Home » Eclipse Projects » GEF » Please help me debug this
Please help me debug this [message #61857] Tue, 04 February 2003 10:31 Go to next message
Originally posted by: jim.azeltine.indus.com
I am working on an app based on the Shapes example. I have most of it
working, the plugin loads, the editor with a palette opens, but I get a
null pointer exception when I click on one of the pallette items. I cannot
seem to figure out where to put breakpoints in order to figure out what is
null.
Jim
Re: Please help me debug this [message #61882 is a reply to message #61857] Tue, 04 February 2003 11:14 Go to previous messageGo to next message
The shapes example is not up-to-date. It is not supported by the GEF team.
Eclipse let's you set an exception breakpoint. Before you open your editor,
but after the runtime workbench has started, add an exception breakpoint for
NullPointerException.
"Jim Azeltine" <jim.azeltine@indus.com> wrote in message
news:b1omc9$oqe$1@rogue.oti.com...
> null.
> Jim
Re: Please help me debug this [message #61931 is a reply to message #61882] Tue, 04 February 2003 11:17 Go to previous messageGo to next message
> > null.
> > Jim
I understand that the Shapes example is not supported. Eric has made noise
about porting it to the new release, but I don't know if he will have
time. He directed me to an old version of Eclipse where is works (prior to
the renaming of the packages from com.ibm.etools). The Shapes example is
the closest to what I am attempting to develop.
Thanks, the hint about exception breakpoints helps alot! 8)
I have found that the exception is occurring in PaletteViewerImpl:
protected void firePaletteSelectionChanged() {
if (paletteListeners == null)
return;
PaletteEvent event = new PaletteEvent(this, selectedEntry);
for (int listener = 0; listener < paletteListeners.size(); listener++)
((PaletteListener) paletteListeners.get(listener)).entrySelected(
event);
In the paletteListeners ArrayList element [0] is null, element [1]=
DefaultEditDomain$1. What should be in element [0]?
Re: Please help me debug this [message #61953 is a reply to message #61931] Tue, 04 February 2003 12:03 Go to previous messageGo to next message
news:b1op2k$r39$1@rogue.oti.com...
team.
editor,
for
a
cannot
what is
> > > null.
> > > Jim
> return;
> event);
Someone must be calling addPaletteListener(null).
Put a *conditional* breakpoint in addPaletteListener, and set its conditions
to listener == null.
Re: Please help me debug this [message #62091 is a reply to message #61953] Wed, 05 February 2003 09:49 Go to previous message
> team.
> editor,
> for
> a
> cannot
> what is
> > > > null.
> > > > Jim
> > return;
> > event);
I think I found the problem. In class GraphicalEditorWithPalette, there is
a call to viewer.addPaletteListener that did not exist in earlier drops:
private void createPaletteViewer(Composite parent) {
PaletteViewer viewer = new PaletteViewerImpl();
viewer.createControl(parent);
setPaletteViewer(viewer);
viewer.addPaletteListener((CopyTemplateAction)getAction(IWor kbenchActionConstants.COPY));
configurePaletteViewer();
hookPaletteViewer();
initializePaletteViewer();
It does not seem to make sense to pass type CopyTemplateAction to
addPaletteListener. I replaced the class in my gef.jar with an earlier
version, and the Shapes example works ok.
Previous Topic:TreeItems instead of Figures
Next Topic:Change figure of an edit part dynamically
Current Time: Sat Jul 26 15:58:31 EDT 2025
Powered by FUDForum. Page generated in 0.03745 seconds
