Home » Eclipse Projects » Equinox » sword4j error
sword4j error [message #61843] |
Thu, 16 February 2006 05:02 |
Hello all,
I try to use sword4j to analyse a plugin project using the
Security>Analyse popup menu. I get next error :
java.lang.IllegalArgumentException: Argument not valid
at org.eclipse.swt.SWT.error(SWT.java:2926)
at org.eclipse.swt.SWT.error(SWT.java:2865)
at org.eclipse.swt.SWT.error(SWT.java:2836)
at org.eclipse.swt.custom.CTabItem.setImage(CTabItem.java:736)
com.ibm.security.j2sesa.views.PermissionView.createPartContr ol(PermissionView.java:1334)
org.eclipse.ui.internal.ViewReference.createPartHelper(ViewR eference.java:305)
at org.eclipse.ui.internal.ViewReference.createPart(ViewReferen ce.java:180)
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:552)
at org.eclipse.ui.internal.Perspective.showView(Perspective.jav a:1655)
org.eclipse.ui.internal.WorkbenchPage.busyShowView(Workbench Page.java:930)
at org.eclipse.ui.internal.WorkbenchPage.access$12(WorkbenchPag e.java:913)
at org.eclipse.ui.internal.WorkbenchPage$13.run(WorkbenchPage.j ava:3148)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
at org.eclipse.ui.internal.WorkbenchPage.showView(WorkbenchPage .java:3145)
at org.eclipse.ui.internal.WorkbenchPage.showView(WorkbenchPage .java:3123)
org.eclipse.ui.handlers.ShowViewHandler.openView(ShowViewHan dler.java:146)
org.eclipse.ui.handlers.ShowViewHandler.openOther(ShowViewHa ndler.java:102)
at org.eclipse.ui.handlers.ShowViewHandler.execute(ShowViewHand ler.java:70)
at org.eclipse.ui.internal.ShowViewMenu$3.run(ShowViewMenu.java :113)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:996 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:538)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1021)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2867)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2572)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
I'm running Eclipse 3.1.0( Build id: I20050627-1435) with sword4j :
- Jalinspector Version: 1.0.16 Build id: 200510260900
- JarSigner Version: 1.0.7 Build id: 200510260900
- Security Workbench Development for Java (SWORD4J) Version: 1.0.45
build id: 200510260900
Have anyone met this error? Should I install something? or run some
other plugin?
Thank you,
Stefan.
PS: here is "configuration details" output:
*** Date: Thu Feb 16 10:04:54 EET 2006
*** Platform Details:
*** System properties:
ANTLR_DO_NOT_EXIT=true
ANTLR_USE_DIRECT_CLASS_LOADING=true
catalina.base=/myhome/eclipse/plugins/org.eclipse.tomcat_4.1 .30.1/
catalina.home=/myhome/eclipse/plugins/org.eclipse.tomcat_4.1 .30.1/
catalina.useNaming=true
eclipse.application=org.eclipse.ui.ide.workbench
eclipse.buildId=I20050627-1435
eclipse.commands=-os
linux
-ws
gtk
-arch
x86
-launcher
/myhome/eclipse/eclipse
-name
Eclipse
-showsplash
600
-exitdata
240010
-Dide.gc=true
-vm
/usr/java/jdk1.5.0_05/bin/java
eclipse.product=org.eclipse.sdk.ide
eclipse.startTime=1140075192271
eclipse.vm=/usr/java/jdk1.5.0_05/bin/java
eclipse.vmargs=-Xms100m
-Xmx256m
-Xss10m
-jar
/myhome/eclipse/startup.jar
eof=eof
file.encoding=UTF-8
file.encoding.pkg=sun.io
file.separator=/
java.awt.graphicsenv=sun.awt.X11GraphicsEnvironment
java.awt.printerjob=sun.print.PSPrinterJob
java.class.path=/myhome/eclipse/startup.jar
java.class.version=49.0
java.endorsed.dirs=/usr/java/jdk1.5.0_05/jre/lib/endorsed
java.ext.dirs=/usr/java/jdk1.5.0_05/jre/lib/ext
java.home=/usr/java/jdk1.5.0_05/jre
java.io.tmpdir=/tmp
java.library.path=/usr/java/jdk1.5.0_05/jre/lib/i386/client: /usr/java/jdk1.5.0_05/jre/lib/i386:/usr/java/jdk1.5.0_05/jre /../lib/i386:/usr/lib/mozilla-1.7.12
java.naming.factory.initial=org.apache.naming.java.javaURLCo ntextFactory
java.naming.factory.url.pkgs=org.apache.naming
java.runtime.name=Java(TM) 2 Runtime Environment, Standard Edition
java.runtime.version=1.5.0_05-b05
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.5
java.vendor.url=http://java.sun.com/
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
java.version=1.5.0_05
java.vm.info=mixed mode, sharing
java.vm.name=Java HotSpot(TM) Client VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Sun Microsystems Inc.
java.vm.version=1.5.0_05-b05
line.separator=
org.eclipse.jdt.debug.ui.scrapbookActive=false
org.osgi.framework.bootdelegation=*
org.osgi.framework.executionenvironment=J2SE-1.5
org.osgi.framework.language=en
org.osgi.framework.os.name=Linux
org.osgi.framework.os.version=2.6.11-1.1369_FC4
org.osgi.framework.processor=i386
org.osgi.framework.system.packages=javax.accessibility,javax .activity,javax.crypto,javax.crypto.interfaces,javax.crypto. spec,javax.imageio,javax.imageio.event,javax.imageio.metadat a,javax.imageio.plugins.bmp,javax.imageio.plugins.jpeg,javax .imageio.spi,javax.imageio.stream,javax.management,javax.man agement.loading,javax.management.modelmbean,javax.management .monitor,javax.management.openmbean,javax.management.relatio n,javax.management.remote,javax.management.remote.rmi,javax. management.timer,javax.naming,javax.naming.directory,javax.n aming.event,javax.naming.ldap,javax.naming.spi,javax.net,jav ax.net.ssl,javax.print,javax.print.attribute,javax.print.att ribute.standard,javax.print.event,javax.rmi,javax.rmi.CORBA, javax.rmi.ssl,javax.security.auth,javax.security.auth.callba ck,javax.security.auth.kerberos,javax.security.auth.login,ja vax.security.auth.spi,javax.security.auth.x500,javax.securit y.cert,javax.security.sasl,javax.sound.midi,javax.sound.midi .spi,javax.sound.sampled,javax
