Home » Modeling » BPEL Designer » Installing BPEL Designer :s
Installing BPEL Designer :s [message #5516] Thu, 24 August 2006 10:47 Go to next message
Originally posted by: paola1109.xxxxxxxx.xxx
Hi, iŽm pretty new in eclipse, this is my problem
Downloaded eclipse 3.20 - clean install - and pointed it at the eclipse
plugin update: http://download.eclipse.org/technology/bpel/update-site/
but then appears this message NETWORK CONNECTION PROBLEM ENCOUNTERED
DURING SEARCH. help! :|
Re: Installing BPEL Designer :s [message #6512 is a reply to message #5516] Wed, 15 November 2006 03:02 Go to previous message
Originally posted by: andras.balogh.cas.de
Hi!
Are you not behind a proxy? You can set a proxy at
Window-> Preferences-> Install/update
regards,
Andras
"Giu" <paola1109@xxxxxxxx.xxx> schrieb im Newsbeitrag
news:c6607e03d3681edebc6f694ca0db93b1$1@www.eclipse.org...
> Hi, i
Previous Topic:WTP ArtifactEditModel and BPEL EditModel
Next Topic:Have a problem to use BPEL designer
Current Time: Sun Aug 31 17:23:39 EDT 2025
Powered by FUDForum. Page generated in 0.03025 seconds
