebBrowser in an IWebBrowserPage
delivered by the Editor
The analogy is to that of:
http://help.eclipse.org/help30/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/editors_workbench_outliner.htm
and
http://help.eclipse.org/help30/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench_resources.htm
-Mark
Re: Preview HTML Editor [message #63289 is a reply to message #63193] |
Fri, 07 January 2005 15:57   |
In fact, such a viewer framework should actually be much higher in the
dependencies of Eclipse, within the platform project, not here in
webtools. It would place the BrowserView in "org.eclipse.ui.views" and
the BrowserViewer used within it up in "org.eclipse.jface".
I suspect the big issue then would be where to place the browser
"preferences".
-Mark
>> seems that a
>> cases where the
>> to get accurate view,
>> currently get in
> and
> -Mark
Re: Preview HTML Editor [message #65164 is a reply to message #65096] |
Wed, 12 January 2005 21:05  |
I agree, both have their place. The underlying implementation is pretty
much the same. Its just a difference of Implemented Interface, ViewPart
vs EditorPart...
-Mark
>> seems that a
>> cases where the
>> currently get in
> Whilst I feel that a browser is often a view, it is also often an
> editor. As you say there is the static Vs dynamic issue. With respect to
> "weight of need". For our purposes the editor is more important at this
> tie, we have a wealth of interfaces that are already XHTML based. Our
> server app is being packaged as an RCP application and we want to stick
> to the same interfaces the client would see.
> That being said, I think the arguments for a browser view have merit. We
> should really have both, but since my project needs the browser editor
> I'm not volunteering either ;-)
> Ross
Current Time: Sun Jul 27 03:02:16 EDT 2025
Powered by FUDForum. Page generated in 0.04319 seconds