sound.sampled.spi,javax.sql,javax.sql.rowset,javax.sql.rowse t.serial,javax.sql.rowset.spi,javax.swing,javax.swing.border ,javax.swing.colorchooser,javax.swing.event,javax.swing.file chooser,javax.swing.plaf,javax.swing.plaf.basic,javax.swing. plaf.metal,javax.swing.plaf.multi,javax.swing.plaf.synth,jav ax.swing.table,javax.swing.text,javax.swing.text.html,javax. swing.text.html.parser,javax.swing.text.rtf,javax.swing.tree ,javax.swing.undo,javax.transaction,javax.transaction.xa,jav ax.xml,javax.xml.datatype,javax.xml.namespace,javax.xml.pars ers,javax.xml.transform,javax.xml.transform.dom,javax.xml.tr ansform.sax,javax.xml.transform.stream,javax.xml.validation, javax.xml.xpath,org.ietf.jgss,org.omg.CORBA,org.omg.CORBA_2_ 3,org.omg.CORBA_2_3.portable,org.omg.CORBA.DynAnyPackage,org .omg.CORBA.ORBPackage,org.omg.CORBA.portable,org.omg.CORBA.T ypeCodePackage,org.omg.CosNaming,org.omg.CosNaming.NamingCon textExtPackage,org.omg.CosNaming.NamingContextPackage,org.om g.Dynamic,org.omg.DynamicAny,
org.omg.DynamicAny.DynAnyFactoryPackage,org.omg.DynamicAny.D ynAnyPackage,org.omg.IOP,org.omg.IOP.CodecFactoryPackage,org .omg.IOP.CodecPackage,org.omg.Messaging,org.omg.PortableInte rceptor,org.omg.PortableInterceptor.ORBInitInfoPackage,org.o mg.PortableServer,org.omg.PortableServer.CurrentPackage,org. omg.PortableServer.POAManagerPackage,org.omg.PortableServer. POAPackage,org.omg.PortableServer.portable,org.omg.PortableS erver.ServantLocatorPackage,org.omg.SendingContext,org.omg.s tub.java.rmi,org.w3c.dom,org.w3c.dom.bootstrap,org.w3c.dom.e vents,org.w3c.dom.ls,org.xml.sax,org.xml.sax.ext,org.xml.sax .helpers
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.3.0
org.osgi.supports.framework.extension=true
os.arch=i386
os.name=Linux
osgi.arch=x86
osgi.bundles=org.eclipse.core.runtime@2:start,
org.eclipse.update.configurator@3:start
osgi.bundlestore=/myhome/eclipse/configuration/org.eclipse.o sgi/bundles
osgi.configuration.area=file:/myhome/eclipse/configuration/
osgi.framework=file:/myhome/eclipse/plugins/org.eclipse.osgi _3.1.0.jar
osgi.framework.beginningstartlevel=1
osgi.framework.shape=jar
osgi.framework.version=3.0.0
osgi.install.area=file:/myhome/eclipse/
osgi.instance.area=file:/myhome/workspace/
osgi.instance.area.default=file:/myhome/workspace/
osgi.logfile=/myhome/workspace/.metadata/.log
osgi.manifest.cache=/myhome/eclipse/configuration/org.eclips e.osgi/manifests
osgi.nl=en_US
osgi.os=linux
osgi.splashLocation=/myhome/eclipse/plugins/org.eclipse.plat form_3.1.0/splash.bmp
osgi.splashPath=platform:/base/plugins/org.eclipse.platform
osgi.syspath=/myhome/eclipse/plugins
osgi.ws=gtk
path.separator=:
sun.arch.data.model=32
sun.boot.class.path=/usr/java/jdk1.5.0_05/jre/lib/rt.jar:/us r/java/jdk1.5.0_05/jre/lib/i18n.jar:/usr/java/jdk1.5.0_05/jr e/lib/sunrsasign.jar:/usr/java/jdk1.5.0_05/jre/lib/jsse.jar: /usr/java/jdk1.5.0_05/jre/lib/jce.jar:/usr/java/jdk1.5.0_05/ jre/lib/charsets.jar:/usr/java/jdk1.5.0_05/jre/classes
sun.boot.library.path=/usr/java/jdk1.5.0_05/jre/lib/i386
sun.cpu.endian=little
sun.cpu.isalist=
sun.desktop=gnome
sun.io.unicode.encoding=UnicodeLittle
sun.jnu.encoding=UTF-8
sun.management.compiler=HotSpot Client Compiler
sun.net.client.defaultConnectTimeout=60000
sun.net.client.defaultReadTimeout=60000
sun.os.patch.level=unknown
user.country=US
user.dir=/myhome
user.home=/myhome
user.language=en
user.name=stefan
user.timezone=Europe/Bucharest
*** Features:
com.ibm.security.j2sesa (1.0.45) "SWORD4J"
com.ibm.security.jarinspector (1.0.16) "JaIinspector"
com.ibm.security.jarsigner (1.0.7) "Jarsigner Plug-in"
net.sf.fjep.fatjar (0.0.20) "Fat Jar Plug-in"
net.sourceforge.metrics (1.3.6) "metrics Plug-in"
org.eclipse.cdt (2.1.1) "Eclipse C/C++ Development Tools"
org.eclipse.cdt.sdk (2.1.1) "Eclipse C/C++ Development Tools SDK"
org.eclipse.cdt.source (2.1.1) "Eclipse C/C++ Development Tools (Source)"
org.eclipse.emf (2.1.1.M200509081004) "Eclipse Modeling Framework (EMF)"
org.eclipse.emf.doc (2.1.1.M200509081004) "Eclipse Modeling Framework
(EMF) Programmers Guide"
org.eclipse.emf.ecore.sdo (2.1.1.M200509081004) "EMF Service Data
Objects (SDO)"
org.eclipse.emf.ecore.sdo.doc (2.1.1.M200509081004) "EMF Service Data
Objects (SDO) Programmers Guide"
org.eclipse.emf.ecore.sdo.source (2.1.1.M200509081004) "EMF Service Data
Objects (SDO) Source"
org.eclipse.emf.source (2.1.1.M200509081004) "Eclipse Modeling Framework
(EMF) Source"
org.eclipse.gef (3.1.1) "Graphical Editing Framework"
org.eclipse.gef.examples (3.1.1) "GEF Examples"
org.eclipse.gef.sdk (3.1.1) "Graphical Editing Framework Developer
Resources"
org.eclipse.gef.source (3.1.1) "Graphical Editing Framework Developer
Resources"
org.eclipse.jdt (3.1.0) "Eclipse Java Development Tools"
org.eclipse.jdt.source (3.1.0) "Eclipse Java Development Tools SDK"
org.eclipse.jem (1.1.0.1) "Java EMF Model"
org.eclipse.jem.sdk (1.1.0.1) "Java EMF Model SDK"
org.eclipse.jem.source (1.1.0.1) "Java EMF Model Source"
org.eclipse.jst (0.7.0) "J2EE Standard Tools"
org.eclipse.jst.sdk (0.7.0) "J2EE Standard Tools SDK"
org.eclipse.pde (3.1.0) "Eclipse Plug-in Development Environment"
org.eclipse.pde.source (3.1.0) "Eclipse Plug-in Development Environment
Developer Resources"
org.eclipse.platform (3.1.0) "Eclipse Platform"
org.eclipse.platform.source (3.1.0) "Eclipse Platform Plug-in Developer
Resources"
org.eclipse.rcp (3.1.0) "Eclipse RCP"
org.eclipse.rcp.source (3.1.0) "Eclipse RCP Plug-in Developer Resources"
org.eclipse.sdk (3.1.0) "Eclipse Project SDK"
org.eclipse.sdk.examples (3.1.0) "Eclipse SDK Examples"
org.eclipse.sdk.samples (3.1.0) "Experimental Eclipse SDK Samples"
org.eclipse.team.extras (3.1.0) "Eclipse FTP and WebDAV Support"
org.eclipse.test (3.1.0) "Eclipse Automated Testing"
org.eclipse.tptp.monitoring.source (4.0.0) "TPTP Monitoring Source"
org.eclipse.tptp.platform.analysis.engine.source (4.0.0) "TPTP Analysis
Engine Source"
org.eclipse.tptp.platform.analysis.source (4.0.0) "TPTP Analysis Source"
org.eclipse.tptp.platform.core.source (4.0.0) "TPTP Core Source"
org.eclipse.tptp.platform.lta.source (4.0.0) "TPTP Log and Trace
Analyzer Source"
org.eclipse.tptp.platform.probekit.source (4.0.0) "TPTP ProbeKit Source"
org.eclipse.tptp.platform.report.source (4.0.0) "TPTP Charting Service
Source"
org.eclipse.tptp.platform.samples.source (4.0.0) "TPTP Platform Samples
Source"
org.eclipse.tptp.platform.statistical.ui.source (4.0.0) "TPTP
Statistical UI Source"
org.eclipse.tptp.platform.trace.source (4.0.0) "TPTP Platform Trace Source"
org.eclipse.tptp.test.samples (4.0.0) "TPTP Test Tools UI Plug-In"
org.eclipse.tptp.test.samples.source (4.0.0) "TPTP Test Samples Source"
org.eclipse.tptp.test.source (4.0.0) "TPTP Test Source"
org.eclipse.tptp.test.tools.source (4.0.0) "TPTP Test Tools Source"
org.eclipse.tptp.trace.source (4.0.0) "TPTP Trace Source"
org.eclipse.uml2 (1.1.1.M200509221052) "UML2"
org.eclipse.uml2.doc (1.1.1.M200509221052) "UML2 Documentation"
org.eclipse.uml2.examples (1.1.1.M200509221052) "UML2 Examples"
org.eclipse.uml2.examples.source (1.1.1.M200509221052) "UML2 Examples
Source"
org.eclipse.uml2.source (1.1.1.M200509221052) "UML2 Source"
org.eclipse.ve (1.1.0.1) "Visual Editor"
org.eclipse.ve.sdk (1.1.0.1) "Visual Editor SDK"
org.eclipse.ve.source (1.1.0.1) "Visual Editor Source"
org.eclipse.wst (0.7.0) "Web Standard Tools"
org.eclipse.wst.sdk (0.7.0) "Web Standard Tools SDK"
org.eclipse.xsd (2.1.1.M200509081004) "XML Schema Infoset Model (XSD)"
org.eclipse.xsd.doc (2.1.1.M200509081004) "XML Schema Infoset Model
(XSD) Programmers Guide"
org.eclipse.xsd.source (2.1.1.M200509081004) "XML Schema Infoset Model
(XSD) Source"
*** Plug-in Registry:
com.atlassw.tools.eclipse.checkstyle (4.0.0) "Checkstyle Plug-in" [Active]
com.ibm.etools.emf.event (3.0.0.1) "Event Model" [Resolved]
com.ibm.security.j2sesa (1.0.45) "SWORD4J" [Active]
com.ibm.security.jarinspector (1.0.15) "JaIinspector" [Active]
com.ibm.security.jarsigner (1.0.7) "Jarsigner Plug-in" [Active]
com.ibm.security.javatreewidget (1.0.1) "Javatreewidget Plug-in" [Active]
com.ibm.security.keystore (1.0.1) "Keystore Plug-in" [Active]
com.ibm.security.keystoreeditor (1.0.5) "Keystoreeditor Plug-in" [Resolved]
com.ibm.security.sword4j.help (1.0.5) "SWORD4J Help Plug-in" [Resolved]
com.ibm.security.tests.checkSecurity (1.0.0) "CheckSecurity Plug-in"
[Active]
com.ibm.shrike (1.0.1) "Shrike Plug-in" [Active]
jadclipse (3.1.0) "JadClipse" [Resolved]
net.sf.fjep.fatjar (0.0.20) "Fat Jar Plug-in" [Resolved]
net.sourceforge.metrics (1.3.6) "metrics Plug-in" [Resolved]
org.antlr (2.7.6.b2) "Antlr Plug-in" [Resolved]
org.antlr.doc (2.7.6.b2) "ANTLR Documentation" [Resolved]
org.antlr.eclipse.core (4.0.0.b2) "ANTLR Core Plugin" [Active]
org.antlr.eclipse.ui (4.0.0.b2) "ANTLR UI Plugin" [Active]
org.apache.ant (1.6.5) "Apache Ant" [Resolved]
org.apache.axis (1.2.1) "Axis121 Plug-in" [Resolved]
org.apache.batik (1.5.5) "Batik SVG Toolkit" [Installed]
org.apache.batik (1.5.1) "SVG Batik Toolkit" [Resolved]
org.apache.jakarta_commons_logging (1.0.3) "Jakarta Commons Logging"
[Resolved]
org.apache.jakarta_log4j_logging (1.2.8) "Jakarta Log4J Logging" [Resolved]
org.apache.lucene (1.4.3) "Apache Lucene" [Resolved]
org.apache.wsil4j (1.0.0) "Apache WSIL4J 1.0" [Resolved]
org.apache.xerces (2.7.0) "Xerces 2.7.0" [Resolved]
org.eclipse.ant.core (3.1.0) "Ant Build Tool Core" [Resolved]
org.eclipse.ant.optional.junit (2.1.0) "Junit Fragment" [Resolved]
org.eclipse.ant.ui (3.1.0) "Ant UI" [Resolved]
org.eclipse.cdt (2.1.1) "Eclipse C/C++ Development Tools" [Resolved]
org.eclipse.cdt.core (2.1.1) "C/C++ Development Tools Core" [Active]
org.eclipse.cdt.core.linux (2.1.1) "C/C++ Development Tools Core for
Linux" [Resolved]
org.eclipse.cdt.debug.core (2.1.1) "C/C++ Development Tools Debug Model"
[Resolved]
org.eclipse.cdt.debug.mi.core (2.1.1) "C/C++ Development Tools GDB/MI
CDI Debugger Core" [Resolved]
org.eclipse.cdt.debug.mi.ui (2.1.1) "C/C++ Development Tools GDB/MI CDI
Debugger UI" [Resolved]
org.eclipse.cdt.debug.ui (2.1.1) "C/C++ Development Tools Debugger UI"
[Resolved]
org.eclipse.cdt.doc.user (2.1.1) "C/C++ Development User Guide" [Resolved]
org.eclipse.cdt.launch (2.1.1) "C/C++ Development Tools Launching
Support" [Resolved]
org.eclipse.cdt.make.core (2.1.1) "C/C++ Standard make Build Core"
[Resolved]
org.eclipse.cdt.make.ui (2.1.1) "C/C++ Standard make Build UI" [Active]
org.eclipse.cdt.managedbuilder.core (2.1.1) "C/C++ Managed Builder Core"
[Resolved]
org.eclipse.cdt.managedbuilder.ui (2.1.1) "C/C++ Managed Builder UI"
[Resolved]
org.eclipse.cdt.sdk (2.1.1) "Eclipse C/C++ Development Tools SDK" [Resolved]
(Source)" [Resolved]
org.eclipse.cdt.source.linux.gtk.x86 (2.1.1) "Eclipse C/C++ Development
Tools (Source)" [Resolved]
org.eclipse.cdt.ui (2.1.1) "C/C++ Development Tools UI" [Active]
org.eclipse.compare (3.1.0) "Compare Support" [Active]
org.eclipse.compare.examples (3.1.0) "Compare Example" [Resolved]
org.eclipse.compare.examples.xml (3.1.0) "XML Compare Support" [Resolved]
org.eclipse.core.boot (3.1.0) "Core Boot" [Resolved]
org.eclipse.core.commands (3.1.0) "Commands" [Active]
org.eclipse.core.expressions (3.1.0) "Expression Language" [Active]
org.eclipse.core.filebuffers (3.1.0) "File Buffers" [Active]
org.eclipse.core.resources (3.1.0) "Core Resource Management" [Active]
org.eclipse.core.resources.compatibility (3.1.0) "Core Resource
Management Compatibility Fragment" [Resolved]
org.eclipse.core.resources.linux (3.1.0) "Core Resource Management Linux
org.eclipse.core.runtime (3.1.0) "Core Runtime" [Active]
org.eclipse.core.runtime.compatibility (3.1.0) "Core Runtime Plug-in
Compatibility" [Active]
org.eclipse.core.variables (3.1.0) "Core Variables" [Resolved]
org.eclipse.debug.core (3.1.0) "Debug Core" [Active]
org.eclipse.debug.ui (3.1.0) "Debug UI" [Active]
org.eclipse.draw2d (3.1.1) "Draw2d" [Resolved]
org.eclipse.draw2d.doc.isv (3.1.1) "Draw2D Documentation" [Resolved]
[Resolved]
org.eclipse.emf.ant (2.1.0.M200509081004) "EMF Ant Tasks" [Resolved]
org.eclipse.emf.codegen (2.1.0.M200509081004) "EMF Template Code
Generator" [Resolved]
org.eclipse.emf.codegen.ecore (2.1.0.M200509081004) "EMF Ecore Code
Generation" [Resolved]
org.eclipse.emf.codegen.ecore.ui (2.1.0.M200509081004) "EMF Ecore Code
Generation UI" [Resolved]
org.eclipse.emf.codegen.ui (2.1.0.M200509081004) "EMF Template Code
Generator UI" [Resolved]
org.eclipse.emf.common (2.1.0.M200509081004) "EMF Common" [Active]
org.eclipse.emf.common.ui (2.1.0.M200509081004) "EMF Common UI" [Resolved]
org.eclipse.emf.commonj.sdo (2.1.0.M200509081004) "CommonJ SDO" [Resolved]
(EMF) Programmers Guide" [Resolved]
org.eclipse.emf.ecore (2.1.0.M200509081004) "EMF Ecore" [Active]
org.eclipse.emf.ecore.change (2.1.0.M200509081004) "EMF Ecore Change
Model" [Resolved]
org.eclipse.emf.ecore.change.edit (2.1.0.M200509081004) "EMF Ecore
Change Edit Support" [Resolved]
org.eclipse.emf.ecore.edit (2.1.1.M200509081004) "EMF Ecore Edit
Support" [Resolved]
org.eclipse.emf.ecore.editor (2.1.0.M200509081004) "Sample Ecore Editor"
[Resolved]
Objects (SDO)" [Resolved]
Objects (SDO) Programmers Guide" [Resolved]
org.eclipse.emf.ecore.sdo.edit (2.1.0.M200509081004) "EMF Service Data
Objects (SDO) Edit Support" [Resolved]
org.eclipse.emf.ecore.sdo.editor (2.1.0.M200509081004) "EMF Service Data
Objects (SDO) Editor" [Resolved]
Objects (SDO) Source" [Resolved]
org.eclipse.emf.ecore.xmi (2.1.0.M200509081004) "EMF XMI" [Resolved]
org.eclipse.emf.edit (2.1.1.M200509081004) "EMF Edit" [Resolved]
org.eclipse.emf.edit.ui (2.1.0.M200509081004) "EMF Edit UI" [Resolved]
org.eclipse.emf.importer (2.1.0.M200509081004) "EMF Model Import
Support" [Resolved]
org.eclipse.emf.importer.ecore (2.1.0.M200509081004) "EMF Ecore
Importer" [Resolved]
org.eclipse.emf.importer.java (2.1.1.M200509081004) "EMF Annotated Java
org.eclipse.emf.importer.rose (2.1.1.M200509081004) "EMF Rose Importer"
[Resolved]
org.eclipse.emf.mapping (2.1.0.M200509081004) "EMF Mapping" [Resolved]
org.eclipse.emf.mapping.ecore2ecore (2.1.0.M200509081004) "Ecore to
Ecore Mapping" [Resolved]
org.eclipse.emf.mapping.ecore2ecore.editor (2.1.0.M200509081004) "Ecore
to Ecore Mapping Editor" [Resolved]
org.eclipse.emf.mapping.ecore2xml (2.1.0.M200509081004) "Ecore to XML
Mapping" [Resolved]
org.eclipse.emf.mapping.ecore2xml.ui (2.1.1.M200509081004) "Ecore to XML
Mapping UI" [Resolved]
org.eclipse.emf.mapping.ui (2.1.0.M200509081004) "EMF Mapping UI" [Resolved]
org.eclipse.emf.mapping.xsd2ecore (2.1.0.M200509081004) "XSD to Ecore
Mapping" [Resolved]
org.eclipse.emf.mapping.xsd2ecore.editor (2.1.0.M200509081004) "XSD to
(EMF) Source" [Resolved]
org.eclipse.ftp (1.0.0) "Ftp Plug-in" [Resolved]
org.eclipse.gef (3.1.1) "Graphical Editing Framework" [Resolved]
org.eclipse.gef.doc.isv (3.1.1) "Graphical Editing Framework
org.eclipse.gef.examples.flow (3.1.1) "GEF Flow Editor Example" [Resolved]
org.eclipse.gef.examples.logic (3.1.1) "GEF Logic Editor Example" [Resolved]
org.eclipse.gef.examples.shapes (3.1.1) "GEF Shape Editor Example"
[Resolved]
org.eclipse.gef.examples.source (3.1.1) "GEF Examples" [Resolved]
org.eclipse.gef.examples.text (3.1.1) "GEF Text Editor Example" [Resolved]
Resources" [Resolved]
org.eclipse.help (3.1.0) "Help System Core" [Active]
org.eclipse.help.appserver (3.1.0) "Help Application Server" [Active]
org.eclipse.help.base (3.1.0) "Help System Base" [Active]
org.eclipse.help.examples.ex1 (3.1.0) "Online Help Sample" [Resolved]
org.eclipse.help.ui (3.1.0) "Help System UI" [Active]
org.eclipse.help.webapp (3.1.0) "Help System Webapp" [Active]
org.eclipse.hyades.analysis.engine (4.0.0) "Hyades Analysis Engine"
[Resolved]
org.eclipse.hyades.execution (4.0.0) "TPTP Platform Execution Plug-In"
[Resolved]
org.eclipse.hyades.execution.correlation (4.0.0) "Hyades Runtime
Correlation Engine" [Resolved]
org.eclipse.hyades.execution.trace (4.0.0) "Hyades Execution Trace"
[Resolved]
org.eclipse.hyades.logging.adapter (4.0.0) "TPTP Monitoring Project
Generic Log Adapter" [Resolved]
org.eclipse.hyades.logging.adapter.ui (4.0.0) "Generic Adapter UI"
[Resolved]
org.eclipse.hyades.logging.core (4.0.0) "Hyades Logging Agent, Common
Base Events and Logging Facility Support" [Resolved]
org.eclipse.hyades.logging.core.sample (4.0.0) "Sample for Hyades
Logging Agent, Common Base Events and Logging Facility Support" [Resolved]
org.eclipse.hyades.logging.parsers (4.0.0) "TPTP Monitoring Project Log
File Parsers" [Resolved]
org.eclipse.hyades.perfmon (4.0.0) "Perfmon StatCon Module" [Resolved]
org.eclipse.hyades.probekit (4.0.0) "Hyades Probekit" [Resolved]
org.eclipse.hyades.probekit.doc.user (4.0.0) "Probekit User
org.eclipse.hyades.probekit.ui (4.0.0) "Probe Editor" [Resolved]
org.eclipse.hyades.resources.database (4.0.0) "Hyades Core Resource
Extensions" [Resolved]
org.eclipse.hyades.sdb (4.0.0) "Symptom Database tool" [Resolved]
org.eclipse.hyades.statistical.ui (4.0.0) "Statistical Analysis" [Resolved]
org.eclipse.hyades.test.core (4.0.0) "TPTP Test Core Plug-In" [Resolved]
org.eclipse.hyades.test.doc.user (4.0.0) "Test Tools user documentation"
[Resolved]
org.eclipse.hyades.test.tools.core (4.0.0) "TPTP Test Tools Core
Plug-In" [Resolved]
org.eclipse.hyades.test.tools.ui (4.0.0) "TPTP Test Tools UI Plug-In"
[Resolved]
org.eclipse.hyades.test.ui (4.0.0) "TPTP Test UI Plug-In" [Resolved]
org.eclipse.hyades.trace.sample (4.0.0) "Samples for the TPTP Monitoring
Tools Plugins" [Resolved]
org.eclipse.hyades.trace.ui (4.0.0) "Hyades Trace Core UI" [Resolved]
org.eclipse.hyades.trace.views (4.0.0) "Hyades Trace Views Plugin"
[Resolved]
org.eclipse.hyades.ui (4.0.0) "Hyades UI" [Resolved]
org.eclipse.jdt (3.1.0) "Eclipse Java Development Tools" [Resolved]
org.eclipse.jdt.apt.core (3.1.0.apt02) "JDT APT Core" [Active]
org.eclipse.jdt.apt.ui (3.1.0.apt02) "JDT APT UI" [Resolved]
org.eclipse.jdt.core (3.1.0) "Java Development Tools Core" [Installed]
org.eclipse.jdt.core (3.1.0.apt02) "Java Development Tools Core" [Active]
org.eclipse.jdt.debug (3.1.0) "JDI Debug Model" [Active]
org.eclipse.jdt.debug.ui (3.1.0) "JDI Debug UI" [Active]
org.eclipse.jdt.doc.isv (3.1.0) "Eclipse JDT Plug-in Developer Guide"
[Resolved]
org.eclipse.jdt.doc.user (3.1.0) "Eclipse Java Development User Guide"
[Resolved]
org.eclipse.jdt.junit (3.1.0) "Java Development Tools JUnit support"
[Active]
org.eclipse.jdt.junit.runtime (3.1.0) "Java Development Tools JUnit
runtime support" [Resolved]
org.eclipse.jdt.launching (3.1.0) "Java Development Tools Launching
Support" [Active]
[Resolved]
org.eclipse.jdt.ui (3.1.0) "Java Development Tools UI" [Active]
org.eclipse.jdt.ui.examples.projects (3.1.0) "Java Development Tools
Example Projects" [Resolved]
org.eclipse.jem (1.1.0.1) "Java EMF Model" [Resolved]
org.eclipse.jem.beaninfo (1.1.0.1) "Java EMF Model BeanInfo
(Introspection) Support" [Resolved]
org.eclipse.jem.proxy (1.1.0.1) "Java EMF Model Proxy Support" [Resolved]
org.eclipse.jem.sdk (1.1.0) "Java EMF Model SDK" [Resolved]
org.eclipse.jem.source (1.1.0.1) "Java EMF Model Source" [Resolved]
org.eclipse.jem.ui (1.1.0.1) "Java EMF Model UI" [Resolved]
org.eclipse.jem.util (1.1.0.1) "Java EMF Model Utilities" [Active]
org.eclipse.jem.workbench (1.1.0.1) "Java EMF Model Workbench Support"
[Resolved]
org.eclipse.jface (3.1.0) "JFace" [Active]
org.eclipse.jface.text (3.1.0) "JFace Text" [Active]
org.eclipse.jst (0.7.0) "J2EE Standard Tools" [Resolved]
org.eclipse.jst.common.annotations.controller (0.7.0) "Annotation
Controller Plug-in" [Resolved]
org.eclipse.jst.common.annotations.core (0.7.0) "Annotation Core
Plug-in" [Resolved]
org.eclipse.jst.common.annotations.ui (0.7.0) "Ui Plug-in" [Resolved]
org.eclipse.jst.common.frameworks (0.7.0) "Integration Plug-in" [Resolved]
org.eclipse.jst.common.navigator.java (0.7.0) "Navigator Plug-in" [Resolved]
org.eclipse.jst.doc.isv (0.7.0) "JST ISV Documentation" [Resolved]
org.eclipse.jst.doc.user (0.7.0) "JST User Doc Plug-in" [Resolved]
org.eclipse.jst.ejb.ui (0.7.0) "WTP EJB UI Plug-in" [Resolved]
org.eclipse.jst.j2ee (0.7.0) "J2EE Component" [Resolved]
org.eclipse.jst.j2ee.core (0.7.0) "J2EE Core Component" [Resolved]
org.eclipse.jst.j2ee.ejb (0.7.0) "EJB component Plug-in" [Resolved]
org.eclipse.jst.j2ee.ejb.annotation.model (0.7.0) "EJB Annotation Model
Plug-in" [Resolved]
org.eclipse.jst.j2ee.ejb.annotations.emitter (0.7.0) "EJB Emitter
Plug-in" [Resolved]
org.eclipse.jst.j2ee.ejb.annotations.ui (0.7.0) "EJB Annotations Ui
Plug-in" [Resolved]
org.eclipse.jst.j2ee.ejb.annotations.xdoclet (0.7.0) "Xdoclet
Annotations Plug-in" [Resolved]
org.eclipse.jst.j2ee.jca (0.7.0) "JCA Plug-in" [Resolved]
org.eclipse.jst.j2ee.jca.ui (0.7.0) "WTP JCA UI Plug-in" [Resolved]
org.eclipse.jst.j2ee.navigator.ui (0.7.0) "J2EE Extensions to Common
Navigator" [Resolved]
org.eclipse.jst.j2ee.ui (0.7.0) "WTP J2EE UI Plug-in" [Resolved]
org.eclipse.jst.j2ee.web (0.7.0) "Web Plug-in" [Resolved]
org.eclipse.jst.j2ee.webservice (0.7.0) "Web Service Plug-in" [Resolved]
org.eclipse.jst.j2ee.webservices.ui (0.7.0) "WTP Webservice UI Plug-in"
[Resolved]
org.eclipse.jst.jsp.core (0.7.0) "Structured Source JSP Model" [Resolved]
org.eclipse.jst.jsp.ui (0.7.0) "SSE JSP Source Editor" [Resolved]
org.eclipse.jst.server.core (0.7.0) "Java Server Support" [Resolved]
org.eclipse.jst.server.generic.core (0.7.0) "Generic Server Plugin"
[Resolved]
org.eclipse.jst.server.generic.serverdefinitions (0.7.0) "Generic server
example definitions" [Resolved]
org.eclipse.jst.server.generic.ui (0.7.0) "Generic Server Plugin UI"
[Resolved]
org.eclipse.jst.server.geronimo.core (0.7.0) "Geronimo server support"
[Resolved]
org.eclipse.jst.server.geronimo.ui (0.7.0) "Geronimo server UI support"
[Resolved]
org.eclipse.jst.server.tomcat.core (0.7.0) "Apache Tomcat Support"
[Resolved]
org.eclipse.jst.server.tomcat.ui (0.7.0) "Apache Tomcat UI Support"
[Resolved]
org.eclipse.jst.server.ui (0.7.0) "Java Server UI Support" [Resolved]
org.eclipse.jst.server.websphere.core (0.7.0) "WebSphere Generic Server
Definition Core Plug-in" [Resolved]
org.eclipse.jst.servlet.ui (0.7.0) "WTP Servlet UI Plug-in" [Resolved]
org.eclipse.jst.source (0.7.0) "J2EE Standard Tools SDK" [Resolved]
org.eclipse.jst.ws (0.7.0) "Web Services" [Resolved]
org.eclipse.jst.ws.axis.consumption.core (0.7.0) "Web service Axis
Consumption Core" [Resolved]
org.eclipse.jst.ws.axis.consumption.ui (0.7.0) "Webservice Axis
Consumption UI" [Resolved]
org.eclipse.jst.ws.axis.creation.ui (0.7.0) "Webservice Axis Creation
UI" [Resolved]
org.eclipse.jst.ws.consumption (0.7.0) "Web Services Consumption" [Resolved]
org.eclipse.jst.ws.consumption.ui (0.7.0) "Web Services Consumption
Graphical User Interface" [Resolved]
org.eclipse.jst.ws.creation.ejb.ui (0.7.0) "Web Services Creation EJB
org.eclipse.jst.ws.creation.ui (0.7.0) "Web Services Creation Graphical
org.eclipse.jst.ws.uddiregistry (0.7.0) "Web Services Universal
Description Discovery and Integration Registry" [Resolved]
org.eclipse.jst.ws.ui (0.7.0) "Web Services Graphical User Interface"
[Resolved]
org.eclipse.ltk.core.refactoring (3.1.0) "Refactoring Core" [Active]
org.eclipse.ltk.ui.refactoring (3.1.0) "Refactoring UI" [Active]
org.eclipse.osgi.services (3.1.0) "OSGi Release 3 Services" [Resolved]
org.eclipse.osgi.util (3.1.0) "OSGi R3 Utility Classes" [Resolved]
org.eclipse.pde (3.1.0) "Eclipse Plug-in Development Environment" [Active]
org.eclipse.pde.build (3.1.0) "Plug-in Development Environment Build
Support" [Resolved]
org.eclipse.pde.core (3.1.0) "Plug-in Development Core" [Active]
org.eclipse.pde.doc.user (3.1.0) "Eclipse Plug-in Development User
Guide" [Resolved]
org.eclipse.pde.junit.runtime (3.1.0) "PDE JUnit Plug-in Test" [Resolved]
org.eclipse.pde.runtime (3.1.0) "Plug-in Development Environment
Runtime" [Active]
Developer Resources" [Resolved]
org.eclipse.pde.ui (3.1.0) "Plug-in Development UI" [Active]
org.eclipse.platform (3.1.0) "Eclipse Platform" [Resolved]
org.eclipse.platform.doc.isv (3.1.0) "Eclipse Platform Plug-in Developer
Guide" [Resolved]
org.eclipse.platform.doc.user (3.1.0) "Eclipse Workbench User Guide"
[Resolved]
org.eclipse.platform.source.linux.gtk.x86 (3.1.0) "Eclipse Platform
Plug-in Developer Resources" [Resolved]
org.eclipse.rcp (3.1.0) "Eclipse RCP" [Resolved]
[Resolved]
org.eclipse.rcp.source.linux.gtk.x86 (3.1.0) "Eclipse RCP Plug-in
org.eclipse.sdk (3.1.0) "Eclipse Project SDK" [Resolved]
org.eclipse.sdk.examples (3.1.0) "Eclipse SDK Examples" [Resolved]
org.eclipse.sdk.examples.source (3.1.0) "Eclipse Platform Plug-in
[Resolved]
org.eclipse.search (3.1.0) "Search Support" [Active]
org.eclipse.swt (3.1.0) "Standard Widget Toolkit" [Resolved]
org.eclipse.swt.examples (3.1.0) "SWT Standalone Examples Plugin" [Resolved]
org.eclipse.swt.examples.browser (3.1.0) "SWT Browser Example Plugin"
[Resolved]
org.eclipse.swt.examples.browser.demos (3.1.0) "SWT Browser Demos
Plugin" [Resolved]
org.eclipse.swt.examples.controls (3.1.0) "SWT Controls Example Plugin"
[Resolved]
org.eclipse.swt.examples.launcher (3.1.0) "SWT Launcher Example Plugin"
[Resolved]
org.eclipse.swt.examples.layouts (3.1.0) "SWT Layout Example Plugin"
[Resolved]
org.eclipse.swt.examples.paint (3.1.0) "SWT Paint Example Plugin" [Resolved]
org.eclipse.swt.gtk.linux.x86 (3.1.0) "Standard Widget Toolkit for GTK
2.0" [Resolved]
org.eclipse.target (1.0.0) "Target Plug-in" [Resolved]
org.eclipse.target.ftp (1.0.0) "Ftp Plug-in" [Resolved]
org.eclipse.target.ide (1.0.0) "Target IDE Plug-in" [Resolved]
org.eclipse.target.iofile (1.0.0) "I/O File Plug-in" [Resolved]
org.eclipse.target.webdav (1.0.0) "Target WebDAV Plug-in" [Resolved]
org.eclipse.team.core (3.1.0) "Team Support Core" [Active]
org.eclipse.team.cvs.core (3.1.0) "CVS Team Provider Core" [Active]
org.eclipse.team.cvs.ssh (3.1.0) "CVS SSH Core" [Resolved]
org.eclipse.team.cvs.ssh2 (3.1.0) "CVS SSH2" [Active]
org.eclipse.team.cvs.ui (3.1.0) "CVS Team Provider UI" [Active]
org.eclipse.team.examples.filesystem (3.1.0) "Eclipse Team File System
Example" [Active]
org.eclipse.team.extras (3.1.0) "Eclipse FTP and WebDAV Support" [Resolved]
org.eclipse.team.extras.source (3.1.0) "Eclipse Team Extras Plug-in
org.eclipse.team.ftp (3.1.0) "FTP Deployment Provider" [Resolved]
org.eclipse.team.target (1.0.0) "Team Target Plug-in" [Resolved]
org.eclipse.team.ui (3.1.0) "Team Support UI" [Active]
org.eclipse.team.webdav (3.1.0) "WebDAV Team Provider" [Resolved]
org.eclipse.test (3.1.0) "Eclipse Automated Testing" [Resolved]
org.eclipse.test.performance (3.1.0) "Performance Test Plug-in" [Resolved]
org.eclipse.test.performance.win32 (3.1.0) "Performance Monitor for
Windows" [Resolved]
org.eclipse.test.source (3.1.0) "pluginName" [Resolved]
org.eclipse.text (3.1.0) "Text" [Active]
org.eclipse.tomcat (4.1.30.1) "Tomcat Wrapper" [Active]
org.eclipse.tptp.monitoring.doc.user (4.0.0) "TPTP Monitoring Tools
org.eclipse.tptp.monitoring.logui (4.0.0) "Logui Plug-in" [Resolved]
[Resolved]
org.eclipse.tptp.platform.agentcontroller (4.0.0) "TPTP Agent
Controller" [Resolved]
org.eclipse.tptp.platform.agentcontroller.doc.user (4.0.0) "Agent
Controller documentation" [Resolved]
Engine Source" [Resolved]
org.eclipse.tptp.platform.analysis.examples (4.0.0) "TPTP Static
Analysis Examples Plug-in" [Resolved]
org.eclipse.tptp.platform.analysis.metrics (4.0.0) "Metrics Plug-in"
[Resolved]
[Resolved]
org.eclipse.tptp.platform.analysis.static.doc.user (4.0.0)
"#%plugin.name" [Resolved]
org.eclipse.tptp.platform.analysis.static.engine (4.0.0) "TPTP Static
Analysis Engine Plugin" [Resolved]
org.eclipse.tptp.platform.analysis.static.engine.ui (4.0.0) "TPTP Static
Analysis Engine UI Plugin" [Resolved]
org.eclipse.tptp.platform.analysis.static.util (4.0.0) "TPTP Static
Analysis Utilities Plugin" [Resolved]
org.eclipse.tptp.platform.analysis.static.util.ui (4.0.0) "TPTP Analysis
UI Utilities Plugin" [Resolved]
org.eclipse.tptp.platform.collection.framework (4.0.0) "TPTP Collection
org.eclipse.tptp.platform.core.source (4.0.0) "TPTP Core Source" [Resolved]
org.eclipse.tptp.platform.doc.user (4.0.0) "TPTP Platform Project
org.eclipse.tptp.platform.log.views (4.0.0) "Hyades Logging Sequence
Diagrams" [Resolved]
Analyzer Source" [Resolved]
org.eclipse.tptp.platform.models (4.0.0) "Hyades Models" [Resolved]
[Resolved]
org.eclipse.tptp.platform.report.core (4.0.0) "TPTP Report Framework"
[Resolved]
Source" [Resolved]
org.eclipse.tptp.platform.report.ui (4.0.0) "TPTP Report UI" [Resolved]
Source" [Resolved]
Statistical UI Source" [Resolved]
Source" [Resolved]
[Resolved]
[Resolved]
org.eclipse.tptp.test.source (4.0.0) "TPTP Test Source" [Resolved]
[Resolved]
org.eclipse.tptp.trace.source (4.0.0) "TPTP Trace Source" [Resolved]
org.eclipse.ui (3.1.0) "Eclipse UI" [Active]
org.eclipse.ui.browser (3.1.0) "Browser Support" [Resolved]
org.eclipse.ui.cheatsheets (3.1.0) "Cheat Sheets" [Resolved]
org.eclipse.ui.console (3.1.0) "Console" [Active]
org.eclipse.ui.editors (3.1.0) "Default Text Editor" [Active]
org.eclipse.ui.examples.javaeditor (3.1.0) "JFace Text Example" [Active]
org.eclipse.ui.examples.multipageeditor (3.1.0) "Multi-Page Editor
Example" [Resolved]
org.eclipse.ui.examples.propertysheet (3.1.0) "User File Editor" [Resolved]
org.eclipse.ui.examples.readmetool (3.1.0) "Readme File Editing Tool"
[Resolved]
org.eclipse.ui.examples.undo (3.1.0) "Undo Example" [Resolved]
org.eclipse.ui.externaltools (3.1.0) "External Tools" [Active]
org.eclipse.ui.forms (3.1.0) "Eclipse Forms" [Active]
org.eclipse.ui.ide (3.1.0) "Eclipse IDE UI" [Active]
org.eclipse.ui.intro (3.1.0) "Welcome Framework" [Active]
org.eclipse.ui.presentations.r21 (3.1.0) "R21 Presentation Plug-in"
[Resolved]
org.eclipse.ui.views (3.1.0) "Views" [Active]
org.eclipse.ui.workbench (3.1.0) "Workbench" [Active]
org.eclipse.ui.workbench.compatibility (3.1.0) "Workbench Compatibility"
[Resolved]
org.eclipse.ui.workbench.texteditor (3.1.0) "Text Editor Framework" [Active]
org.eclipse.uml2 (1.1.1.M200509221052) "UML2" [Resolved]
org.eclipse.uml2.codegen.ecore (1.1.1.M200509221052) "UML2 Ecore Code
org.eclipse.uml2.codegen.ecore.ui (1.1.1.M200509221052) "UML2 Ecore Code
org.eclipse.uml2.common (1.1.1.M200509221052) "UML2 Common" [Resolved]
org.eclipse.uml2.common.edit (1.1.1.M200509221052) "UML2 Common Edit"
[Resolved]
org.eclipse.uml2.doc (1.1.1.M200509221052) "UML2 Documentation" [Resolved]
org.eclipse.uml2.ecore.importer (1.1.1.M200509221052) "UML2 Importer for
EMF" [Resolved]
org.eclipse.uml2.edit (1.1.1.M200509221052) "UML2 Edit Support" [Resolved]
org.eclipse.uml2.editor (1.1.1.M200509221052) "UML2 Editor" [Resolved]
org.eclipse.uml2.examples (1.1.1.M200509221052) "UML2 Examples" [Resolved]
org.eclipse.uml2.examples.emof2ecore (1.1.1.M200509221052) "UML2
EMOF2Ecore Example" [Resolved]
Source" [Resolved]
org.eclipse.uml2.examples.ui (1.1.1.M200509221052) "UML2 Examples UI"
[Resolved]
org.eclipse.uml2.resources (1.1.0.M200509221052) "UML2 Resources" [Resolved]
org.eclipse.uml2.source (1.1.1.M200509221052) "UML2 Source" [Resolved]
org.eclipse.update.configurator (3.1.0) "Install/Update Configurator"
[Active]
org.eclipse.update.core (3.1.0) "Install/Update Core" [Active]
org.eclipse.update.core.linux (3.1.0) "Install/Update Core for Linux"
[Resolved]
org.eclipse.update.scheduler (3.1.0) "Automatic Updates Scheduler" [Active]
org.eclipse.update.ui (3.1.0) "Install/Update UI" [Active]
org.eclipse.ve (1.1.0) "Visual Editor" [Resolved]
org.eclipse.ve.cde (1.1.0.1) "Visual Editor Common Data Editor" [Resolved]
org.eclipse.ve.doc (1.1.0) "Visual Editor for Java User Guide" [Resolved]
org.eclipse.ve.java.core (1.1.0.1) "Visual Editor Java Core" [Resolved]
org.eclipse.ve.jfc (1.1.0.1) "Visual Editor for Java Foundation Classes"
[Resolved]
org.eclipse.ve.propertysheet (1.1.0.1) "Visual Editor PropertySheet"
[Resolved]
org.eclipse.ve.sdk (1.1.0) "Visual Editor SDK" [Resolved]
org.eclipse.ve.source (1.1.0.1) "Visual Editor Source" [Resolved]
org.eclipse.ve.swt (1.1.0.1) "Visual Editor for Standard Widget Toolkit"
[Resolved]
org.eclipse.webdav (3.0.0) "WebDAV Client" [Resolved]
org.eclipse.wst (0.7.0) "Web Standard Tools" [Resolved]
org.eclipse.wst.command.env (0.7.0) "Environment Command Framework
(headless)" [Resolved]
org.eclipse.wst.command.env.core (0.7.0) "Environment Command Framework
(core)" [Resolved]
org.eclipse.wst.command.env.ui (0.7.0) "Environment Command Framework
(GUI)" [Resolved]
org.eclipse.wst.common.emf (0.7.0) "EMF Utilities" [Resolved]
org.eclipse.wst.common.emfworkbench.integration (0.7.0) "EMF Workbench
Edit Plug-in" [Resolved]
org.eclipse.wst.common.frameworks (0.7.0)
"org.eclipse.wst.common.frameworks" [Active]
org.eclipse.wst.common.frameworks.ui (0.7.0) "WTP UI Plug-in" [Resolved]
org.eclipse.wst.common.modulecore (0.7.0) "Modulecore Plug-in" [Resolved]
org.eclipse.wst.common.navigator.views (0.7.0) "Common Navigator View"
[Resolved]
org.eclipse.wst.common.navigator.workbench (0.7.0) "Navigator Workbench
Components" [Resolved]
org.eclipse.wst.common.snippets (0.7.0) "Snippets View" [Resolved]
org.eclipse.wst.common.ui (0.7.0) "Eclipse Base UI extensions" [Active]
org.eclipse.wst.common.ui.properties (0.7.0) "Common Properties UI"
[Resolved]
org.eclipse.wst.common.uriresolver (0.7.0)
"org.eclipse.wst.common.uriresolver" [Active]
org.eclipse.wst.css.core (0.7.0) "Structured Source CSS Model" [Resolved]
org.eclipse.wst.css.ui (0.7.0) "SSE CSS Source Editor" [Resolved]
org.eclipse.wst.doc.isv (0.7.0) "WST ISV Documentation" [Resolved]
org.eclipse.wst.doc.user (0.7.0) "Web Standard Tools Help User Doc
Plug-in" [Resolved]
org.eclipse.wst.dtd.core (0.7.0) "Structured Source DTD Core" [Resolved]
org.eclipse.wst.dtd.ui (0.7.0) "SSE DTD Source Editor" [Resolved]
org.eclipse.wst.html.core (0.7.0) "Structured Source HTML Model" [Active]
org.eclipse.wst.html.standard.dtds (0.7.0) "Known DTDs" [Resolved]
org.eclipse.wst.html.ui (0.7.0) "HTML UI Source Editor" [Resolved]
org.eclipse.wst.internet.cache (0.7.0) "Cache URI Resolver Plug-in"
[Resolved]
org.eclipse.wst.internet.monitor.core (0.7.0) "Monitor" [Resolved]
org.eclipse.wst.internet.monitor.ui (0.7.0) "TCP/IP Monitor" [Resolved]
org.eclipse.wst.internet.proxy (0.7.0) "Internet Proxy Preferences" [Active]
org.eclipse.wst.javascript.core (0.7.0) "Structured Source JavaScript
Model" [Resolved]
org.eclipse.wst.javascript.ui (0.7.0) "SSE JavaScript Source Editor"
[Resolved]
org.eclipse.wst.rdb.connection.ui (0.7.0) "RDB Connection.ui" [Resolved]
org.eclipse.wst.rdb.core (0.7.0) "RDB Core" [Resolved]
org.eclipse.wst.rdb.core.ui (0.7.0) "Core UI plugin" [Resolved]
org.eclipse.wst.rdb.data.core (0.7.0) "Data Core Plugin" [Resolved]
org.eclipse.wst.rdb.data.ui (0.7.0) "Data UI Plugin" [Resolved]
org.eclipse.wst.rdb.dbdefinition.db2.iseries (1.0.0) "DB2 UDB iSeries
Database Definition Plug-in" [Resolved]
org.eclipse.wst.rdb.dbdefinition.db2.luw (0.7.0) "DB2 UDB Database
org.eclipse.wst.rdb.dbdefinition.db2.zseries (0.7.0) "DB2 UDB Database
org.eclipse.wst.rdb.dbdefinition.derby (0.7.0) "IBM Cloudscape Database
Definition" [Resolved]
org.eclipse.wst.rdb.dbdefinition.informix (0.7.0) "Informix Database
org.eclipse.wst.rdb.dbdefinition.mysql (0.7.0) "DBDefinition Mysql
Plug-in" [Resolved]
org.eclipse.wst.rdb.dbdefinition.oracle (0.7.0) "Oracle Database
org.eclipse.wst.rdb.dbdefinition.sqlserver (0.7.0) "SQL Server Database
org.eclipse.wst.rdb.dbdefinition.sybase (0.7.0) "Sybase Database
org.eclipse.wst.rdb.derby (0.7.0) "RDB Derby Plug-in" [Resolved]
org.eclipse.wst.rdb.derby.ui (0.7.0) "RDB Derby Ui Plug-in" [Resolved]
org.eclipse.wst.rdb.fe.ui (0.7.0) "FE Ui Plug-in" [Resolved]
org.eclipse.wst.rdb.fe.ui.actions (0.7.0) "FE Ui Actions Plug-in" [Resolved]
org.eclipse.wst.rdb.models.dbdefinition (0.7.0) "DBDefinition Model"
[Resolved]
org.eclipse.wst.rdb.models.sql (0.7.0) "SQLModel Plug-in" [Resolved]
org.eclipse.wst.rdb.models.sql.edit (0.7.0) "SQLModel Edit Plug-in"
[Resolved]
org.eclipse.wst.rdb.mysql (0.7.0) "RDB Mysql Plug-in" [Resolved]
org.eclipse.wst.rdb.outputview (0.7.0) "Data Output Plug-in" [Resolved]
org.eclipse.wst.rdb.server.extensions (0.7.0) "Server Explorer
Extensions Plug-in" [Resolved]
org.eclipse.wst.rdb.server.ui (0.7.0) "Server Explorer plugin" [Resolved]
org.eclipse.wst.rdb.sqleditor (0.7.0) "SQL Source Editor Plugin" [Resolved]
org.eclipse.wst.rdb.sqlscrapbook (0.7.0) "Sqlscrapbook Plug-in" [Resolved]
org.eclipse.wst.server.core (0.7.0) "Server Core" [Resolved]
org.eclipse.wst.server.ui (0.7.0) "Server UI" [Resolved]
org.eclipse.wst.source (0.7.0) "Web Standard Tools SDK" [Resolved]
org.eclipse.wst.sse.core (0.7.0) "Structured Text Model" [Active]
org.eclipse.wst.sse.ui (0.7.0) "Structured Source Editor" [Active]
org.eclipse.wst.validation (0.7.0) "Validation Framework" [Active]
org.eclipse.wst.validation.ui (0.7.0) "Validation Framework UI" [Resolved]
org.eclipse.wst.web (0.7.0) "Simple Web Plug-in" [Resolved]
org.eclipse.wst.web.ui (0.7.0) "Simple Web UI Plug-in" [Resolved]
org.eclipse.wst.ws (0.7.0) "Web Services" [Resolved]
org.eclipse.wst.ws.explorer (0.7.0) "Web Services Explorer" [Resolved]
org.eclipse.wst.ws.parser (0.7.0) "Web Services Description Parser"
[Resolved]
org.eclipse.wst.ws.ui (0.7.0) "Web Services UI" [Resolved]
org.eclipse.wst.wsdl (0.7.0) "WSDL Model" [Resolved]
org.eclipse.wst.wsdl.ui (0.7.0) "WSDL Editor" [Resolved]
org.eclipse.wst.wsdl.validation (0.7.0) "WSDL Validator" [Resolved]
org.eclipse.wst.wsi (0.7.0) "WSI Conformance Tools" [Resolved]
org.eclipse.wst.wsi.ui (0.7.0) "Soap Monitor" [Resolved]
org.eclipse.wst.xml.core (0.7.0) "Structured Source XML Model" [Active]
org.eclipse.wst.xml.ui (0.7.0) "XML UI Plugin" [Active]
org.eclipse.wst.xsd.core (0.7.0) "XSD Core Plugin" [Resolved]
org.eclipse.wst.xsd.ui (0.7.0) "XML Schema Editor" [Resolved]
[Resolved]
(XSD) Programmers Guide" [Resolved]
org.eclipse.xsd.ecore.importer (2.1.0.M200509081004) "XML Schema
Importer for EMF" [Resolved]
org.eclipse.xsd.edit (2.1.0.M200509081004) "XML Schema Edit Framework"
[Resolved]
org.eclipse.xsd.editor (2.1.0.M200509081004) "XML Schema Editor" [Resolved]
(XSD) Source" [Resolved]
org.junit (3.8.1) "JUnit Testing Framework" [Resolved]
org.uddi4j (2.0.3) "UDDI4J 2.0.3" [Resolved]
org.wsdl4j (1.4.0) "WSDL4J 1.4" [Resolved]
ru.novosoft.nsuml (1.4.0) "Novosoft NSUML" [Installed]
system.bundle (3.1.0) "OSGi System Bundle" [Active]
*** User Preferences:
#Thu Feb 16 10:05:00 EET 2006
@org.eclipse.tptp.platform.log.views=4.0.0
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.comment.indent_parameter_description=true
@org.eclipse.ui.editors=3.1.0
/instance/org.eclipse.team.cvs.ui/pref_added_flag=+
/instance/org.eclipse.team.cvs.ui/pref_filetext_decoration={ dirty_flag}{name}
@org.eclipse.debug.ui=3.1.0
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_after_at_in_annotation_type_declaration=do
not insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.brace_position_for_enum_constant=end_of_line
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.JUNIT_HOME=/myhome/eclipse/plugins/org.junit_3.8.1
/instance/org.eclipse.ant.ui/printMargin=true
/instance/org.eclipse.hyades.trace.ui/defaultProfilingSet=or g.eclipse.hyades.defaultProfilingSets.memory
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_after_binary_operator=insert
/instance/org.eclipse.debug.ui/org.eclipse.debug.ui.DebugVie w+org.eclipse.debug.ui.debugview.toolbar.toggleStepFilters=t rue
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.userLibr ary.edt_libs=\#\# <cp
entry ignore>\#\#
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_after_comma_in_method_invocation_arguments=in sert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_after_prefix_operator=do
not insert
/instance/org.eclipse.jdt.ui/Refactoring.savealleditors=true
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_before_closing_paren_in_if=do
not insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_after_comma_in_type_arguments=insert
/instance/org.eclipse.ui.workbench/ColorsAndFontsPreferenceP age.selectedElement=Forg.eclipse.jdt.ui.editors.textfont
/instance/org.eclipse.team.cvs.ui/pref_dirty_flag=*
/instance/org.eclipse.jdt.debug.ui/org.eclipse.debug.ui.Vari ableView.org.eclipse.jdt.debug.ui.show_null_entries=true
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_before_comma_in_method_declaration_throws=do
not insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.alignment_for_enum_constants=0
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .problem.unusedDeclaredThrownException=warning
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_before_opening_brace_in_annotation_type_decla ration=insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_after_opening_bracket_in_array_allocation_exp ression=do
not insert
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.text.custom_ templates= <?xml
version\="1.0" encoding\="UTF-8"?><templates><template
autoinsert\="true" context\="java" deleted\="false"
description\="adviceexecution pointcut (AspectJ)" enabled\="true"
name\="adviceexecution">adviceexecution()</template><template
autoinsert\="true" context\="java" deleted\="false" description\="after
returning advice (AspectJ)" enabled\="true"
name\="after_returning">after(${args}) returning() \:
${pointcut_expression} {}</template><template autoinsert\="true"
context\="java" deleted\="false" description\="after throwing advice
(AspectJ)" enabled\="true" name\="after_throwing">after(${args})
throwing() \: ${pointcut_expression} {\n}</template><template
autoinsert\="true" context\="java" deleted\="false" description\="around
advice (AspectJ)" enabled\="true" name\="around">around(${args}) \:
context\="java" deleted\="false" description\="before advice (AspectJ)"
enabled\="true" name\="before">before(${args}) \: ${pointcut_expression}
{\n}</template><template autoinsert\="true" context\="java"
deleted\="false" description\="call constructor pointcut (AspectJ)"
enabled\="true" name\="call_cons">call(${modifier_pattern}
${type_pattern}.new(..))</template><template autoinsert\="true"
context\="java" deleted\="false" description\="call method declaration
(AspectJ)" enabled\="true" name\="call_method">call(${modifiers_pattern}
${ret_type_pattern}
${type_pattern}.${id_pattern}(..))</template><template
autoinsert\="true" context\="java" deleted\="false" description\="cflow
name\="cflow">cflow(${pointcut_expression})</template><template
description\="cflowbelow pointcut (AspectJ)" enabled\=&q
Current Time: Tue Jul 22 03:13:57 EDT 2025
Powered by FUDForum. Page generated in 0.08395 seconds
